The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 06-04-2011, 02:08 PM
DenPureSound's Avatar
AJAXAZ --
Consider the 4311CI for a room that large also, but it will be around 2X in cost over the 3312CI. If you are the kind of person that very rarely upgrades, I would consider the 4311CI so you can reach up to 11.2 in that very large room, assuming the cost will fit your Budget.
The 4311CI - MSRP = $1999.99
The 3312CI - MSRP = $ 999.99
DenPureSound is offline
Old 06-04-2011, 02:13 PM
SocalSD's Avatar
Originally Posted by SocalSD View Post
Hi - quick question regarding setup of a new 1612. I can stream Netflix on my TV; how can I get the sound to play through my speakers? The AVR is only connected to the TV via the OUT on the AVR. Do I need to use another HDMI cable to connect the TV to the AVR?
To be more specific, I noticed that there is a TV source for the AVR, which plays sound through the TV speakers. If I want content from the TV to play through my AVR, I guess I have to connect the TV and AVR with a 2nd HDMI cable (the first one is on the OUT of the AVR to the TV)
SocalSD is offline
Old 06-04-2011, 02:31 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
On the 1612 try to send the tv audio back to the receiver using the toslink optical connection. Actually labeled tv in on receiver next to hdmi in.
kikkenit2 is offline
Old 06-04-2011, 02:51 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
You have a couple options ... if you have a newer 3D HDMI 1.4 TV that supports ARC, then you can turn it ON and set HDMI Control to ON on the 1612 and pass the audio from the TV back to the 1612 via the same HDMI cable that connects from the HDMI Monitor Out on the 1612 to the TV. Simply press TV on the remote and you'll get the audio from the TV. If you have an older TV, then connect an optical cable from the TV audio out to the optical input on the 1612 and again press TV on the remote to get the audio from the TV.
jdsmoothie is online now
Old 06-04-2011, 04:32 PM
SocalSD's Avatar
Perfect - HDMI Control ON the 1612 did the trick. Many thanks
SocalSD is offline
Old 06-04-2011, 05:05 PM
I was experimenting today with converting .mp3 over to .flac and .wav to see the differences in filesizes, and Sound Quality (SQ) differences and whether I could notice a human ear perceivable difference when playing them into the Denon 33XX, using an 8GB USB Flash Drive.
FileSizes
.mp3 = 11,143KB
.flac = 61,423KB
.wav = 200,545KB
Knowing .flac is lossless, but compressed somewhat, I was amazed at the filesize difference from .flac to .wav, shown above.
I used the "Switch Sound File Converter" (Excellent Free Program) to convert files, and it was set as follows:
.wav -- 96KHz./24bits/Stereo
.flac -- Encoder Compression = 4
Sampling Rate = 96K
Stereo
The Denon would NOT play .wav files set for 96KHz./32bits/Stereo, but did work on the next lower setting being 96KHz./24bits/Stereo !!
Before I convert 1,000 of .mp3's to another Higher SQ Format, wanted to know if anyone else has something to add to this... Pls. chime in JD, and BP ++...
Looks like I most likely will convert to .flac and serve up the audio files via DLNA server on home net.
Always something NEW...
Old 06-04-2011, 05:12 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
wait -- you are converting MP3 into FLAC? you do know that the SQ will not be better right? you can't start with the lossy version and convert it back to the lossless version -- the data is already gone!
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 06-04-2011, 05:38 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
FileSizes
.mp3 = 11,143KB
.flac = 61,423KB
.wav = 200,545KB
Sampling Rate = 96K
Stereo
I'm assuming your using the original higher Rez source to convert from. Converting to flac from a mp3 isn't correct.
Edit: see bp beat me to it..
In search of video bliss...
mariob33 is offline
Old 06-04-2011, 06:04 PM
mbman81's Avatar
Hi Denon users,
I'm thinking of getting some Monitor rx8s. Heard them at the store and thought they were great sounding. My concern is that they are 4 ohms. My receiver is a 2112 which officially supports 8 and 6 ohms. Will it be powerful enough to play these? Will my speakers be as loud as they would with comparable 8 ohm speakers?
Are other people running 4ohm fronts strait off the receiver without a separate amp? How is the distortion?
Thanks guys!
mbman81 is offline
Old 06-04-2011, 06:10 PM
You are 100% correct indeed. Must of been brain dead... but believe it or not, it seemed to me that the .flac was better than the .mp3 in SQ, maybe just Placebo effect.
Old 06-04-2011, 06:12 PM
Mariob33, Your right on again and 100% correct. What Higher Res. source should I use, .wav to start out with or ?? then convert to .flac or ?
Old 06-04-2011, 06:15 PM
Originally Posted by mbman81 View Post
Hi Denon users,
Thanks guys!
What is the sensitivity of those speakers in db (2.83V/1M)? Use this for starters to determine How Loud It Will go :
http://myhometheater.homestead.com/splcalculator.html
Old 06-04-2011, 06:27 PM
jdsmoothie's Avatar
Liked: 5508
Either .wav or .flac compressed from the original source (if CD or vinyl).
Old 06-04-2011, 06:35 PM
jdsmoothie's Avatar
Liked: 5508
Hi Denon users,
Thanks guys!
Every XX12 model is designed to support 6Ω and 8Ω speakers, although at average volumes and in small/med sized rooms can usually run 4Ω speakers as well. If you are in a larger room or prefer to listen to your movie or music audio at reference volume (0db), then you would either want to look at 8Ω speakers or consider an AVR with preouts to add an external amp. And no, the RX8's would not be as loud at the same volume as 8Ω speakers (which is why you would be limited to a volume of only about -20db as if you tried to get the same higher volume as the 8Ω speakers, you would push the AVR into protection mode which would cause it to shut down). Think of it like two hoses ... an 8Ω speaker is like a 1/2" hose where the water flowing through it has pretty good force/pressure while water flowing at the same pace from the source through a 2" hose would have much less force/pressure (ie. 4Ω speakers).
Old 06-04-2011, 07:01 PM
mbman81's Avatar
That is disheartening. I finally found some speakers that the misses and I both enjoyed the sound from. So basically a 4 ohm speaker requires that additional power to keep a similar sound DB level? I already got the 2112 so guess I have to find another speaker since therecis no pre outs. Doh!
mbman81 is offline
Old 06-04-2011, 07:06 PM
mbman81's Avatar
Keep in mind, that only the two towers would be 4 ohms, the other channels would be 6 ohms. Since it's just two it may have enough power to keep going?
mbman81 is offline
Old 06-04-2011, 07:13 PM
jdsmoothie's Avatar
Liked: 5508
The front 3 speakers require the most power. See if the store you demo'd them in will let you take them home to demo. You can then see for yourself how they manage in your room and just how high you can raise the volume before they shut the AVR down in protection mode.
Old 06-04-2011, 07:14 PM
rynberg's Avatar
1. Isn't your 2112 still in the return window?
2. If you love the speakers then try them out...a good dealer should let you take a pair home overnight to audition them.
rynberg is offline
Old 06-04-2011, 07:44 PM
G-rig's Avatar
Just to confirm ... you also have the sub connected via the sub preout? Otherwise the AVR won't recognize the sub as being present and Audyssey won't apply any filtering to it.
Yes, I had both connected, thanks.
(The manual for the speakers says to set it up this way as the crossovers are installed in the subwoofer. So the amplifier is connected to the inputs on the subwoofer and the satellites are connected to the outputs on the subwoofer).
G-rig is offline
Old 06-04-2011, 07:46 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
If you have them available the original CD..
mariob33 is offline
Old 06-04-2011, 08:04 PM
moshock's Avatar
So what's with the 3312 inventory?...
Any reviews out for it yet?...
moshock is offline
Old 06-04-2011, 08:12 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Not sure what you mean? I was able to call around and several dealers had them in stock. I wound up going with ABT but I would also try AVS forum sponsor.
mariob33 is offline
Old 06-04-2011, 09:15 PM
Schappy's Avatar
Is anybody streaming there music to their Denon Receiver.
I have a 1912 and am trying to use Windows Media Player to stream music to the receiver.
I had everything set up and working. Now for some reason it can only detect 4 albums from my library.
I have streaming enabled in WMP.
Schappy is offline
Old 06-04-2011, 09:37 PM
sahmen's Avatar
Heeelp! Can anyone tell me what I shall be losing out on if I go with a closeout deal on the 3311 instead of getting the 3312? I am mostly interested in sound quality, great 2d/3d pq, and good networking capabilities. I have been waiting for the 3311 prices to come down since the xx12 models were announced.... i would even consider getting the 991 (except that they do not have pre-outs, which even my current 989 does)... The pre-outs are not absolutely necessary for me at the moment... I just want them for purely "just in case" reasons. Still, if there is no really compelling reasons to jump on the 3312 wagon, then I'd rather target the 3311/991. Any helpful tips would be very welcome.
sahmen is offline
Old 06-04-2011, 10:15 PM - Thread Starter
batpig's Avatar
Liked: 3415
not much in the way of new features on 3312 vs. 3311. the most important functional changes are:
1) a more colorful "advanced" GUI (more like what was in the 4311, 4310 etc)
2) the GUI can overlay on 3D video (the 3311 can overlay only on 2D video)
3) you can have both HDMI outs active simultaneously (3311 is one or the other)
4) Airplay is built in (it's a $49 upgrade on the 3311)
5) 1 extra HDMI input (6 on the back, 1 on front vs 5/1 on the 3311)
6) cheesier looking front fascia; the 3311 has the slicker front end with the drop-down door.
PQ and SQ should be the same. Both use MultEQ XT, have Audyssey DSX, 3 zones, plenty of HDMI inputs, video conversion, 125W/ch, etc and have the same 3-year warranty.
BTW -- there are color images of the new 3312 GUI posted on the 3312 product page (scroll right in the photo thingy). The 3311 GUI is the same as the 3310 GUI in this youtube video.
Setup Guide and FAQ
batpig is offline
Old 06-04-2011, 10:18 PM
rynberg's Avatar
Originally Posted by sahmen View Post
Heeelp! Can anyone tell me what I shall be losing out on if I go with a closeout deal on the 3311...
Get the 3311 if you ask me. I consider the 3312 inferior.
rynberg is offline
Old 06-04-2011, 10:28 PM
moshock's Avatar
moshock is offline
Old 06-04-2011, 10:44 PM
**OptimusPrime**'s Avatar
Liked: 29
Anyone do a video quality comparison from last years' models? I read a review that says the picture quality was "blurry" on a satellite feed though the 1912. However, no info on whether or not it was through HDMI or component cable.
**OptimusPrime** is offline
Old 06-04-2011, 11:01 PM
jdsmoothie's Avatar
Liked: 5508
In addition to batpig's fine summary differences, the 3312CI also uses a new Analog Devices video chip (not as yet compared to the ABT chip in the 3311CI) and also uses a new design on the network card, so hopefully more reliable then the one installed on the 3311CI which had some issues that were resolved with firmware updates.
Old 06-05-2011, 12:37 AM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
Batpig and jdsmoothie...great job taking the bull by the horns with this thread. When I was looking at avr's in the past it was so annoying to see different avr's "official" threads first few posts having no substantial info. That's ridiculous and lazy.
You guys have done a great service for future and current avr owners. I'm sure it will also facilitate a more precise and better flowing thread.
I hope you guys never decide to just pack up and leave us!
The great support you two offer the avs Denon community is irreplaceable and absolutely one of the main reasons I have purchased a Denon for myself and my parents.
I hate to eat up space on this thread but feel like letting, not only you guys, but the rest of the avs community to know my feelings about it.
mphfrom77 is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
