The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 365 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
Old 04-13-2012, 06:06 PM
loopaddiction's Avatar
Hi all, i'm having trouble connecting to my home network with my 2112CI. My internet provider is AT&T Wireless and I have it connected through ethernet cables from receiver to router via an ethernet bridge (NetGear XE102G Wall plugged Ethernet Bridge) I'm unable to connect it directly with 1 cable since my receiver is in a room up stairs and the router is downstairs. As far as I know, the ethernet bridge should work as i've never had a problem with it using other devices. It works with my WD Live Hub for instance.
I tried powering off/on the receiver and resetting the microprocessor already. My network details on the receiver shows the following:
DHCP: On
IP Address: 169.254.109.058
Subnet Mask: 255.255.000.000
Default Gateway: 192.168.001.254
Primary and Secondary DNS: 000.000.000.000
My network info on the receiver shows:
IP Address: 169.254.109.58
MAC Address: 0005cd-236d3a
I'm pretty sure my router supports DHCP as my network details on my computer says DHCP is on. I went through the setup wizard and tried using Pandora and it tells me i'm unable to connect to the network.
Any help would be appreciated.
loopaddiction is offline
Old 04-13-2012, 06:25 PM
spager's Avatar
DHCP: On
Check out pg.1 of this forum and look at post 3, 8b and 12g for networking tips and fixes.
spager is offline
Old 04-13-2012, 06:28 PM
turquoisewords's Avatar
DHCP: On
Your assigned IP address tells you that DHCP failed to assign you an address.
The private networki block 169.254.0.0/16 is reserved for this purpose.
Make sure your DHCP server is working with a laptop or another device. Better yet -- assign a static IP address that is on your local network.
turquoisewords is offline
Old 04-13-2012, 06:31 PM
FORMULA11's Avatar
I just ordered a 1712 from EE for $270 useing Ccode GRANDSLAM good till 4-19
FORMULA11 is offline
Old 04-13-2012, 07:08 PM
I tried searchiing online but can't seem to find an easy guide on how to assign a static IP address to my receiver. I can only find how to set a PC to have a static IP. Not really experienced with networking as you can tell, can you give me a brief overview on how to do this?
I have a 3800HGV-B router by the way.
Old 04-13-2012, 07:50 PM
Update: I found on my routers settings page that the ethernet port I was using with the bridge had an address of 192.168.1.78, I tried tracerouting it and set the DHCP to off on the receivers settings with all the needed info. Now I see this on the routers setting page:
It shows that it's connected and has a static IP address assigned...so I believe I did it right? Restarted the receiver and tried again (DHCP off) and it still won't connect.
Old 04-13-2012, 08:04 PM
spager's Avatar
Have you tried Denon Internet Radio to see if you have a connection? Have you tried resetting your router? Try a Network reset on the avr. Pg,1 post 5.
spager is offline
Old 04-13-2012, 08:05 PM
Klynn's Avatar
The screen cap.. what device are those settings for? The AVR or the bridge? EDIT: I assume the bridge, because if you could access the Denon from a PC you probably wouldn't be posting about a problem.
Use the bridge for another device and see what happens. (I.E. take a laptop, turn off/disconnect the built in wifi, plug into the bridge, see if you get internet). That will help you eliminate if the bridge is the problem or the AVR. IMO, it's probably the bridge. I do residential/small business IT for a living and wifi/ethernet bridges make me want to cry sometimes.
Klynn is offline
Old 04-13-2012, 08:15 PM
The screen cap is for the bridge I believe, but my reciever is connected directly to the bridge via ethernet. That's also the IP address I entered into the receivers settings. Do I need to setup a separate static IP for the receiver itself (and if so how?)?
I hooked up the bridge to my WD TV Live Hub (which doesn't have a wireless card) and I am able to connect to the internet. Still no go with the receiver, after many restarts and setup wizard testing.
Old 04-13-2012, 08:41 PM
Hmm okay some progress, so now i'm able to see the Denon receiver through iTunes but it's stuck at "Connecting to DENON:[AVR-2112CI]" and the pop-up just vanishes after a while. This is after I powered off the receiver, let it sit for a few minutes unplugged, then turned it back on. I also still can't connect to Pandora or internet radio.
Could it be a compatibility issue with the receiver and this network bridge? Again, the bridge works find with my Western Digital hub.
Old 04-13-2012, 08:44 PM
balpers's Avatar
Originally Posted by balpers View Post
Thanks for the responses. I think I may have solved the problem in another way. I neglected to mention that I am controlling the switching with a Harmony One remote. This remote allows unused components to be powered down when you switch away from them. My guess is that the Harmony throws some sort of signal to HDMI ports when this function is invoked.
Anyway, it seems that turning this option off fixes the problem. (If not, I have the Monoprice device on order ... no worries for $13, even if I don't need it.)
I'll report back if it recurs.
Thanks for your help.
Burt
Well, I spoke too soon. It turns out that my solid HDMI switching was a fluke. All my inputs are flaky. Things generally work from a cold start, but switching from one component to another is a crap shoot. I'll have to see what happens with the Monoprice device. More to come...
Burt
The Consultant's Creed:
I can do it right.
I can do it cheap.
I can do it fast.
You get to choose any two.
balpers is offline
Old 04-14-2012, 04:22 AM
markie100's Avatar
Hi, am i right in thinking that you can't alter bass & treble while using audyssey dynamic? also could someone please clarify why they can be altered in zone 2 & can i use the zone 2 (using the same speakers as my main zone)? please for give me if i sound a bit cluless,
markie100 is offline
Old 04-14-2012, 05:08 AM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
Correct. Audyssey Dynamic EQ must be disabled in order to use the Tone Control settings (Bass/Treble). Audyssey is not applied to Zone 2 speakers. And no you can't use the same speakers for both main zone and Zone 2 if you want to use Audyssey.
jdsmoothie is offline
Old 04-14-2012, 05:27 AM
markie100's Avatar
thanks once again jd
Old 04-14-2012, 07:59 AM
markie100's Avatar
Hi, could someone kindly explain (in easy to follow instructions), how to save my 2312 settings to my computer ( it is connected to the internet), as i would like to be able to download them back to the receiver rather than go through a set up every time,
thanks.
Old 04-14-2012, 08:36 AM
Ladyblue627's Avatar
Yes, it should be. It turns red to let you know that either HDMI Control or Network Standby (or both) is set to ON.
Thank you for your reply jdsmoothie. I had a feeling it would be something network related, now I can rest assured. Thanks again.
LB
Ladyblue627 is offline
Old 04-14-2012, 09:06 AM
ghostsup's Avatar
Thanks to all (especially JD) who helped me out with my HDMI handshake issues between my 2112 and Samsung DLP. I did solve the problem, however it was an extremely expensive fix! I bought a new Samsung 55" 7500F LED TV and the problems are 100% solved. I honestly can't believe what I was missing visually!
ghostsup is offline
Old 04-14-2012, 09:42 AM
o0Dan0o's Avatar
First, thanks to anyone who can help me with this problem, it's been driving me insane.
So I get my new 3312 to replace my yamaha RX-V863, the sole purpose being to get HDMI back so I can work everything through the receiver. This is connected to my samsung PN50C8000, a two year old plasma, my PS3 and a motorola U-Verse box. When connected to the u-verse box it works fine, but it doesn't appear to want to recognize the PS3.
With the PS3 plugged in any HDMI port (I've tried all of them), when it's off it shows the normal 'DENON' screen, when I power it on the TV goes blank and in a few seconds says 'No Signal.' I also don't get sound from the PS3 through the denon, at least I can't hear clicking through the menus. Again, the u-verse box works without an issue.
I've tried doing several HDMI resets, I've tried replacing the cables (I have a few spares), and I've tried doing a microprocessor reset. When I set my two receivers up next to each other, I can swap the hdmi cables over to the 863 and everything works fine, swap them back to the denon and nothing.
I should also add, I tried searching through this thread, but I haven't come up with much, I apologize if it's a repeat question. So please, if you have any ideas, let me know!
Dan
o0Dan0o is offline
Old 04-14-2012, 10:39 AM
mtmcd's Avatar
Is there separate tone control for zone 2 on the 2112CI? If so, how does one find that menu? If not, is there any way to control the tone of zone 2?
mtmcd is offline
Old 04-14-2012, 11:56 AM
jdsmoothie's Avatar
Liked: 5548
Sorry, but no. Zone 2 tone control starts with the 2312CI and higher models. Your best bet is to connect the Zone 2 preouts to another AVR and use it's tone controls.
Old 04-14-2012, 11:59 AM
rwe416's Avatar
Dan
I ran into the same problem with my 2112CI and was getting really aggrevated. Finally I figured mine out. I had to go into the menu and where it says HDMI I had to turn it on. After that no problems.
rwe416 is offline
Old 04-14-2012, 12:03 PM
jdsmoothie's Avatar
Liked: 5548
Dan
Did you check the Troubleshooting section in post #3 and try setting PS3 Deep Color Output setting to OFF?
Old 04-14-2012, 12:58 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
3808ci owner, looking to upgrade to a receiver that has 3D passthrough such as the 3312ci, was curious if anyone has opinions on if there are any negatives in upgrading from 3808ci to 3312ci such as if Denon cut corners on this line as it progressed or hear from anyone who had a 3808ci and upgraded to the 3312ci.
WynsWrld98 is online now
Old 04-14-2012, 02:59 PM
o0Dan0o's Avatar
On the ps3 or the avr?
I have gone through the trobule shooting section, including the deep color option, with no luck.
Dan
o0Dan0o is offline
Old 04-14-2012, 03:11 PM
HoldenCruze's Avatar
Originally Posted by WynsWrld98 View Post
3808ci owner, looking to upgrade to a receiver that has 3D passthrough such as the 3812ci, was curious if anyone has opinions on if there are any negatives in upgrading from 3808ci to 3812ci such as if Denon cut corners on this line as it progressed or hear from anyone who had a 3808ci and upgraded to the 3812ci.
G'day mate,sorry to say not such thing as an 3812 in the US the 3312 is the highest model on the moment. maybe when the ..13 serie comes out there will be an higher model
HoldenCruze is offline
Old 04-14-2012, 03:22 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
Sorry I meant 3312
Old 04-14-2012, 04:12 PM
Sorry I meant 3312
wait for the new 2013 models they will be here soon
Old 04-14-2012, 04:13 PM
jdsmoothie's Avatar
Liked: 5548
Dan
Have you reset the PS3 (ie. press/hold power on button for about 10 seconds) while connected to the AVR? Do you have another TV you can use to test with the PS3?
Old 04-14-2012, 05:56 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
At higher prices ofcourse, not sure there is anything in them that is important to me and there are VERY good deals to be had right now on the 3312 and 4311.
Old 04-14-2012, 07:04 PM
rwe416's Avatar
[quote=o0Dan0o;21907136]On the ps3 or the avr?
On the avr.
rwe416 is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
