The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 323 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 03-04-2012, 06:25 PM
wjbertrand's Avatar
When looking at my Audysey settings there seems to only manual and off as choices. I don't see any indication on my 2112ci that Audysey is engaged. I think it's supposed to show something like auto or XTEQ or something? Do I need to restore from back up?
-Jeff-
Ventura, CA
Panasonic TC-P60S60, Denon 2112ci, Panasonic DMP-BD86, Polk PSW-10 sub, Klipsch flool standing (front) and surround speakers, speaker factory kit center speaker, Toshiba DVD-VHS dubbing player/recorder, Apple TV, Sony turntable, Direct TV DVR
wjbertrand is offline
Old 03-04-2012, 06:41 PM
poochpa's Avatar
Quoted: 45 Post(s)
Thanks for the suggestion JD. I tried resetting the remote, but it didn't help. For those of you with a 1912 remote, is it normal for your "M" light to flash about 7 times when you press, for example, the volume buttons? Thanks.
Mike
poochpa is offline
Old 03-04-2012, 07:21 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
If the only choices are OFF and MANUAL then there is no Audyssey calibration saved. Either run Audyssey or restore from a saved config file.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 03-04-2012, 07:46 PM
phoreverphantom's Avatar
Hey everyone. Just wanted to say this is a great forum, I've never seem so many individuals willing to help so many newbies.
In that regard, I seek some guidance . I have refurb 1712 that did not come with the remote control. I had a couple universal remotes laying around, so it didn't bother me much at the time. After programming, the remotes work for basic commands, but are lacking when I need to do other things. For example, going to the previous screen while in the menu gui.
My question is, do you guys recommend buying a replacement Denon remote or is there a universal remote that is recommended that'll have most of the commands I need to perform more advanced maneuvers? Also, what are the best prices for each (original or universal, whichever is recommended)?
phoreverphantom is offline
Old 03-04-2012, 07:53 PM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
Mike
My 1912 remote only flashes M once with each keypress.
Maybe the batteries are dead?
Check for a stuck button too.
doctorwizz is offline
Old 03-04-2012, 08:12 PM
IowaYankees's Avatar
Hi all-
I am having issues with the Denon 1912 and it seeing the media server. My PC identifies the Denon on my network, I have sharing checked off but anm dumbfounded as to why when I try to play anything it says the media server is 'empty'. It can play internet radio just fine. I must not be doing somethinig correctly but not sure what it is. Can anyone direct me to a simple set-up on the net or share with me another step?
IowaYankees is offline
Old 03-04-2012, 08:30 PM
candy76man's Avatar
I recently got a refurb denon 1912 (to replace my onkyo606 due to the hdmi daughter board failing) and am very happy with it except for one annoyance.... The volume control..... If I hold down the volume button it goes up or down way to fast and always overshoots the volume level I want by a good margin, but hitting the volume button repeatedly to go one notch at a time is way too slow. I am using a harmony one remote but the volume "speed" is the same when using the factory remote.
Has anyone else noticed this? Is there anyway to change it aside from denon possibly doing something about it in a firmware update?
thanks!
candy76man is offline
Old 03-04-2012, 08:33 PM
doctorwizz's Avatar
Quoted: 730 Post(s)
Liked: 229
thanks!
Same here on my 1912. I'm pretty sure it is normal. It is like acceleration.
Old 03-04-2012, 08:39 PM
candy76man's Avatar
Yeah, exactly...but it accelerates way too fast and I always end up way too loud or way to quite if I hold down the volume button, but to get where you want without holding the button down you have to hit the volume button 10 plus times to make a significant change in volume which is tedious at best
Old 03-04-2012, 08:49 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
Get the Harmony 650 for $50 that does everything Denon remote does plus lots more.
tvuong is offline
Old 03-04-2012, 08:54 PM
pbets's Avatar
Just picked up the 1312BA package and being very new to the wonderful world of receivers I am not clear on a few of the receivers settings. Please feel free to laugh as I really am guessing as this thing has no auto setup ..advice would be greatly appreciated.
1) Speaker Setup>Bass Settings>LFE
* I've set this to 150Hz based on the Boston Acoustics MCS 160 manual recommendation for subwoofer crossover value.
2) Speaker Setup>Crossover Frequency>Front/Center/Surround
* I set all these to 120Hz based on the speakers specs for frequency response being 120Hz-20kHz
3) Speaker Setup>Channel Level>Test Tone Start
* I used a dB meter app on my phone(lol) to get a ballpark and tried to match values from the ideal seating position.
pbets is offline
Old 03-04-2012, 09:13 PM
ShapS's Avatar
Quoted: 12 Post(s)
Apparently, they don't listen to their customers cause this has been a complaint for years. I absolutely hate it. I've had my unit for a good while now and hate the volume control just as much as day one.
No idea how they think this method of acceleration is a good thing.
ShapS is offline
Old 03-04-2012, 11:19 PM - Thread Starter
batpig's Avatar
Liked: 3415
Denon volume controls have worked this way for years and years. It's actually very easy and useful once you adapt to it. Just learn, don't fight it
think of it like a 2-speed gear.... if you hold it down it goes *fast*, for gross changes... if you tap-tap-tap, it goes slow, for fine tuning. The key is to get the "feel" so that you don't hold down the volume button for too long. It takes a split second to shift into high gear, so if you press it, go "hmmm, nothing's happening" and then keep mashing it, you will overshoot. But that's because you are holding too long, you have to anticipate the change and release a little quicker. If you get the feel, it's very easy to quickly make a big jump to get in the ballpark of where you want to go, and then tap-tap-tap to fine tune if perfectly.
Setup Guide and FAQ
batpig is offline
Old 03-04-2012, 11:21 PM - Thread Starter
batpig's Avatar
Liked: 3415
since the 1312 model doesn't have Auto Setup, you have to do this stuff manually. You are basically on the right track, honestly. The only thing you should do is lower the LFE low pass (LPF) down to 120Hz. It is NOT a crossover, the crossover is the thing you set in (2) above.
you should check out my website and read through the setup guide and FAQ. I discuss proper manual setup so even though you don't have Audyssey you should learn a lot.
Setup Guide and FAQ
batpig is offline
Old 03-05-2012, 12:37 AM
ReSultZ's Avatar
Quoted: 81 Post(s)
Liked: 35
By using the HDMI as a video pass-through is there a way to have the AVR NOT mess with my tv's video settings IE color etc?
Also when using pandora I can't seem to be able to see the settings on my TV screen, but can see them on the AVR.
I'm using the 3312IC
ReSultZ is offline
Old 03-05-2012, 04:43 AM
NuSoardGraphite's Avatar
Quoted: 326 Post(s)
Liked: 298
I have a 1912 and I can only see the Network settings and internet radio menu etc when the source input is set to an analogue input.
I do see some information that comes up via HDMI input source, but for some reason I can't see the network stuff.
Stand tall and shake the heavens...
NuSoardGraphite is offline
Old 03-05-2012, 04:50 AM
SoundofMind's Avatar
Liked: 166
Originally Posted by Brian Fineberg View Post
Should I just keep the avr in stereo mode for music? Can anyone suggest dts: neo or anything for iPod music?
I suggest you try both Neo:6 Music and DolbyPLIIx Music to see which you prefer. Neo:6 emphasizes the front soundstage with sparing use of surrounds for ambiance; I also like its balance of CC to FR/L. Restorer HQ improves compressed files including adding some dynamics back in. Of course for all music, unless you actually want to compress the dynamic range, keep DVol off. For ex., MultiCh Stereo works well with DVol on Midnight for dinnerparty background music-it keeps it audible but never too loud. MultiCh Stereo also works for party dance music with DVol off, if you have decent surrounds and crank it up it simulates a disco, but without all the artificial reverb of some of the other DSP modes.
On the other hand, for critical listening of high quality music sources I listen in native format. Music that is mixed MC is cool in the HT.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 03-05-2012, 07:57 AM
lopro's Avatar
I have the 1912 US version.
I'm getting very intermittent results with my AirPlay. Sometimes my iTunes just doesn't see the Denon. Othertimes it works great and will even power on my Denon when I play a song from my laptop via iTunes.
Is anybody else getting this intermittent problem with AirPlay? What is it and how can it easily be resolved? Maybe it has something to do with switching networks between home and office? Even when I reboot my laptop and restart my router (1st gen. Apple Time Capsule), I still don't see AirPlay.
It always inevitably occurs whenever I have guests and want to just play some music from the laptop very quickly. Then I'm stuck with Pandora or the FM tuner which pretty much rocks...I mean sucks.
lopro is offline
Old 03-05-2012, 08:03 AM
wjbertrand's Avatar
OK thanks, wonder where the settings went?? I tried loading the config.bat file I'd saved, but the receiver hung at "loading" for over 30 minutes so. I gave up on that and re-ran the Audyssey set up all over again. Got the expected sound back again!
-Jeff-
Ventura, CA
Old 03-05-2012, 08:37 AM
mccafjohn's Avatar
How is your Denon connected to the LAN?
I can't offer any advice about resetting the processor, but my set up has been working very well and has only dropped out once in 6 weeks.
I use an AirPort Express "N" set to extend the network. My 1912 is plugged directly into the ethernet port on the APEx. As the crow flys it is about 50' from my Airport Extreme through several walls in a condo with neighbors on either side. (sans interference issues). I can see my Denon from any computer, iPhone, or iPad in the building.
My only suggestion would be to look at how you are connected to your LAN and troubleshoot from there.
Denon 1912
Polk audio in a 6.1
Samsung 55"
mccafjohn is offline
Old 03-05-2012, 09:35 AM
Benny42's Avatar
What the others wrote, but:
First of all your Harmony isn't at the same speed as the Denon remote. It actually lags, meaning there is a noticeable time span between pressing the button and sending out the IR signals. Compare it with your Denon remote (or any other "primitive" remote) by pointing the remote at a point&shoot camera to make the IR signals visible!
You can set the key delay to 0 ms in the Harmony setup but you will still have some overhead resulting in lag (even with the most recent Harmony firmware).
Secondly, the Harmony buffers each button press and if you keep a button pressed down it - of course - repeats. This is actually a good and necessary feature but when combined with the lag may require you to learn the right timing as you will otherwise overshoot the volume setting.
There are several solutions to your dilemma:
- Logitech changes the Harmony One firmware (very unlikely as it is pretty old already and Logitech never admitted to this problem, but perhaps there will be a faster One successor some day? I would pay for this...)
- Denon changing their volume controle behaviour (not likely, especially with current models)
- You adapt to the "optimal timing" (most likely ;-))
bye
Benny
Benny42 is offline
Old 03-05-2012, 09:37 AM
dkushner's Avatar
My brand new 2312CI has the same buggy and unreliable behavior with Airplay, and most of the functions in the Net/USB input. I experience lags, and just plain buggy behavior in general. Pandora freezes, button presses are often unresponsive or return you to the incorrect area. I'm convinced that quality control in this area leaves much to be desired.
I happen to be the software testing manager for a software company and have significant troubleshooting experience in general so maybe I'm sensitive to defects and unreliable behavior. This is my first Denon purchase and overall I'm disappointed with Denon's quality control. Many companies lack in this area and I was hoping a brand like Denon would be better than what I've personally experienced.
dkushner is offline
Old 03-05-2012, 10:47 AM
johnwjames5's Avatar
Originally Posted by johnwjames5 View Post
I have a 2112CI that I think might have taken it in the shorts. I'd done some reading here and had decided to use the HDMI standby pass-through for the cable DVR, ran the cables right, got it working (in a manner of speaking), and then found two oddities. One was that I could never set the default HDMI port for the HDMI Control option while using the web-based forms: I'd select it, and it would always bounce back to Last. The second oddity was that as soon as I turned this option on, I found that the AirPlay would play fine - once. As soon as I paused output from iTunes, any attempt to restart playing, or play another day, etc would give a message in iTunes that the remote device was in use, and the only way I could clear this error was to unplug the Denon and plug it back in after a few secs.
I was going to reset the microprocessor tomorrow when I felt like it, but tonight I turned things on to watch a movie, and the settings were odd and I couldn't get sound out of the unit. I decided now was the time, and since resetting it, I get stuck in the Setup Wizard menu, told to press Enter to start, and the unit does not respond to Enter or most of the rest of things pressed on the remote. Yes, I'm on the right zone, and I can turn the unit on and off from the remote, but I can't do anything else to drive through setup.
Any other ideas to see if this unit can be resurrected without sending it back for servicing?
Not that I seem to understand a lot else about this device, but before taking it to an authorized service center today, I decided to just poke on things one more time. Letting the unit sit for a couple of days seems to have changed something, and today the unit responds to commands from the remote. Rather than go through and set everything up again, I thought maybe I'd try reloading the config.dat file I'd saved a day before everything went to hell. One thing that is not clear from the instructions or anyplace I can seemingly find is whether or not the unit should be on or in standby mode when I use the web feature to start reloading the configuration. I ask because I've selected my config.dat file, and said to upload, but it's been sitting for 15 minutes or so, and there is no "Loading" on the front display, so I'm not sure anything is really happening. It's not uncommon for the Denon instructions to be vague, so I don't know if I should have had the unit on to see "Loading" or if the process is really taking place, and I'd rather not stop it if I'm just a minute or so from finishing.
Any general clues on this? Should I have started with the unit on or in standby? Does it just miraculously finish without feedback sometimes? I did try to crawl the thread some before posting this, but I just wasn't finding a hit, nor was I able to find anything starting from Google and pointing into the forum. Thanks.
johnwjames5 is offline
Old 03-05-2012, 11:07 AM
lopro's Avatar
My Denon is connected directly to my Time Capsule (router) with ethernet cable. And, I've reset the Denon processor a few times since I've had this setup. The reset doesn't seem to affect the missing AirPlay in iTunes. Had issues before reset and after reset.
It seems like an Apple/iTunes problem to me, but not sure.
lopro is offline
Old 03-05-2012, 02:29 PM
ReSultZ's Avatar
Quoted: 81 Post(s)
Liked: 35
^ So Pandora won't show up on screen digital...is that what you mean?
How about setting the AVR to NOT change or add your any changes to your tv picture settings? Cause when I look at the video status,it says movie.
ReSultZ is offline
Old 03-05-2012, 03:25 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Thinking of adding an amp. I have a 2312ci. Anyone recommend an amp that will match up for fronts? Thanks
Reefdvr27 is offline
Old 03-05-2012, 03:32 PM
ccotenj's Avatar
Liked: 101
good thing you are only thinking about it, because the 2312 doesn't have pre-outs...
you'd have to use a speaker level to line level converter in order to add an amp...
you going into protection and/or clipping? if not, don't bother...
- chris
ccotenj is offline
Old 03-05-2012, 04:00 PM
Canary_Jules's Avatar
Hi, I'm thinking of upgrading from my AVR-1909 to one of the newer models as I will need 3d capability with my new Sony VW95ES projector. So, obviously the AVR-1912 is the direct equivalent today. Obviously this has more features than my present receiver, but would I notice any improvement in the sound itself? I also have the option of upgrading to an AVR-2312 - which is also at a great price right now. This has a few more features than the AVR-1912 but will the AVR-2312 receiver actually ultimately sound any better? And am I any better off still with the Denon over say an equivalent Onkyo? Movie watching is my main priority.
FYI, I have a BK XLS200 sub, Teufel Ultra 2 certified dipole surrounds, Wharfedale Diamond 8.3 floorstanders, Wharfedale Diamond 8.1 centre and Wharfedale Diamond 7.1 rear surrounds. It's my plan to gradually upgrade from the Wharfedales to matching Teufels.
I appreciate your advice.
Canary_Jules is offline
Old 03-05-2012, 04:06 PM
spager's Avatar
I would rerun Audyssey if it doesn't work and their is an issue get it repaired and be done with it. If it works, problem solved and move forward. After you rerun Audyssey save a fresh Settings and get rid of the old config.
Yes when you save and load leave amp on. It will shut down and restart by itself.
spager is offline
Old 03-05-2012, 04:34 PM
tvuong's Avatar
Liked: 875
If you can get the 2312, buy it as it has a better Audessey bersion than the 1912. You can also get the 2112 for $450 which has Audessey MultiXT like the 2312.
tvuong is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
