AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (http://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   marantz sr8002 vs pm8004 for 2 channel music (http://www.avsforum.com/forum/90-receivers-amps-processors/1333309-marantz-sr8002-vs-pm8004-2-channel-music.html)
dabbu1 05-06-2011 03:19 AM
I was seeking some opinions on comparing these two units.
They are required for a powering a pair of Vienna Acoustic Grand Bachs (4 Ohms, 90db, 50-300 watts each)
The room is my living room 18*18*9 with an entry into the kitchen.
I dont listen to music ever in deafening levels.
My preference for the sr8002 is of course because it is a "receiver" (ie the multifunctionalities) and can be had for around $700-800 these days.
The pm8004 - i could live with an intergrated amplifier if the sound is really good.
The sr8002 claims to deliver 125 watts @ 8 ohms for 7 channels (though its kind of difficult to tell if its all 7 channels driven) and 160 watts @ 6 ohms.
The pm8004, on the other hand, is clearly their current premium non reference integrated amp running at $1000. However, it only delivers 70 watts per channel @ 8 ohms and 100 watts @ 4 ohms.
Is the PM8004 likely to give better quality sound? I can live without all the multifunctionalities of the receiver, if i knew that the quality of sound was better.
As i said, I dont care for party level volumes, but my understanding is that high wattage is also desireable for better dynamic range.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
