The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 06-06-2011, 12:24 PM
MuaySteve's Avatar
Quoted: 24 Post(s)
Liked: 31
^That is what I was expecting the Canadian prices to be. Eeek.
MuaySteve is offline
Old 06-06-2011, 01:16 PM
defkon's Avatar
Hmmm.. $700 MSRP for 2112 and $850 for 2312...
is there any justification for spending the extra 150??
I see that it has a couple more features ....
- Advanced GUI
- 105W/chan vs 90 on 2112.
Is there anything else? Is this enough to justify the $150? To be honest this is my first AVR I have purchased for my home theater my last being a Sony HTIB setup... Just want to make sure I put my money into the best place...
Thx
defkon is offline
Old 06-06-2011, 01:19 PM
AjaxAz's Avatar
Originally Posted by batpig View Post
you could use them in a pinch but dipoles aren't really recommended for height speakers. You might not hear much from them given how diffuse they already are! Where are the built-in surrounds located? To the sides or behind the seating area?
definitely go with the 3312ci in a room that size, especially if you are a "keep it for a long time" kind of guy. IMHO before you look for better speakers, add another subwoofer. A room that size will swallow up a single little sub.
The built in rear surrounds are in the ceiling, unfortunately, but they seem to be alright. And for as small as the Atlantic 173 sub is, it packs a pretty solid wallop, IMO. But you're probably right that another sub would help considerably.
Sure. Although if the current surrounds were improperly located behind you (as many are) then you would be better served using them as "rear" surrounds and setting up your Atlantic speakers as "side" surrounds. If the current surrounds are properly placed as "side" surrounds, then you might also want to consider placing the Atlantic speakers on pedastals and using them as DSX "wide" speakers (feature only on the 3312CI) as wides generally provide a better surround field then do either the rear surrounds or front height speakers.
Interesting, although I am constrained by having the built in surrounds in the ceiling above my seating position, and I don't think I can get approval from key household members to reconfigure or add additional speakers to the side or behind. The room is a "great room" with a combined living room/kitchen and I'd have to wire under the carpet to get speakers behind or to the side of the couch. The main seating position is basically dead center of the room.
Originally Posted by DenPureSound View Post
AJAXAZ --
Consider the 4311CI for a room that large also, but it will be around 2X in cost over the 3312CI. If you are the kind of person that very rarely upgrades, I would consider the 4311CI so you can reach up to 11.2 in that very large room, assuming the cost will fit your Budget.
The 4311CI - MSRP = $1999.99
The 3312CI - MSRP = $ 999.99
I barely have the budget to reach out and get the 3312CI, but thanks for the input. Plus, I'm unlikely to be adding any speakers in the near future (I might change my speakers, but it is now doubtful I'll ever move beyond a 5.1 setup). Plus, after my Onkyo fried, I'm afraid of investing 2k in a receiver and having it die on me just out of warranty. Probably an unjustified fear, but I was pissed when the Onkyo died.
AjaxAz is offline
Old 06-06-2011, 01:27 PM
Slickman's Avatar
Quoted: 133 Post(s)
Liked: 91
- Advanced GUI
Thx
It also has upscaling for non HD sources. I ended up getting the 2112 though because it's much cheaper and I basically only use HD sources, plus the wattage difference is only a .5db difference by my calculations.
Slickman is offline
Old 06-06-2011, 01:58 PM
crazyfoo's Avatar
ughhh just got the receiver, and I assumed zone 2 would have the speaker wire connections like zone 1 does, alas they are RCA. Do I need to use a Speaker Wire to RCA adapter to get the 2nd zone audio working with the receiver?
Found one at Monoprice, but now I guess I need to buy a soldering gun just for this, oh and learn how to solder.
Am I missing something? Is there something else I can try?
"I don't know how to put this, but I'm kind of a big deal."
crazyfoo is offline
Old 06-06-2011, 02:03 PM
ccotenj's Avatar
Liked: 101
no, that's not gonna work... you can't hook up your speakers to a line level output...
you need to connect those outputs to an amplifier, and then an amplifier to the speakers...
edit: which unit do you have? isn't there an amp assign option to use a pair of the speaker binding posts for zone 2?
- chris
ccotenj is offline
Old 06-06-2011, 02:13 PM
jdsmoothie's Avatar
Quoted: 12424 Post(s)
Liked: 5670
It's a 7.1 AVR so as long as you've only got a 5.1 setup in your main zone you can use the Surr Back/Amp Assign posts for powered Zone 2.
jdsmoothie is offline
Old 06-06-2011, 02:15 PM
crazyfoo's Avatar
OHHH THANK YOU! I don't even have speakers in the main zone yet, just bought this receiver with the plans to get some. I will be fine with 5.1 when the time comes!
crazyfoo is offline
Old 06-06-2011, 02:27 PM
jdsmoothie's Avatar
Liked: 5670
Yup .... in fact as the vast majority of owners only have a 5.1 setup, the factory default setting for the AMP ASSIGN setting is Zone 2.
Old 06-06-2011, 02:49 PM
Jedi54's Avatar
new member here and I cannot thank jdsmoothie and a few other vital members here enough for all of their dedication and support.
After reading 21 pages of this thread, I decided to go with the 2112 and am VERY excited about this AVR.
I redeemed quite a few of my Citi Thank you Points and will be getting JR gift certificates to cover the lower price that I was quoted on the phone so hopefully they'll arrive before this supposed rate increase.
Jedi54 is offline
Old 06-06-2011, 02:53 PM
Slickman's Avatar
Quoted: 133 Post(s)
Liked: 91
Originally Posted by Jedi54 View Post
new member here and I cannot thank jdsmoothie and a few other vital members here for all of their dedication and support.
Welcome and congrats on the purchase, I should have my 2112 later this week.
Slickman is offline
Old 06-06-2011, 03:13 PM
Jedi54's Avatar
and to think... I originally started my search thinking I was going to get a Yamaha receiver.
Since I'm saving money by using my points, I decided to pick up some Polk Monitor 70 speakers and a CS2 center channel while I was at it.
Should be fun once it's all complete
Jedi54 is offline
Old 06-06-2011, 03:17 PM
G-rig's Avatar
PS3 with the ps3 media server program on your computer. You get the full DTS sound this way too. You can also copy the files to your PS3 as well.
So does that mean the PS3 will do the decoding and the output LPCM audio is identical to the Dolby TrueHD / DTS-HD MA original format (via HDMI to the receiver)?
Is Dolby TrueHD / DTS-HD MA still possible with 5.1 speakers (or is it downmixed as DTS 5.1)?
I'll have to look into a better media player than the WDTV.
G-rig is offline
Old 06-06-2011, 03:24 PM
jdsmoothie's Avatar
Liked: 5670
Okay folks ... it's official. Denon has confirmed that MSRP will be going up on the 1912, 2112CI, 2312CI, and 3312CI effective June 12. Although the new rates are not yet known for sure, the increase will average about $100 per model apparently due to "the earthquake (in Japan) and the cost pressures as a result of that disaster".
If you have pre-ordered prior to that date, the resellers will most likely honor that pre-order purchase price.
Old 06-06-2011, 03:26 PM - Thread Starter
batpig's Avatar
Quoted: 3591 Post(s)
Liked: 3433
correct, TrueHD or DTS-MA is just a "container" for the lossless PCM audio
The number of speakers is irrelevant, DTS-MASTER could be 2 channels, 5 channels, 7 channels... the point is LOSSLES vs LOSSY encoding.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 06-06-2011, 03:27 PM
Slickman's Avatar
Quoted: 133 Post(s)
Liked: 91
MKVs usually have DTS that is downmixed at 1.5mb per second, but it still sounds very good, and it's pretty hard to tell a difference between an actual Blu-ray and an MKV. The PS3 sends the DTS signal to the receiver, so instead of it saying Multi Channel In on the receiver it'll say DTS instead. The newest version of PS3 Media Server has worked with every MKV I've thrown at it, and the MKVs can either be streamed in real time, or you can copy them to the PS3.
Slickman is offline
Old 06-06-2011, 03:45 PM
G-rig's Avatar
Thanks for clarifying that Slickman & batpig - Sounds like the PS3 with PS3 media server is a good bit of kit.
I also wanted to make sure lossless transport was possible when playing a BR disc in the PS3 as well, as I would assume that the Denon should do the decoding if it receives an LPCM signal over HDMI. Otherwise the receiver won't be doing any decoding (just receiving a multichannel signal)?
G-rig is offline
Old 06-06-2011, 03:52 PM
jdsmoothie's Avatar
Liked: 5670
LPCM "is" the decoded audio file by the PS3 which is passed to the AVR (no further decoding required by the AVR) and why the AVR reads "Mult Ch In" as it has no way of knowing what the original compressed file format was ... DD or DTS.
Old 06-06-2011, 04:05 PM
subq's Avatar
Current MSRP is $599.99 correct, your saying it is going up to $699.99 (for the 2112CI)?
subq is offline
Old 06-06-2011, 04:39 PM
hobo1137's Avatar
Originally Posted by joeyd1965 View Post
All, I just ordered a 2112 from ABT for $499 - several in stock.
Confirmed! Live Chat program on their site worked as good as a phone call. I cannot wait until this arrives! This thread has been a great resource.
hobo1137 is offline
Old 06-06-2011, 04:42 PM
mariob33's Avatar
Quoted: 89 Post(s)
Liked: 69
Send a message via Skype™ to mariob33
Originally Posted by jdsmoothie
Sorry, didn't want to get make this too complicated. Let's make it easy and just say "in the house."
Agreed : o )
In search of video bliss...
mariob33 is offline
Old 06-06-2011, 04:45 PM
Slickman's Avatar
Quoted: 133 Post(s)
Liked: 91
How'd you guys get it for $499, on my computer it says $599. I only paid $532 so I wasn't that far off, but still. I got mine on hookedontronics.com and used a coupon code.
Slickman is offline
Old 06-06-2011, 04:46 PM
johnnyletrois's Avatar
I've been trying to stream MKV from PS3 Media Server on my desktop via gigabit and cannot get it to work at all. Some files will open and start playing, but then hang. Others won't play at all and I get the unsupported file error.
Desktop is an i7-2600 with 8gigs of RAM and I'm on a gigabit LAN so not sure what the problem is.
johnnyletrois is offline
Old 06-06-2011, 04:47 PM
Slickman's Avatar
Quoted: 133 Post(s)
Liked: 91
Do you have the newest version that just released like 1-2 weeks ago? With the older version only like half my MKVs worked, but now with the new version all my MKVs work perfect.
Slickman is offline
Old 06-06-2011, 04:49 PM
dpmb's Avatar
All you do is call and ask. I've called 3 or 4 authorized sellers, and each has quoted me a price of $499.
Looks like I need to pull the trigger before the suggested increase.
dpmb is offline
Old 06-06-2011, 04:55 PM
jdsmoothie's Avatar
Liked: 5670
Yes.
Old 06-06-2011, 04:56 PM
jdsmoothie's Avatar
Liked: 5670
Did you buy a 3rd party warranty as well as you won't have a valid warranty buying from an unauthorized reseller?
Old 06-06-2011, 04:58 PM
mariob33's Avatar
Quoted: 89 Post(s)
Liked: 69
Yes.
So looks like with the increase the best buy pricing is dead on. Thanks for the confirmation.
mariob33 is offline
Old 06-06-2011, 05:00 PM
Jedi54's Avatar
dang it, no way my JR gift cards will get here before then.
I had called them a few days ago and had gotten a price of $549.
Jedi54 is offline
Old 06-06-2011, 05:06 PM
jdsmoothie's Avatar
Liked: 5670
I'm guessing they will work with you .. perhaps even hold it with a credit card until your gift cards arrive.
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
