Onkyo TX-NR708 frozen, help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-05-2011, 06:03 PM - Thread Starter
My 2 month old Onkyo TX-NR708 has suddenly decided to freeze. When I turn it on (have to use the power cord, the power button does not work), it stays on a certain video mode. The video and audio works, but I can't change inputs, volume, etc. I never touch a button in front so I don't think it's stuck or anything. This is very strange. Can someone help? I emailed their support but have heard nothing back
David
413X3 is offline
post #2 of 8 Old 05-05-2011, 06:39 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
Try doing a factory reset. It's on page 84 in your manual. A warning. You will loose all settings by doing this.
Secret Squirrel is offline
post #3 of 8 Old 05-05-2011, 06:56 PM - Thread Starter
Thanks for the reply. No luck. It's in standby mode now after a reset.. only problem is none of the buttons work! I can't even turn it on. stuck in standby now
413X3 is offline
post #4 of 8 Old 05-05-2011, 07:08 PM
Quoted: 44 Post(s)
Liked: 39
Thats to bad. Im afraid there is most likely something wrong inside the AVR and you will probably need to get it serviced. Call Onkyo and see what they tell you to do. Don't wait for an Email reply. Im sure they are going to have you take into an authorized repair facility.
post #5 of 8 Old 05-05-2011, 07:09 PM - Thread Starter
Ok I got it out of standby by holding the power button down when I plugged in the receiver. but after that, I can't change anything, volume doesn't work, no input button works. Ugh
413X3 is offline
post #6 of 8 Old 05-05-2011, 07:10 PM - Thread Starter
Thanks I will do that. They probably ignored me because I didn't enter my serial number, a pain to get to without unplugging everything
413X3 is offline
post #7 of 8 Old 05-05-2011, 07:25 PM
Quoted: 44 Post(s)
Liked: 39
There has been some issues with the 708/808/1008 with freeze ups and some automatically switching inputs. Also remote controls not working on some units. I think your AVR could be one of the units suffering from this.
post #8 of 8 Old 05-05-2011, 08:33 PM - Thread Starter
Is there another better model I should get? or just hope they fix it properly?
413X3 is offline
Onkyo Tx Nr708
