The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 335 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 03-16-2012, 12:32 PM
jdsmoothie's Avatar
Quoted: 12167 Post(s)
Liked: 5545
Does your unit indicate there is a firmware update available? If yes, have you tried setting Network Standby to OFF, turn the AVR off for about 10 minutes, power back ON and then try the update again.
jdsmoothie is online now
Old 03-16-2012, 01:11 PM
pacemaker's Avatar
Quoted: 30 Post(s)
Can I stop Audyssey setting my speakers to large before it does its auto setup?
i prefer the sound in 'small' for all speakers and the sub to do the bass
also i notice the auto setup has the sub at -12 should i turn it down on the sub before running setup to achiave a result of up to -11 to prove its not maxed out?
cheers
pacemaker is offline
Old 03-16-2012, 01:24 PM
ps24eva's Avatar
Quoted: 37 Post(s)
Originally Posted by ps24eva View Post
Was there another firmware update for the 2112 tonight?
I got a firmware update prompt.
bump
ps24eva is offline
Old 03-16-2012, 01:41 PM
jdsmoothie's Avatar
Liked: 5545
cheers
No for the LARGE setting, and yes for lowering the sub gain setting on the sub.
Please refer to the AUTO SETUP section in post #3 --> http://www.avsforum.com/avs-vb/showt...?p=20422026#A2
Old 03-16-2012, 03:04 PM
mdmeo's Avatar
Thanks JD. Always appreciate your help and time! I verified that it is in "browse" mode by pressing and holding "search" and also noting the screen on the ipod is displaying the "denon" logo and "OK to disconnect" screen and not the iPod meta data. From the Favorites screen on the TV GUI I can see network locations and ipod. Once I select the ipod, TV gos black. Volume control still does display on bottom of TV. I have tried a Classic iPod which has worked in the past and also a New iPod Touch which might not be supported, so that might be the issue with the iTouch? Not sure about the "classic" model?
mdmeo is offline
Old 03-16-2012, 05:18 PM
Gregg Brent's Avatar
Those speakers are 6Ω so will take a little more power to drive than would 8Ω speakers, and even then for someone that likes to listen at loud movie volume in a medium sized room, the volume can easily approach -5db. Ensure you have your front mains set to SMALL with 80hz crossovers to allow for more available headroom for the speakers. Also note your Pioneer AVR likely had a different volume scale. After running AUTO SETUP, reference volume is set to 0db using the default "relative" volume scale.
Thanks will check and make sure it's set correct
Gregg Brent is offline
Old 03-16-2012, 05:20 PM
Originally Posted by ccotenj View Post
keep in mind that your new avr needs some room to breathe... how much clearance do you have (top & sides)? is the cabinet enclosed?
it's about 6 inches on top and about quarter inch on sides.. it's open in the back. Should I attach a small fan to the space?
Old 03-16-2012, 05:39 PM
GM4X4's Avatar
Hi,
I've got a 2112ci but would like to turn off Dynamic volume for different sources but when I set Dynamic Volume to off from Evening and change the source to my PS3 and then back to my WDTV the Dynamic Volume is enabled back to Evening. Is there anyway I can turn off Dynamic Volume for different sources or completely off?
GM4X4 is offline
Old 03-16-2012, 06:12 PM
jsl262's Avatar
How do i set the Avr-1912 to receive the audio from my samsung tv. I followed the directions from Amazon video which are a few simple steps. I have set it for external speakers. it instructs me to set AVR to dolby digital. It says stereo on receiver . How do I do set to dolby digital?
jsl262 is offline
Old 03-16-2012, 08:14 PM
Drivingrain's Avatar
Not trying to do a price talk post here, but is there a reason why the 3312CI just got a 20% price drop on particular big retailing website? New model coming perhaps?
Drivingrain is offline
Old 03-16-2012, 09:22 PM
lou99's Avatar
Wrong Thread.
lou99 is offline
Old 03-16-2012, 10:08 PM - Thread Starter
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
Originally Posted by GM4X4 View Post
Hi,
Audyssey settings are memorized by source by default..... but if you use a QUICK SELECT to change sources it will always revert back unless you re-memorize the quick select.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 03-16-2012, 10:11 PM - Thread Starter
batpig's Avatar
Liked: 3420
Can you be clear about how the audio is piped back to the AVR? Is it going back through the HDMI cable (using ARC) or do you have an optical output to the receiver?
Either way, the receiver can only play what you give it. If it says "STEREO" and the input signal is 2.0 (check the GUI and the INFORMATION menu to confirm audio input signal) then that is what the receiver is getting.
So, it sounds like now you are getting 2.0 audio.... there are two possibilities, either (1) there is a setting wrong on the TV that is preventing 5.1 DD audio from flowing out, or (2) that is all that's available (many streaming sources do not have 5.1 audio). Either way, the receiver has nothing to do with it, again it can only play the signal that it gets.
That said, when you get a 2.0 signal, press the MOVIE button to engage PLII Cinema to matrix the 2.0 signal to 5.1. It won't be true 5.1 but the "simulated" mix will still sound pretty good.
Setup Guide and FAQ
Old 03-16-2012, 10:57 PM
Zack Fair's Avatar
Please I need everyone's help! I'm very confused.. I want to buy 2112 or 1912....!
I have right now 2308ci. (700 wts) 5.1
I know both have differences 630 wts 2112 and 875 wts 1912.
2112 Audyssey MultEQ XT Support... less wts than I have
1912 Audyssey MultEQ... more wts than I have
Reason: Upgrade! please recommendations...!!
Zack Fair is offline
Old 03-16-2012, 11:24 PM
tvuong's Avatar
Quoted: 1549 Post(s)
Liked: 878
Don't let the Wattage a decision maker when buying receiver. I do not understand this wattage question keep coming up (not point at you) as i do not even pay attention to it. I dont remember what the wattage on my 2312 and 3312 are? Get the 2112
tvuong is online now
Old 03-16-2012, 11:35 PM
Zack Fair's Avatar
But why 2112.?? and not the 1912..?
Some reason you have.! please..!
Old 03-17-2012, 01:32 AM
jdsmoothie's Avatar
Liked: 5545
Please refer to post #2 on page 1 of this thread for a comparison of the various models. Btw ... the 2308CI is rated at 100W/CH while both the 1912 and 2112CI are rated at 90W/CH. For all intents and purposes, they all provide the same amount of power.
Old 03-17-2012, 05:08 AM
GM4X4's Avatar
"Audyssey settings are memorized by source by default..... but if you use a QUICK SELECT to change sources it will always revert back unless you re-memorize the quick select."
Thanks batpig for the info. I'll try that.
GM4X4 is offline
Old 03-17-2012, 05:52 AM
LSU fan's Avatar
What jd said. The 1912 and 2112 have the same amp.
LSU fan is offline
Old 03-17-2012, 08:57 AM
tvuong's Avatar
Liked: 878
For what you stated: XT v.s non XT and others posted on page 1.
Old 03-17-2012, 09:13 AM
Razal's Avatar
Hey guys. I've been reading for hours and I know I've probably read the answer I'm looking for but most of it is just too advanced for me.
I have the 2112ci and I recently changed my sub. I went from a Velodyne Impact 12 BV to a Velodyne DLS-5000R.
They are different, but I am NOT an AV guy so I don't know how they are different (other than size and power), but my gut tells me that when I ran Audyssey for the new Sub, I screwed everything all up because my sub doesn't play any sound at all.
I'm not sure if it was always like that, or if I blew it but my gut tells me it isn't blown, just that when I ran audyssey, I did it wrong.
I'm not sure what "settings" the sub should be on.... and when I ask that, what I'm really saying is when you tell me it should be on "low pass" or "high phase" or whatever the proper terminology is... I don't know. I need someone to tell me... "turn this knob all the way to the left or right". Volume all the way up or down!
Should the "low pass crossover" be turned all the way to the right where it says "40hz" or all the way to the left where it says "direct" or in the middle?
Should "auto on/off" be on "active or inactive"?
There is a picture of my back panel of my sub here http://www.hometheaterhifi.com/volum...05-part-1.html
Where should it be plugged into from my AVR? My installer put it in where it says "output" and in the white connector "L", but shouldn't it be in "Input"???
Sorry for all the stupid questions but I have ZERO knowledge about this stuff.
Razal is offline
Old 03-17-2012, 09:38 AM
Nickff's Avatar
Quoted: 278 Post(s)
Liked: 169
Definitely want the RCA cable plugged into the input marked LFE on the back of the sub. Then, re-run audyssey. Typically, a good starting point for the sub's volume or gain is the half-way point. If after running audyssey the sub's channel level is negative 5 or lower, turn the sub's volume or gain down a bit and re-run. If audyssey sets the sub's channel level positive 5 or higher then turn the sub's volume or gain up a bit and re-run. The closer the sub's channel level is to 0 after running audyssey, the better.
Mathematics is the reason for the season.
Nickff is offline
Old 03-17-2012, 10:02 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Just scored a Denon 3312ci on a open box buy. It is in mint condition. I bought a 2312ci last month, but I did not realize it did not have preouts, live and learn!
Reefdvr27 is offline
Old 03-17-2012, 10:54 AM
Zack Fair's Avatar
Thanks to everyone's help!
I decided buy the 2112...!
Has almost the same components compared to the more expensive and it has an affordable price.
Old 03-17-2012, 01:00 PM
ghostsup's Avatar
+1 for the 2112! Just got her hooked up yesterday and couldn't be happier! This replaced a 10 year old HK AVR 525 and I must say, my system has never sounded even close to this good. Plus, if you're a fan of the band Rush... it's a no brainer! LOL!
ghostsup is offline
Old 03-17-2012, 02:01 PM
kauaidoug's Avatar
Not sure if by TV>BD65 you mean the TV is connected to the BD65? With no cable box, you'll want to connect an optical cable from the TV to the 2112CI.
My TV has cable direct no box, HDMI connect from TV to 2112, HDMI from 2112 to BD65.
I connected an optical cable from TVdigital audi out to 2112 optical tv.
I read my TV set up and gone through here looking for what I am sure is a very simple solution. Read FAQs and says about setting from source but it's all greek to me. Find it very hard to navigate and negotiate the manual. BTW
kauaidoug is offline
Old 03-17-2012, 02:04 PM
robjaskiewicz@gm's Avatar
Hi folks,
sorry; ive read the faq and cant seem to find a how to post a new thread instruction. I apologize for this intrusion into the thread but can someone help
robjaskiewicz@gm is offline
Old 03-17-2012, 02:25 PM - Thread Starter
batpig's Avatar
Liked: 3420
if you want us to help, you can start by asking a question
Setup Guide and FAQ
Old 03-17-2012, 02:27 PM - Thread Starter
batpig's Avatar
Liked: 3420
so what's the problem? if you have an optical cable running out from the TV to the receiver, and you are getting audio..... what's wrong? that sounds like correct function.
Setup Guide and FAQ
Old 03-17-2012, 02:49 PM
kauaidoug's Avatar
Sorry, I am not getting audio, that's the problem
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
