The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 332 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 03-14-2012, 06:17 PM
ccotenj's Avatar
Liked: 101
it does not... to do that, you need xt32, and would need to step up to the 4311...
- chris
ccotenj is offline
Old 03-14-2012, 06:36 PM
jw00dy's Avatar
Quoted: 20 Post(s)
Thanks Chris. 4311 isn't in the $$ cards. I think I'll stick with my Pio.
RBH Sound: R55Ti x 2, R56Ci x 1, R5Bi x 4
Infinity Primus: P162 x 2, PC351 x 1, P152 x 2
Pioneer VSX-1120K, BIC PL200
jw00dy is offline
Old 03-14-2012, 06:46 PM
ps24eva's Avatar
Quoted: 37 Post(s)
I have ripped movie files with 2 channel mp3 sound.
But PLII Cinema won't process it???
ps24eva is offline
Old 03-14-2012, 07:09 PM
cxg331's Avatar
1. Correct. Generally you'll only want to use Dyn Vol when watching TV (for loud commercials) or late at night, otherwise normally you'll want it OFF for movies. Dyn EQ provides a bass/surround boost at lower volumes below 0db.
2. Press the "Movie" or "Music" button on the remote and select STEREO.
3. Correct.
4. If your towers have a powered subwoofer, you'll want to connect the sub preout to a "Y" splitter and connect to both of the sub coax digital inputs and rerun AUTO SETUP so sub gets set to YES.
Thanks for the answers. My towers don't have powered subs, but thanks anyway.
Last question for now: does using banana plugs have an effect in audio, or is it simply a matter of ease of use when hooking everything up?
cxg331 is offline
Old 03-14-2012, 07:20 PM
jdsmoothie's Avatar
Quoted: 12181 Post(s)
Liked: 5549
The latter.
jdsmoothie is offline
Old 03-14-2012, 07:23 PM
jdsmoothie's Avatar
Liked: 5549
What does the front panel display read when the audio file is playing?
Old 03-14-2012, 07:37 PM
ps24eva's Avatar
Quoted: 37 Post(s)
It says PLII Cinema.
But only the center channel will pump out sound.
I guess PLII Cinema wasn't designed to be used on MP3 (since MP3 is typically used for music).
ps24eva is offline
Old 03-14-2012, 07:38 PM
jdsmoothie's Avatar
Liked: 5549
It should work on 2CH audio which is why it's displayed on the front panel. Are you sure the track was ripped correctly? Try PLII - Music and see what happens.
Old 03-14-2012, 07:46 PM
ps24eva's Avatar
Quoted: 37 Post(s)
PLII Music works ok.
Keep in mind this is mp3. You sure PLIIcinema should work on mp3?
ps24eva is offline
Old 03-14-2012, 07:52 PM
jdsmoothie's Avatar
Liked: 5549
Its 2CH audio so it should, although I don't work with MP3 audio so cannot confirm.
Old 03-14-2012, 08:15 PM
ps24eva's Avatar
Quoted: 37 Post(s)
I don't know what is going on then.
ps24eva is offline
Old 03-14-2012, 09:09 PM
laklog's Avatar
This is probably a dumb question but does anyone know of any trick/workarounds that will allow me to extract the center channel line out signal on a 1712 which only has a subwoofer pre out? My Mits DLP provides a line in connector to allow you to use the TV speaker as a center channel. I realize I could interpose some kind of HDMI audio extractor to the HDMI out prior to sending it to the TV but I am worried that it might degrade the video.
I assume there is no "box" that will take an amplified speaker output and "deamplify" it to a line signal.
laklog is offline
Old 03-14-2012, 09:55 PM
vv132's Avatar
Originally Posted by vinceisvince View Post
http://www.audyssey.com/blog/2009/05/small-vs-large/
Check out that link!
Also -5db is extremely loud for me and your channel levels seem quite different than mine.. is anything set to zero? Otherwise it seems like something is wrong being at -5db for a good volume level.
Hey i set my towers to small, turned off dynamic , audio is fine i guess just doesnt get real loud as i thought it would be able too. streaming music from itunes sounds pretty good. But i dunno about my levels, i do only sit 7-8ft away from my 55 inch
vv132 is offline
Old 03-14-2012, 11:08 PM
Odys's Avatar
I'm a new 2112 owner and I can't get a true surround signal. I'm testing with a BD on my PS3 and I've selected DTS-HD Master Audio. All I'm getting is stereo modes on the 2112 (MCH Stereo, PLII, etc.). How do I select true multichannel? My old Onkyo had a Multichannel button on the remote. I feel like an idiot asking this, but I've literally spent hours with the manual, remote and this thread. I've tried both PCM and Bitstream on the PS3.
Odys is offline
Old 03-15-2012, 12:42 AM
cistearns's Avatar
Make sure the HDMI-CEC settings on each device haven't changed. Also to increase the number of optical inputs on the AVR, you can add an optical splitter.
I made sure the HDMI-CEC is on on all devices. That was actually the first thing I did (and rechecked after the resets). Unfortunately that didn't help. I'm inclined to believe that the HDMI board has a fault, but still going to try any other suggestions.
(For my one other device I'll probably just use a optical-coax converter to use the other digital input, still given the prevalence of optical audio I wish Denon would include more than one on all the receivers)
cistearns is offline
Old 03-15-2012, 05:00 AM
gibsonpa's Avatar
Just installed some Energy 6C heights last night (thanks to batpig over on the Energy forum)
Quick setup question on my Denon 2112:
From reading many posts...I did the amp assign to "front heights", Audy recognized and measured. Fired up a blu-ray, then went to "surround mode" and set PLz front heights=on (gain=middle,lfe=0,cinema=off). I was expecting to see "DTS-HD MA + PLiiz" on the Denon 2112 display. Instead it showed "DTS-HD MA" with a small "PLII" icon above...no PLiiz was displayed anywhere. Is that what you would expect? Also, I am guessing the lfe=0 and cinema=off are ok. I am assuming the "surround mode" is "sticky" and I won't have to do for every bluray.
Any help would be much appreciated.
Thanks!!
gibsonpa is offline
Old 03-15-2012, 05:11 AM
jdsmoothie's Avatar
Liked: 5549
It appears correct based on what is shown in the Owner's manual. Your other settings are correct as well.
Old 03-15-2012, 05:13 AM
jdsmoothie's Avatar
Liked: 5549
The PS3 is only passing a 2CH signal. Reset the PS3 by powering on pressing/holding the ON button for longer than usual until you hear a series of beeps.
Old 03-15-2012, 05:29 AM
ccotenj's Avatar
Liked: 101
google "speaker to line level converter"... you'll find a bunch, the car audio guys use them all the time...
you'd be MUCH better off just using a center speaker though (rather than using the tv as one)...
- chris
ccotenj is offline
Old 03-15-2012, 05:30 AM
ccotenj's Avatar
Liked: 101
as pliicinema is "post processing", it would have no way of knowing the original source was a mp3... by the time it gets to the post processing routines, it has already been converted to pcm...
- chris
ccotenj is offline
Old 03-15-2012, 07:56 AM
Odys's Avatar
Thanks, that did it!
Odys is offline
Old 03-15-2012, 08:59 AM
EricST's Avatar
Quoted: 67 Post(s)
Liked: 45
Has anyone recently called online dealers and gotten a better price then MSRP?
60" Samsung KS-8000
Oppo 203 UHBD
Denon 2200X receiver
PSB X series 5.2.2
SVS Dual PB-1000
The Force will be with you ...always.
EricST is offline
Old 03-15-2012, 09:29 AM
LVS
LVS's Avatar
^^^ Call avscience
LVS is offline
Old 03-15-2012, 09:45 AM
LSU fan's Avatar
I found the best price at Electronics Expo. I'd call them, J&R, and AV Science. All were much less than MSRP.
LSU fan is offline
Old 03-15-2012, 11:08 AM
cenvalycali's Avatar
I'm getting in the Denon 1712 today and I had a quick question. I have 2 surrounds that are 4 ohmn but the rest of my speakers are 8 ohmn. Will the 1712 have any problem powering and making the 4ohmn speakers work? And can I mix ohnm like I plan?
cenvalycali is offline
Old 03-15-2012, 11:29 AM
EricST's Avatar
Quoted: 67 Post(s)
Liked: 45
SCORE!
Just got 2112 brand new in box for $481.49 Thanks for the advise on calling them!!!
60" Samsung KS-8000
Oppo 203 UHBD
PSB X series 5.2.2
SVS Dual PB-1000
EricST is offline
Old 03-15-2012, 11:32 AM
jdsmoothie's Avatar
Liked: 5549
Yes you can mix as you plan. Surrounds require very little power.
Old 03-15-2012, 11:41 AM
gibsonpa's Avatar
Thanks Jdsmoothie! For some reason, I thought the "+PLiiZ" was supposed to be on the main display when I read the manual...but guess it is just the small icon on the display. Thanks!!
gibsonpa is offline
Old 03-15-2012, 11:45 AM
BeachBoys1's Avatar
Originally Posted by cistearns View Post
Has anyone else had problems with HDMI-CEC stop working completely? I have a 2112 and the my Sony TV just stopped seeing the Receiver for control and ARC, it has been working fine. The TV is also unable to see the Blu-Ray player connected to the receiver, this was working as well. If I directly connect the Blue-Ray to the TV it sees the player, which is why I think the problem is with the receiver.
I'm inclined to think it is a hardware problem. The only change I made prior to it stopping function is connection of an IR repeater (Harmony 900) directly to the back panel. This was working fine though.
I have tried:
Factory reset of the TV.
Reset the receiver CPU.
Disconnecting everything including unplug from power. Then only connecting the receiver to the TV with no other HDMI devices in to the receiver.
I've exchanged PM's with jdsmoothie and cistearns concerning this issue.
I have a new Denon 3312ci receiver hooked up to a new Sony 55HX929 TV via HDMI ARC. I hooked a new Blu-ray player up to the Denon, and was watching a movie for the first time when the Denon crapped out. Just turned off for no reason. Then the unit would only power on to "TV Stereo" with no sound or video, and wouldn't go into Standby mode (red ring around power button). After trying the "soft reboot" by unplugging the Denon and Sony power cords overnight and unplugging/re-plugging in and verifying all of the HDMI cables and speaker wire connections, I reset the CPU (Denon default settings restored). Then I couldn't get the OSD to come up, so I could set "HDMI Control" on the receiver to "On". Seems to me like "On" should be the default setting! I even reset the remote per instructions. The Sony TV HDMI-CEC settings look OK (tried setting on and off). I have one HDMI 1.4 cable between the HDMI ARC output of the Denon to the HDMI ARC input of the Sony, and a Panny 210 Blu-ray player hooked to the "BD" HDMI port in the back of the Denon. That's all I have!
I'm thinking that maybe the HDMI board in the Denon is not very robust. I've asked Electronics Expo to RMA the unit and exchange it for a new one, so we'll see what happens. Film at 11.
I find it interesting that Denon says that with 80% of units returned for repair, they cannot find any fault with them. I would REALLY like to know what the root cause of this problem is; if it's something I'm doing wrong or something is up with these xx12 units. Two times is the charm - if it happens again, I think I'll look for another brand receiver. Up until now, I've really liked this 3312, though, and would prefer to keep it. But........
BeachBoys1 is offline
Old 03-15-2012, 11:54 AM
jdsmoothie's Avatar
Liked: 5549
Sure. The manual isn't always correct.
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
