The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 309 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 02-18-2012, 08:46 AM
Charles R's Avatar
Liked: 536
Originally Posted by HTNUT1975 View Post
If it didn't show "XT" would that mean it doesn't have MultiEQ XT? That's the primary reason I got it.
It goes through the 8 positions so I think it's a cosmetic (display) thing.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 02-18-2012, 08:59 AM
tcat's Avatar
Quoted: 197 Post(s)
Liked: 93
Looking at this authorized dealer list: http://usa.denon.com/us/wheretobuy/p...eetailers.aspx I assume I'd be better off paying $10 more from B&H than from Buy.com (or Ebay) for a new 1712.
tcat is offline
Old 02-18-2012, 09:04 AM
ozar's Avatar
Liked: 152
One month owner of the 1912 here, and while I'm very happy with it, I sort of which I'd gone for a little more power. I wasn't thrilled with the owner manual (on CD) or the remote control that came with it, but they'll do.
oz
ozar is offline
Old 02-18-2012, 09:34 AM
khronikos's Avatar
I decided to step up to the 2112 from the same seller on Ebay. I like the features. Only 360 shipped for refurb! 1 left.
khronikos is offline
Old 02-18-2012, 09:38 AM
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Hi,
My buddy just bought the Denon 3312ci. When we were setting it up, he called Denon and they told him to put it on LFE+main. All of his speakers on Definitive Tech and all set to small. Seems from everything I read, this should be set to LFE. Should I have him change this to LFE?
Thanks, Jerry
UN60HU8550 HS01 SEK-3500 Denon X4300h Samsung UBD-K8500 4K Ultra HD
Lyons07 is offline
Old 02-18-2012, 10:01 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
Originally Posted by Lyons07 View Post
Hi,
Thanks, Jerry
Have you read Batpig's Denon guide? If not, Google Batpig Denon and you will find it.
Mathematics is the reason for the season.
Nickff is offline
Old 02-18-2012, 10:35 AM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5511
Hi,
Thanks, Jerry
It doesn't matter, although no reason to change from the factory default of LFE. When the front mains are set to SMALL (as they should be), the sub setting of LFE+MAIN does not apply, rather only whan the speakers are set to LARGE. Unfortunately, Denon CSRs are a 3rd party company and often are not trained well enough to provide the correct and accurate information.
jdsmoothie is offline
Old 02-18-2012, 10:36 AM
jdsmoothie's Avatar
Liked: 5511
Originally Posted by khronikos View Post
Does the 1912 pass 0-255 now after a firmware update. Thanks. There is a sweet deal on ebay and I need to know this for my PC.
The last firmware update I saw had this on it but I don't know if it is for this one.
Yes. This was fixed with a firmware update last summer.
Lyons07's Avatar
Quoted: 108 Post(s)
Liked: 26
Thank you!!
Lyons07 is offline
Old 02-18-2012, 10:37 AM
jdsmoothie's Avatar
Liked: 5511
Originally Posted by Charles R View Post
I recently saw a 1712 which shipped from Denon (not the dealer) within a couple of weeks ago and it still didn't light up XT. So Im guessing it's hard to find a unit which has been updated.
My guess is that a firmware update has never been developed to resolve the issue of the XT not showing up ... just not that important.
Edit: On a brighter note, and yes, it's been a long time coming for sure ..... the new XX13 models are apparently all going to be firmware updatable via a USB jack.
Old 02-18-2012, 10:43 AM
jdsmoothie's Avatar
Liked: 5511
Originally Posted by ozcot View Post
I now have a Pioneer 1019 had for a few years no issues but I am looking into getting a Denon 1912 for the 3d pass through and other upgrades the Pioneer fails to have. Will the Denon a give much better sound quality as well? Is getting MultEQ XT that big of a deal if so I may go with the 2112. Thanks for any info.
You will likely find some improvement in that MultEQ can EQ the sub whereas the Pioneer cannot. The difference between MultEQ and XT is likely to be more subtle depending on the quality of your speakers. However, if you are located in the USA, the difference in cost between the 1912 and 2112CI from Electronics Expo is generally only $20-$50 which makes it a no brainer to get the 2112CI, for the better Audyssey version, extra year of warranty, and the ability to SAVE the config file to a PC so you don't have to rerun AUTO SETUP again if for some reason you have to do a microprocessor reset.
Old 02-18-2012, 10:50 AM
jdsmoothie's Avatar
Liked: 5511
Originally Posted by TechB74 View Post
Hi JD, thanks! I had do do the network reset and got the system working again. However if I try to update again it does the same thing. It gets stuck at the Authenticating stage. Any ideas? Thanks again!
It could be an issue with your network so try resetting the router and if the AVR isn't directly connected to the router via cable, try that as well.
Old 02-18-2012, 10:51 AM
jdsmoothie's Avatar
Liked: 5511
Not at all ... the fact that you can do 8 mic positions confirms it's XT and not regular MultEQ.
Old 02-18-2012, 10:56 AM
Possumgirl's Avatar
Liked: 58
Originally Posted by wrooster View Post
Hi folks,
First all GREAT THREAD here, tons of useful info.
I have an AVR2112 incoming, which will be mated with a Samsung UN55D6300SF TV. This TV supports HDMI ARC.
I am trying to determine whether the HDMI ARC supports 5.1 audio sourced by the TV tuner, or whether I have to run a separate TOSLINK fiber to get the audio from the OTA HDTV tuner back to the AVR2112.
ARC will send 5.1 audio from the internal tuner to the receiver. Follow the Sammy's instructions for turning on Anynet+ and connecting to HDMI2. Be sure you turn on HDMI-CTL on the Denon. It is off by default.
Possumgirl is offline
Old 02-18-2012, 10:58 AM
jdsmoothie's Avatar
Liked: 5511
Well I saw the firmware and I think I am going to pull the trigger for 320 and free shipping for refurb. Too good to pass up. I would like some confirmation but I guess the firmware in January is good enough.
Ozcot they have the 1912 right now on ebay for 320.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=280828229265
Better hurry 342 after tax but 6 or more free ebay bucks and only 3 LEFT!
The ebay seller you purchased from is NOT an authorized reseller of Denon refurbs (they made a one time purchase from Denon and all units sell with a reduced 90 day warranty). Suggest you purchase a 3rd party warranty from them as well. Also note there are only 4 authorized refurb resellers as noted in the link below. When purchasing from them you will get a full 1 year warranty from Denon.
Yes and no. You always take a chance when buying from an unauthorized reseller as Denon will not honor the warranty if you need any repairs, so if you choose to go that route, as suggested above, get a 3rd party extended warranty.
That said, the best prices on Denon AVRs (new) are from several authorized resellers that provide discounts to include AV Science, Electronics Expo, and J&R. Give them a call and ask for their best price and you'll likely get a brand new unit for the same price the refurbs are going for.
Old 02-18-2012, 11:01 AM
jdsmoothie's Avatar
Liked: 5511
Unless you have your AVR volume knob maxed out, the additional power in even the 3312CI would have been moot. Rather you would need to add an external amp with at least 250W or more.
Old 02-18-2012, 11:05 AM
jdsmoothie's Avatar
Liked: 5511
Originally Posted by Scurly View Post
So....if you have your crossover is set to 80, does this mean your surrounds and center are also set at 80hz? I run Audyssey then change all speakers to Small.
Only if you want it set that way, otherwise you can set them up to separate crossovers if desired. You can easily check the speaker settings in the Speaker Setup menu.
Old 02-18-2012, 12:02 PM
lou99's Avatar
I recently upgraded from a Onkyo 607 to a Denon 2312, and for the first time ever I'm running into HDMI handshake-setting issues.
The devices having issues are
PS3 Slim - Black screen, no video, no audio. I've turned off Deep Color Output, and set the HDMI settings to "Manual" at 1080i,p, and 720p.
Samsung Time Warner Cable Box - I get Audio, but Video is displayed as grey/white and black flickering. Restarting the box, and receiver seems to resolve this most of the time.
Is there a setting in the Denon that would make it a bit more compatible with other devices?
lou99 is offline
Old 02-18-2012, 01:07 PM
Garman's Avatar
Quoted: 1184 Post(s)
Liked: 507
So I'm looking to pull the trigger on the 1712, refurbished. Is there some kind of firmware update that I should know about? I recall reading something about a video issue with the Denons, even when HDMI was set for pass through, and that whatever the issue was (clipping whites?), it was fixed with a firmware update. My worry would be that I get a receiver that needs that firmware update, but I'm screwed because I have to pay for shipping to get that update (thereby nullifying any savings from getting a refurbished unit).
Just a FYI, J&R had these for under $300 bucks and not refurbished. I got a demo from a local store for less. I hope no firmware date is needed.
Dynaudio,Magnepan,Hegel, Musical Fidelity,Belles and KEF, etc...... Maybe New Belles Aria Int. Amp as far as equipment goes and for speakers the: Contour's 20's or Raidho next...
Charter Member - E.S.A.C. (Eastern Shore Audio Collective) http://www.esac.club/index.php
Kanso Audio Stand's http://kansoaudiofurniture.com/
Garman is offline
Old 02-18-2012, 01:51 PM
dc_519's Avatar
Quick questions everyone...
Is there a quick and easy way to refresh content when connected to a media server?
dc_519 is offline
Old 02-18-2012, 03:04 PM
jdsmoothie's Avatar
Liked: 5511
Issues with a cable box are quite common (with any brand) and can be worked around by bypassing the AVR with HDMI to the TV and optical to the AVR. Issues with the PS3 are less common and video issues are usually resolved by setting the Deep Color Output to OFF as you have already done. You may want to try replacing the HDMI cables for both sources as well as connecting each source to each of the HDMI inputs on the AVR to see if one works better than another.
Old 02-18-2012, 04:48 PM
lou99's Avatar
Now that I purchased a refurbished 2312, Its hard to tell if the unit is defective. The cable company has already told me they can't help further.
Using HDMI+Optical for every device isnt an option because I dont have enough optical ports.
I was also told that all high-speed HDMI cables are the same and it shouldn't matter. Herm...
Anyway, changing the cable didnt help; the screen either flashed solid green, or snow/black.
I'm now working on a return... but am skeptical of going Denon again and ending up in the same spot.
My Cablebox is a Samsung HMT-8272 if that helps.
lou99 is offline
Old 02-18-2012, 05:02 PM
Raferx2's Avatar
I have a new Denon AVR 1912 hooked up to two old Tannoy 611s and some no-account old tiny Cambridge speakers for surrounds and a Sunfire sub. No center speaker. I know it's a Frankenstein setup, but it's what I got.
Problem: In 5.1 video, while imaging is great -- dialogue sounds like it comes straight from center -- center volume is too low. Dialogue is hard to hear when music and effects are just right.
I could buy a center speaker, but I can't find a 611 center anymore. I don't really want to replace the 611s with a new surround setup (I love the Tannoys, and can't afford to replace them anyway). If I get a center from another vendor, will Audessey be able to balance it out so it sounds good?
Or is there a way to fix the phantom center level? I've tried all the movie "modes" and all they have the same volume problem. Dialogue sounds great in multi-channel stereo, but then it's not exactly localized right, obviously.
Thanks AVSF gurus.
Raferx2 is offline
Old 02-18-2012, 05:39 PM
jdsmoothie's Avatar
Liked: 5511
I wasn't suggesting for "every" device, rather only the cable box. As I said, PS3's generally don't have issues with Denon AVRs.
Not true. The quality of the cable matters.
Old 02-18-2012, 05:42 PM
jdsmoothie's Avatar
Liked: 5511
Thanks AVSF gurus.
When movies/TV make up the majority of your listening, you will be much better served with a dedicated center speaker of equal quality to the front mains and ideally from the same mfr; however, if not, Audyssey will still do a good job at EQing it in your environment.
Old 02-18-2012, 06:51 PM
miky702's Avatar
I haven't shopped for a new receiver in 3 years. Is 565 a good price for a refurb 3312 from macmall? Thanks.
miky702 is offline
Old 02-18-2012, 09:19 PM
mikeyraw's Avatar
for my sub it says LPE TO LFE 120HZ....is this about right, or way off?.......this was after i ran auto setup.....1612.......
PSN ID - MikeyRaw8
mikeyraw is offline
Old 02-18-2012, 10:21 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Originally Posted by batpig View Post
mikeyraw: http://batpigworld.com/fadq.html#audyssey
Originally Posted by mikeyraw View Post
thank you sir
so when you said "thank you sir" was that just to acknowledge receipt? because if you had read it, how could you have missed the "What's the deal with the "LFE" setting?" question right?
.... bustin' your chops a bit. 120Hz is the correct setting.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 02-18-2012, 10:34 PM
dgeralds's Avatar
I have a Sony BDP-S380 hooked up to AVR2312 via HDMI. Whenever I play audio CD there is no sound (audio) and I have to switch the INPUT SOURCE and switch back in order to get sound (audio). But have no issues while playing DVD or Bluray disc.
Please help!
dgeralds is offline
Old 02-18-2012, 10:36 PM
lou99's Avatar
Ill look into replacing the refurb 2312. Thanks!
I have a different question:
With the Onkyo 607, I had the ability to lower the "Bass" to -2. I cant seem to find this setting in the 2312. Although - I can find them for Zone 2.
lou99 is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
