The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 334 - AVS Forum | Home Theater Discussions And Reviews
 289Likes
post #9991 of 20263 Old 03-15-2012, 09:39 PM
Anodyne's Avatar
This is likely an HDMI handshake issue. Try turning on the TV first, wait a few secs, turn on the AVR, wait a few secs and then turn on the Wii. If you're not using HDMI Control or VierraLink on the TV, try setting them to OFF.
You know what, now that you mention it, this whole problem started after I turned on HDMI-CEC. But I have to have it on in order to use Netflix and ARC from the Panasonic ST30 (at least from the troubleshooting I did to get that to work). Hmmm. I'll try the series of turning everything on as you described and see if I can get the Harmony to pause long enough to allow it all to work that way....
Anodyne is offline
post #9992 of 20263 Old 03-15-2012, 09:42 PM
jdsmoothie's Avatar
Quoted: 15323 Post(s)
Liked: 7477
Perhaps ... but you don't need the feature ON when using the Wii.
jdsmoothie is offline
post #9993 of 20263 Old 03-15-2012, 09:44 PM
Anodyne's Avatar
The HDMI-CEC is definitely overriding how I turn things on (TV and AVR come on and turn off at the same time... which is how it's supposed to work, I guess... but still annoying in this case).
Is there a way to get the HDMI-CEC to be input-dependent? In other words, can it be off when the AVR is set to Sat/Cbl and on when it's set to a different input?
Anodyne is offline
post #9994 of 20263 Old 03-15-2012, 10:00 PM
cenvalycali's Avatar
Try following the instructions on pp. 75-76 in your Owner's manual.
Read the AUTO SETUP section in post #3 linked in my sig.
Just read over auto setup and it looks like maybe I will go without the Dynamic sound for now until I get a Sub. I still need to download the owners manual. Hey I really appreciate your help. My setup sounds alot better already.
cenvalycali is offline
post #9995 of 20263 Old 03-15-2012, 11:12 PM
Any special setup for htpc? I get video fine but no audio. Htpc is setup through a sewell hammerhead. vga, hammerhead, audio from headphones into hammerhead, hdmi out of hammerhead. The setup will send audio and video to my tv without a problem. Should I send the audio from the computer to the avr with just an audio plug? If I'm not explaining it right ask questions. Thank you.
Adam
post #9996 of 20263 Old 03-16-2012, 02:09 AM
Kutis's Avatar
I was reading AUTO SETUP instructions in beginning and now I'm wondering why Audyssei sets my Wharfedales 9.2 to SMALL @50hz. How to change crossover freq and still run with Audyssei mode -"Audyssei"? Or can I run Audyssei mode "Manual" and EQ setting from Autosetup are still valid?
Kutis is offline
post #9997 of 20263 Old 03-16-2012, 04:21 AM
jdsmoothie's Avatar
Liked: 7477
No, it is a global setting. You should be able to program the Harmony to disable HDMI-CEC on the TV when using the Wii.
post #9998 of 20263 Old 03-16-2012, 04:31 AM
jdsmoothie's Avatar
Liked: 7477
Adam
THe converted signal may be to strange for the AVR to process. Try every HDMI input on the AVR. If still no joy, then go the separate audio cable route.
post #9999 of 20263 Old 03-16-2012, 04:34 AM
jdsmoothie's Avatar
Liked: 7477
Simply raise the crossover from 50hz to 80hz and you're good to go.
post #10000 of 20263 Old 03-16-2012, 04:59 AM
Kutis's Avatar
Sorry for being thick headed but which is the correct menu path to do that?
I've found 2 channel/stereo settings which I've updated to my preference but seems like I can only change crossover when Audussey is set to 'Manual'. Is that correct or am I missing something here? It's european 1912 BTW.
Kutis is offline
post #10001 of 20263 Old 03-16-2012, 05:56 AM
jdsmoothie's Avatar
Liked: 7477
Might be a little different on your EU unit, but close enough to the below to get you there ...
System Setup ---> Speaker Setup ---> Speaker Config ---> Crossover Freq ---> Advanced
post #10002 of 20263 Old 03-16-2012, 07:08 AM
jfriedmann's Avatar
Does anyone have a solution for the Firmware Update "hanging / stopping" on the Authenticating Stage?
I've left mine for 30+ minutes, and it just stays there.
jfriedmann is offline
post #10003 of 20263 Old 03-16-2012, 07:25 AM
jdsmoothie's Avatar
Liked: 7477
Have you tried resetting your router? Connecting directly to the router if wireless (as recommended in the manual)? Unplug the AVR for a few minutes? Reset the microprocessor?
post #10004 of 20263 Old 03-16-2012, 08:05 AM
Superman07's Avatar
Quoted: 87 Post(s)
Liked: 26
Denon has progressively reduced the number of analog legacy inputs as well as dropped the external inputs and multi channel preouts from the lower/mid level models below the 331X series most likely as a cost cutting factor as the vast majority of the public buying this level of models won't need to use an external amp. Unless you are in a very large room or like to listen at very loud volumes, you likely wouldn't need an external amp with those speakers either; however, if you are considering preouts at all and don't want to go to the 331X series, consider the Marantz lower models as they generally feature FL/FR preouts at a minimum.
Thanks for the reply. Is there an advantage and/or large disadvantages in going with brands like Marantz, Anthem, Pioneer Elite etc aside from auto room correction choices (assuming not Audessey, but I didn't look yet)?
Superman07 is offline
post #10005 of 20263 Old 03-16-2012, 08:28 AM
jdsmoothie's Avatar
Liked: 7477
You're going to have some that prefer one brand over another, but in the end it's mostly based on which Auto EQ might be preferred (if demo'd at all) and what features a particular brand's models offers. For the past couple of years, with a few exceptions, Denon and Marantz AVRs are clones of each other.
post #10006 of 20263 Old 03-16-2012, 08:40 AM
jfriedmann's Avatar
It's connected directly to the router, I could try to connect it directly to the modem?
I've tried resetting the router and also unplugging the AVR for a few minutes with no luck.
How do I reset the microprocessor?
post #10007 of 20263 Old 03-16-2012, 08:50 AM
tvuong's Avatar
Quoted: 1790 Post(s)
Liked: 1086
depends on which model you have. Refer to p.1 to reset.
tvuong is offline
post #10008 of 20263 Old 03-16-2012, 08:51 AM
allsop4now's Avatar
The first few posts in this thread contains a FAQ and there are instructions on how to reset the microprocessor.
allsop4now is offline
post #10009 of 20263 Old 03-16-2012, 08:56 AM
sminyard's Avatar
I posted this in the Speaker section as well:
When I originally bought my Denon AVR-1912, I bought a 5.1 sub/satellite system, which is not making me happy. The satellites are mounted on the ceiling, and they are only able to reach down to 150 Hz. I am planning to buy 2 bookshelf speakers to go beside the TV. Is there any reason that I can't add a speaker selector and use both the satellites and the bookshelf speakers across the front? I realize that the crossover will be set around 80 Hz for the bookshelf speakers, and that the sub will no longer be filling that gap, but will this work?
sminyard is offline
post #10010 of 20263 Old 03-16-2012, 10:18 AM - Thread Starter
batpig's Avatar
Quoted: 3720 Post(s)
Liked: 3592
no, what you want to do is use the ceiling speakers as HEIGHTS and then have a new pair of front L/R mains.
is your center channel up at the ceiling as well? all three primary front speakers (L/C/R) are important so if you get new bookshelf speakers, budget for a matching center as well.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10011 of 20263 Old 03-16-2012, 10:24 AM
sminyard's Avatar
Can I use heights if I also use Zone 2? If not, will the setup I described above work at all?
My center is just above the TV, and I do plan to purchase a new one that matches the bookshelf speakers.
sminyard is offline
post #10012 of 20263 Old 03-16-2012, 10:27 AM
Gregg Brent's Avatar
I just bought the 3312. New to Denon. Was going to get a Pioneer 55 but it didn't fit in my media cabinet.
Anyway did the setup through wizard and all seemed to go well but I notice the volume has to be almost at 0db to reach level I like for watching movies. Is this normal?
There isn't much room on the scale to go louder. Is it just the amp isn't that powerful and need to set the volume at this level? My old Pioneer would only have to be at -15 to be booming. I'm not sure if there is a setting I'm missing, etc.
The speakers I'm driving are the Artison Portraits and surrounds.
Thanks for any info.
Gregg Brent is offline
post #10013 of 20263 Old 03-16-2012, 10:43 AM
jdsmoothie's Avatar
Liked: 7477
Although it would work, doesn't really make much sense to do it that way. You have a choice of either Front Height or powered Zone 2, but not both. If you prefer to keep Zone 2, then don't connect the ceiling speakers. Ideally the front 3 speaker tweeters should be at seated ear height.
post #10014 of 20263 Old 03-16-2012, 10:46 AM
jdsmoothie's Avatar
Liked: 7477
Those speakers are 6Ω so will take a little more power to drive than would 8Ω speakers, and even then for someone that likes to listen at loud movie volume in a medium sized room, the volume can easily approach -5db. Ensure you have your front mains set to SMALL with 80hz crossovers to allow for more available headroom for the speakers. Also note your Pioneer AVR likely had a different volume scale. After running AUTO SETUP, reference volume is set to 0db using the default "relative" volume scale.
post #10015 of 20263 Old 03-16-2012, 10:53 AM
Kutis's Avatar
OK, thanks. I've been there but been confused 'cause Auto setup menu still displays original settings in Parameter check
Kutis is offline
post #10016 of 20263 Old 03-16-2012, 11:01 AM
mdmeo's Avatar
Have a AVR 2112ci and plugged an IPOD touch into USB port. It plays and sounds great, displays on the units display, but no longer displays on the TV (Samsung LED)? It used to work perfectly, but now not sure where the TV GUI went? Thanks for any advice.
mdmeo is offline
post #10017 of 20263 Old 03-16-2012, 11:07 AM
jdsmoothie's Avatar
Liked: 7477
Those settings cannot be changed, rather only indicate what the original AUTO SETUP settings were after the calibration as well as showing what the settings would be should you ever decide to use the RESTORE feature and return to those settings.
post #10018 of 20263 Old 03-16-2012, 11:12 AM
jdsmoothie's Avatar
Liked: 7477
Ensure the iPod is in BROWSE mode (p. 25).
post #10019 of 20263 Old 03-16-2012, 11:14 AM
ccotenj's Avatar
Liked: 101
keep in mind that your new avr needs some room to breathe... how much clearance do you have (top & sides)? is the cabinet enclosed?
- chris
ccotenj is offline
post #10020 of 20263 Old 03-16-2012, 11:21 AM
pulse215's Avatar
I have the same problem with the 2312. Did all the above steps, even connnected to an open network (live in a condo complex) and no joy. I've never gotten a firmware upgrade to work.
Generally no problem accessing my music server, and denon android app works ok so not sure what the problem is
pulse215 is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
