The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #10081 of 20168 Old 03-18-2012, 12:20 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
Originally Posted by lou99 View Post
Hey Guys, I have two quick questions:
1) PS3 games dont seem to be calibrated with reference level in mind - What AVR settings are you guys using for gaming? When I play NBA 2k12, I cant tolerate a volume over -25. It's very loud! This may cause Dyn EQ and such to go out of whack. Should I "lower" the Level of the PS3 input? use Reference Level Offset on the receiver? or Lower the "master volume" in the Game?
2) While watching a movie yesterday where background 'music' played pretty loud on all speakers on a specific scene. The master volume on the Receiver was on -10 and Dynamic Volume was set to Day. I dont know if this was caused by Dynamic Range or DynEQ boosting anything because I was watching the movie at -10. Is Reference Level Offset "Literal?" I watch Bluray's at -10db. Does that mean I should use a -10db REO setting?
1. Volume listening level is going to depend on several factors including distance from the speakers and the size of your room as well as the efficiency rating of your speakers. Why do you believe Dyn EQ can go "out of whack"? The lower the volume below 0db, the stronger the bass/surround boost. If you want to reduce the bass/surround boost at a given volume, simply raise the Reference Offset incrementally up to -15db until you're satisfied. Bottom line, if it's very loud overall, then simply lower the master volume.
2. Read my response above again.
jdsmoothie is offline
post #10082 of 20168 Old 03-18-2012, 12:26 PM
spager's Avatar
Originally Posted by Zack Fair View Post
Denon 2112.!
I see 2 strange things ! I don't know if its the denon for return or its the software!
I plug the Ethernet connection and some times I see a message about updated to press enter but its like don't response and in The radio when I'm looking some station a message appear and say no connection to network.!
Maybe its the software and I need to update but I don't know how manually because I press enter but I don't see nothing xd
What can I do.?
You are probably getting a firmware update notification go to page 1 of this forum, post #6 for complete instructions.
For networking issues go to page 1, post 3 section 8.
spager is offline
post #10083 of 20168 Old 03-18-2012, 12:46 PM
pacemaker's Avatar
Quoted: 30 Post(s)
Is there an 'optimum settings' guide?
pacemaker is offline
post #10084 of 20168 Old 03-18-2012, 12:53 PM
jdsmoothie's Avatar
Liked: 5502
Everyone comes with their own built in personalized "optimum settings" guide .... your ears.
post #10085 of 20168 Old 03-18-2012, 12:59 PM
lou99's Avatar
Thanks, but doesnt that cause a problem? If im playing games at -25, wouldnt that cause unnecessary "boosts" in Dyn EQ? Even when -25 is just as loud as reference in a particular game?
lou99 is offline
post #10086 of 20168 Old 03-18-2012, 01:08 PM
jdsmoothie's Avatar
Liked: 5502
No clue to what you're referring to?
Either use Dyn EQ or don't use it ... your choice.
post #10087 of 20168 Old 03-18-2012, 01:56 PM
lou99's Avatar
The issue isn't with DYN EQ, but the fact that games could be 25% louder than movies at reference level. All good disregard the question.
lou99 is offline
post #10088 of 20168 Old 03-18-2012, 02:04 PM
Damenace72's Avatar
As recommended, are your front mains set (or reset) to SMALL with minimum of 80hz crossovers? If not, there is no LFE channel in your iPod audio so there's nothing to be sent to the sub.
Main fronts are set to small. No surrounds or center.those are off. Set to LFE. Crossover set to 80hz. LFE set to 80hz.
Selecting ch level still does not bring up the SW. Not sure what else to check. Is it my iPod classic? Sub worked fine with the iPod on the pioneer.
Damenace72 is offline
post #10089 of 20168 Old 03-18-2012, 02:10 PM
pacemaker's Avatar
Quoted: 30 Post(s)
abybody manged to get a Samsung BD player working with the remote?
post #10090 of 20168 Old 03-18-2012, 02:18 PM
spager's Avatar
In the Input Setup there is a Source Level that will help but remember the receiver volume will be affected by what the source outputs.
spager is offline
post #10091 of 20168 Old 03-18-2012, 02:32 PM
Superfluous's Avatar
Is the airplay good on these units?
Superfluous is offline
post #10092 of 20168 Old 03-18-2012, 02:54 PM
ccotenj's Avatar
Liked: 101
you aren't using "direct" by any chance?
edit: "direct" on the pioneer is not equivalent to "direct" on the denon... "direct" on the denon is roughly equivalent to "pure direct" on the pioneer...
- chris
ccotenj is offline
post #10093 of 20168 Old 03-18-2012, 02:58 PM
ccotenj's Avatar
Liked: 101
LOL! i like that...
- chris
ccotenj is offline
post #10094 of 20168 Old 03-18-2012, 03:31 PM
Patrick G's Avatar
How do I get Audio Return Channel to work? I've got a single hdmi running from the Denon to the hdmi2 (ARC) port on my Samsung UN65D8000. Everything is running thru the Denon. However, when I play Netflix via Samsung Smart Hub on the TV, I still get the audio from the DirecTV channel I was watching.
Patrick G is offline
post #10095 of 20168 Old 03-18-2012, 03:41 PM
Damenace72's Avatar
I think I am using direct. Under audio settings it gives me 2ch direct/ST. The setting is 'custom' or 'basic'. I have mine set to custom. Am I supposed to change it say from direct?
post #10096 of 20168 Old 03-18-2012, 04:03 PM
chadsdsmith's Avatar
Quoted: 31 Post(s)
Liked: 24
When you guys watch older blu ray with 5.1 lpcm audio, which listening mode do you use? I ask because it seems like when I use the normal multi channel setting (I have a 1712 btw), I get more dialogue coming from the surround apeaker than I am used to from movies, as if it is a stereo source being routed to the surrounds. Using plxII or whatever seems to fix that but I was just wondering what to use in order to have the intended sound as transmitted from the disk? I hope you understand what I am trying to say... sometimes my questions make perfect sense to me but everyone else is like...huh?
chadsdsmith is offline
post #10097 of 20168 Old 03-18-2012, 04:16 PM
Possumgirl's Avatar
Liked: 58
Did you turn the Denon's HDMI-CTL on? By default it is off. Once that's turned on you should just need to press the TV button on your remote to hear the Netflix audio.
Possumgirl is offline
post #10098 of 20168 Old 03-18-2012, 04:31 PM
EricST's Avatar
Quoted: 63 Post(s)
Liked: 44
Can't wait, 2112 will be here this week.
60" Samsung KS-8000
Oppo 203 UHBD
Denon 2200X receiver
PSB X series 5.1.2
The Force will be with you ...always.
EricST is online now
post #10099 of 20168 Old 03-18-2012, 05:09 PM
pacemaker's Avatar
Quoted: 30 Post(s)
Just got a 2112ci after returning a pioneer vsx 50 because I could not play my iPod on USB in zone 2. My powered subwoofer worked like a champ on the pioneer, but no sound at all from the sub now that it is hooked up to the Denon. I have checked to ensure the the sub is marked 'yes' in the setup. I am definitely hooked up to the pre out on the receiver. when I got into the ch select menu the sub is not showing up at all. With the sub on, scratching my thumb on the coax I get a sound. Is my receivers pre out toast, or am I missing a setting? Can anyone help? Thanks!
Hi
same problem i had listening to 2ch audio in direct mode possibly
in the bass setting there is an option to use LFE+Main, check if you have LFE only
i used to think this meant sending 'sub' sounds to the sub+Main speakers but i think it actually means sending dedicated 'sub' soundtrack data + normal bass from 2ch material to the sub, hence the lack of the 'sub' in the ch select as you are only listening to 2ch
give it a go!
post #10100 of 20168 Old 03-18-2012, 05:10 PM
ccotenj's Avatar
Liked: 101
there is no "dedicated sub soundtrack data" in a 2 channel recording...
rather than using "direct" (and bypassing room correction, which almost all users benefit from), use "stereo"...
- chris
ccotenj is offline
post #10101 of 20168 Old 03-18-2012, 05:18 PM
pacemaker's Avatar
Quoted: 30 Post(s)
I know thats why using LFE only means you loose the bass from 2ch 'main'
in 'direct' mode there is still an option for Audyssey but i dont know what this does
i will give 'stereo' another go but thought 'direct' was more 'real' if that makes sense
post #10102 of 20168 Old 03-18-2012, 05:24 PM
ccotenj's Avatar
Liked: 101
nope, that's not it either...
nope... it's not more "real" in any way...
what you hear is made up of 3 things...
- the mix of the source material...
- the speakers...
- what the room does to the sound after it comes out of the speakers...
many people underestimate/don't realize how much of an impact #3 makes... using room correction actually gives you a closer approximation of what the mixer intended (especially below 200hz in an average home environment, but also important above that) than not using it will...
- chris
ccotenj is offline
post #10103 of 20168 Old 03-18-2012, 06:23 PM
kenshomi's Avatar
So a friend of mine asked if I wanted his AVR3808 - I just bought a 1712 a few months back - should I take him up on it. I find most of his hand-me-downs are better then my new stuff? I'm checking out the specs. IT seems to do everything my 1712 does and more.
kenshomi is offline
post #10104 of 20168 Old 03-18-2012, 07:59 PM
Damenace72's Avatar
Stereo and LFE + Main did the trick! Thanks everyone for their suggestions.
post #10105 of 20168 Old 03-18-2012, 08:34 PM
cjsiv's Avatar
Liked: 33
So I got my new 2112 hooked up tonight. Definitely different than my 1910. Anyone know what it means when it says "offset -5" as an example when I change channels? What exactly does that mean? My 1910 did not do that.
cjsiv is offline
post #10106 of 20168 Old 03-18-2012, 08:37 PM
Yobder's Avatar
Anybody have a Logitech 880 Remote? When I select menu, the up, down and select does not work, only forward and back. I have an AVR1912, thanks.
mack
Yobder is offline
post #10107 of 20168 Old 03-18-2012, 08:37 PM - Thread Starter
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
the 3808 is a significantly higher end unit than the 1712. I would take it for sure as a free "hand me down".
the only thing the 1712 does that the 3808 doesn't is support 3D (HDMI 1.4).
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #10108 of 20168 Old 03-18-2012, 08:39 PM - Thread Starter
batpig's Avatar
Liked: 3415
mack
you have to go into the Harmony software and cusomize the buttons for the device, the defaults are sometimes screwy. The up/down buttons are probably assigned to TUNER UP/DOWN or something.
Setup Guide and FAQ
batpig is offline
post #10109 of 20168 Old 03-18-2012, 08:41 PM - Thread Starter
batpig's Avatar
Liked: 3415
That is the Dolby Digital Dialnorm offset. Your 1910 did it too, because EVERY receiver that decodes Dolby Digital does it
it's just a notification of the offset value embedded in the DD metadata. nothing to worry about it and you can't change it even if you wanted to (you don't). Read more here: http://www.hometheaterhifi.com/volum...on-6-2000.html
Setup Guide and FAQ
batpig is offline
post #10110 of 20168 Old 03-18-2012, 08:43 PM - Thread Starter
batpig's Avatar
Liked: 3415
something is wrong, sounds like you are getting a 2ch signal which means your Blu-ray player is configured wrong.
check the input signal in the GUI under INFORMATION > AUDIO INPUT SIGNAL. My bet is it will say something like PCM 2/0/0 instead of a multichannel signal (which would say 3/2/.1 for example with 5.1).
Setup Guide and FAQ
batpig is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
