The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 06-09-2011, 01:07 PM
lowpolyjoe's Avatar
Originally Posted by Kalani View Post
I can't say for sure, but no matter how much lipstick you put on a pig, it's still a pig.
The Denon 3312 is a great receiver, and if you plead a bit (and move fast!), you shouldn't have too much trouble getting it for ~$800 from Electronics Expo. Next week the prices go up, and at some point I have little doubt Denon is going to ream EE for these sales, so you may as well take advantage of it while you can!
After that start saving for some better speakers, which can be added over time to greatly improve your sound. The urgency is for the receiver, if the 3312 is the one you want, because these prices won't be here for long.
Another thought, re speakers, is to consider the used market. There are some serious bargains out there. You can get something MUCH better than what you have now for peanuts if you're willing to go used. If you decide you want something different or better later, you're not out much money, so it's not so painful to start upgrading further as funds permit.
thanks for the feedback. i am worried that the price will jump up and not return to levels like these for many months. i'm also worried i'll drop $800 and not notice any difference at all in my home theatre experience and be out $800.
i had not considered used stuff. i have bad luck in general, so buying used always scares me. i'm strongly considering some DIY speaker projects in the near future. i believe the value in some good DIY setups is also pretty good.
thanks
lowpolyjoe is offline
Old 06-09-2011, 01:10 PM
Topspin14m's Avatar
Can someone comment on the 2112 vs. the 3312? I am not looking for a list of features, but I have a 5.1 setup with 2 tower speakers up front. I also have a second zone with two speakers that I run off a second amp. I am mostly concerned that the 2112 will not be powerful enough to drive the 5.1 setup that I have. I do not believe I have 4 ohm speakers (which would be a problem I know) because a Denon amp is powering the system now. I am not at home/do not know exactly what I have in terms of speakers/the model of the receiver because I inherited this equipment with a new home and did not purchase it myself.
Topspin14m is offline
Old 06-09-2011, 01:32 PM
Jedi54's Avatar
Originally Posted by DRGSin View Post
OK...good news for me, I just placed my order!! Bad news for you guys, I just placed my order. Having no idea as to what 90% of this thread discusses, I will be having lots of questions, so please bear with me!
congratulations but much reading to do you have.
Jedi54 is offline
Old 06-09-2011, 02:22 PM
jrh
jrh's Avatar
Just wanted to let everyone know that, despite my postings last nigh, today I was able to run Audyssey, as well as get all my inputs working!
I have a question, though: If I connect a DVD player to the DVD HDMI input and connect a WII to the DVD component inputs and DVD red/white audio jacks, is the 3312 supposed to output the DVD player when it's turned on, but display the WII when it's on and the DVD's off?
Similarly, what about if, instead of a WII, I connected another DVD's DVI video to the 3312's DVD HDMI via a DVI>HDMI adapter and the same DVD's audio to the 3312's DVD optical audio input. Seems like my XR-V663 would do this (i.e., play more than one device through an input, just give priority to HDMI over Component, etc.)?
jrh is offline
Old 06-09-2011, 02:23 PM
lowpolyjoe's Avatar
just ordered a 3312 from electronics expo.
didn't do as good as some other prices mentioned on here, but they only had something like 3 left (down from 8 the previous time i called) so i bit the bullet as it seems everyone is selling out and restock times have been quoted as long as 30 days to me. and i hear these deep discounts below msrp are not going to last long because of upcoming restrictions from denon.
it was a shocker when they sales guy said my credit card was declined but apparently he just typed in the info wrong, as it went through the next time.
i've never bought a reciever (just few home-theatre-in-a-box setups) so i'm hoping this is worth the plunge...
Old 06-09-2011, 02:36 PM
mjpearce023's Avatar
Quoted: 34 Post(s)
Liked: 38
For most 8 ohm speakers the 2112 will be plenty depending on the room size. I went from a Denon 1508 to a Denon 3310 and the extra power made no difference for me. The 1508 had plenty of power for my system so the 3310 just added some more head room. I don't think you would find a difference in sound quality between the 2112 and 3312 as the both use MultiEQ XT. You would have to move up to the 4311 to get an audible improvement in my opinion.
mjpearce023 is offline
Old 06-09-2011, 02:38 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
What about NHt absolute tower speakers which have an 8 ohm average 4 min?
mjodotcom is offline
Old 06-09-2011, 02:47 PM
Quoted: 34 Post(s)
Liked: 38
I don't know about that. Most speakers I see are around 90 db or higher sensitivity and 8 ohm. The NHTs you mentioned are only 86db and would be a little more difficult to push. I would have no problem with some Klipsch RF7s or Paradigm Monitor 11s on a 2112 but those are both very efficient speakers. The room size also has a lot to do with it as does how loud you listen.
Old 06-09-2011, 02:51 PM
Scurly's Avatar
Quoted: 29 Post(s)
I have the 1911 and just received the 3312CI without the set up mic for Audyssey.
Does anyone know if the one I have for the 1911 will work?????
Scurly is offline
Old 06-09-2011, 02:52 PM
Topspin14m's Avatar
I thought the 2112 did not use MultiEQ XT?
EDIT: I see it does. Ok I should be fine then I figure. Especially since the receiver is rated at 90 watts per channel for 7 channels and I am only using 5...
Old 06-09-2011, 03:00 PM
roknrol's Avatar
Quoted: 27 Post(s)
Check the styrofoam packaging from the box. The mic may be in a little white box stuffed in there as others are reporting. Apparently, easy to miss.
roknrol is offline
Old 06-09-2011, 03:51 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
And based on the responses to the guy with the 2112 who nearly tossed out his mic with the packaging, no, other receivers mics are not calibrated the same and will not work.
Kalani is offline
Old 06-09-2011, 03:52 PM
assplats's Avatar
I have 5 NHT SuperZero 2.0 satellites that are rated at 86dB sensitivity, and my current 75 watt x 7 receiver pushes them just fine.
assplats is offline
Old 06-09-2011, 03:55 PM - Thread Starter
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
the mics are the same DM-A409 model so no worries, but you should still have a mic in the 3312ci box.
not true, all Denon AVR's have used the same DM-A409 mic since the xx09 models.
you can also use the current Onkyo mic (ACM-1h) which is the same thing, but in a gray plastic package instead of black. They are all the same mic, designed and produced by Audyssey for Onkyo/Denon.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 06-09-2011, 03:58 PM - Thread Starter
batpig's Avatar
Liked: 3420
Originally Posted by lowpolyjoe View Post
i'm currently using crap sony satallite speakers all the way around (5.1). i probably won't get decent speakers for a while after dropping $800+ on an avr after dropping $3K on a tv recently (samsung plasma).
i've never seen/heard audessey in action - will it make my crappy speakers sound noticably better? can anyone comment on that asap so i can make a decision before everyone sells out of these receivers?
looks like you already bought.... but to be perfectly honest, an $800 receiver is sort of a waste if you aren't willing to upgrade your speakers too. You could have gotten a 2112 for nearly half the price and had similar sound quality.
Unless there is some specific reason you wanted the 3312ci, if it's not too late, I would recommend switching the order to a cheaper model, and allocate money to SPEAKERS instead. Spending that same $800 on a 2112ci and a Energy Take Classic 5.1 speaker package will almost certainly sound better than a 3312ci with your crappy Sony HTIB speakers.
The 3312ci will be a great receiver, no doubt, so if you are willing to start upgrading speaker soon than go with it, but if you are just going to use those HTIB speakers for a long time, probably was a waste.
Setup Guide and FAQ
Old 06-09-2011, 04:00 PM
Scurly's Avatar
Quoted: 29 Post(s)
read previous posts and looked thru the styrofoam...sure enough. it was in there. Nice to have the forum! I will be leaning on it this weekend when I set up this 3312CI
Scurly is offline
Old 06-09-2011, 04:02 PM - Thread Starter
batpig's Avatar
Liked: 3420
remember folks:
THERE IS A TON OF INFO POSTED IN THE FIRST 6 POSTS OF THIS THREAD!!!! PLEASE CHECK THERE FIRST BEFORE POSTING BASIC QUESTIONS!
Setup Guide and FAQ
Old 06-09-2011, 04:05 PM
TalkingRat's Avatar
Liked: 32
But couldn't it be the same model mic, but tweaked for each model uniquely?? From the Audyssey FAQ:
Can I use any mic for MultEQ? Can I use a mic from my previous AVR on my new AVR?
No. The Audyssey mic that was included with your AVR has been specially calibrated to your AVR model. Using another microphone for your MultEQ calibration will not produce accurate results. If you can not find the micophone that was included with your AVR, contact the manufacturer for a replacement.
http://www.audyssey.com/technology/faq/index.html
TalkingRat is offline
Old 06-09-2011, 04:11 PM
syphon's Avatar
Please delete mod.
syphon is offline
Old 06-09-2011, 05:08 PM
ps24eva's Avatar
Quoted: 37 Post(s)
How do I update firmware on the 2112?
Help an old avsforum vet
ps24eva is offline
Old 06-09-2011, 05:10 PM
JAM7843's Avatar
Do I need to upgrade my speakers for the AVR3312ci.
The speakers I have are the JBL ES Series:
Floorstanding speakers
JBL ES90
110watts cont/440 peak
8 ohms
sensitivity 91db
Bookshelf speakers for surround
JBL ES30
70 watts cont/280 peak
8 ohms sensitivity 88db
Center Channel
JBL ES25c
75 watts cont/ 300 watts peak
8 ohms
sensitivity 90db.
Subwoofer 12 inch
JBL ES250p
RMS Power 400 watts
Peak Dynamic Power 700watts
JAM7843 is offline
Old 06-09-2011, 05:11 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
"How do I update firmware on the 2112?"
(quotes not working right all of a sudden)
Are there any new firmware releases for a brand new receiver already? That would surprise me. I hope Denon is not turning into Microsoft...
Kalani is offline
Old 06-09-2011, 05:12 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
JBL ES90
8 ohms
sensitivity 91db
JBL ES30
Center Channel
JBL ES25c
8 ohms
sensitivity 90db.
Subwoofer 12 inch
JBL ES250p
RMS Power 400 watts
Those will work fine with the 3312. You can ALWAYS spend more and upgrade to something better, but whether you "need" to is subjective.
Kalani is offline
Old 06-09-2011, 05:14 PM
JAM7843's Avatar
Thank You for that quick response
JAM7843 is offline
Old 06-09-2011, 05:40 PM
antbatt13's Avatar
3312 in the trunk! $749 at, Best Buy of all places...
antbatt13 is offline
Old 06-09-2011, 05:45 PM
hecklerj01's Avatar
That's unreal...the BB near me already has a $1099 price tag on the 3312!!
hecklerj01 is offline
Old 06-09-2011, 05:47 PM
Iusteve's Avatar
Damn @ BB?? Really??? They NEVER have good prices. Are you sure its the 3312 and not the 2312?
XBOX Live: Zz NiNj4 D4D zZ
Iusteve is offline
Old 06-09-2011, 05:48 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
The avr should prompt you if notifications are on and the avr is networked.
In search of video bliss...
mariob33 is online now
Old 06-09-2011, 05:49 PM
antbatt13's Avatar
Yes, I'm sure, lol.
And the price tag was $1099.
Old 06-09-2011, 06:36 PM
mjodotcom's Avatar
Quoted: 14 Post(s)
But aren't the absolute towers harder to push? So do people think the 2112 would be more than enough headroom for those speakers? So would I really gain nothing going to a 3312?
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
