The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 380 - AVS Forum | Home Theater Discussions And Reviews
 287Likes
post #11371 of 20242 Old 04-28-2012, 05:35 PM
jdsmoothie's Avatar
Quoted: 15095 Post(s)
Liked: 7286
Originally Posted by Roachforlife View Post
Id like to do 5.1 in my living room, and have 2 speakers for zone 2 on my patio. Is there a way to do a HDMI source for the rears or only with the 3xxx series? Thanks
The 3xxx series cannot pass HDMI to Zone 2, however, any of the Zone 2 models can set the Amp Assign speaker posts to "Front B" to pass the same HDMI audio playing to the Front A speakers (as noted in the post you quoted).
jdsmoothie is online now
post #11372 of 20242 Old 04-28-2012, 05:37 PM
SolApathy's Avatar
I am just trying to find a fix for this problem I keep having- Randomly when I am done with airplay the receiver will completely lock up. It shows the last song played and refuses to do anything unless I unplug the power.
I already tried the MP reset and it happened again the same night after that. I am so frustrated, this is one of the main reasons I bought the 1912.
I read in a few posts where people have experienced the same issue, but have not seen any fixes ( My firmware is up to date).
I am about to throw this stupid thing out
-Frustrated
SolApathy is offline
post #11373 of 20242 Old 04-28-2012, 06:00 PM
paul_eclipse's Avatar
need help...just bought 2112 two weeks ago...
Had hdmi plugged into 'sat/cbl " to samsung e8000, was working fine until i turned it on today. I got picture but no sound. After trying everything I moved hdmi to "bd" and picture and sound work perfect. What can I check to fix sat/cbl.
paul_eclipse is offline
post #11374 of 20242 Old 04-28-2012, 06:02 PM
jdsmoothie's Avatar
Liked: 7286
Might have just been a loose connection, otherwise it's likely other devices will work fine with that input.
post #11375 of 20242 Old 04-28-2012, 06:12 PM
jdsmoothie's Avatar
Liked: 7286
-Frustrated
When finished with Airplay, try backing all the way out of the sub menus to ensure the NET/USB source is no longer active. Are you able to turn OFF the source? You might also want to try setting "Network Standby" to OFF if not using that feature.
post #11376 of 20242 Old 04-28-2012, 08:37 PM
SolApathy's Avatar
I use the network standby feature, once the system is locked up you cannot back out of anything.
The next time I finish using it I will immediately back out of the Net/USB input and see if that makes a difference.
post #11377 of 20242 Old 04-29-2012, 04:39 AM
ccotenj's Avatar
Liked: 101
Originally Posted by Strider- View Post
Unfortunately, your best bet is still to run a secondary Analog L/R pair from your source to the AVR. It's a stupid limitation that has no reason to exist, but it is what it is. For things like a cable/satellite STB, running the analog line avoids the problem (with the 3312) of using the optical and accidentally sending AC3 or DTS to zone 2, which will just result in white noise.
fwiw...
it is a limitation that is purely a financial choice by the cem's... probably a wise one, as it would add significant cost for a feature that would be used by a small minority...
it is not a limitation of hdmi...
- chris
ccotenj is offline
post #11378 of 20242 Old 04-29-2012, 06:22 AM
markie100's Avatar
Hi, could somebody tell me if it is possible to turn off " Airplay" on a 2312, as i was playing around with remote, caught the airplay button, & as my son had his ipod on in his bedroom, it connected & came through on full volume.
Thanks for any advice.
markie100 is offline
post #11379 of 20242 Old 04-29-2012, 07:35 AM
jdsmoothie's Avatar
Liked: 7286
post #11380 of 20242 Old 04-29-2012, 09:34 AM
darkhorror's Avatar
How is the sound quality of the 1712 vs something like a 3312 or 2312?
Or how about the older models like the 2809 or 3808?
darkhorror is offline
post #11381 of 20242 Old 04-29-2012, 10:12 AM
indio22's Avatar
Quoted: 21 Post(s)
Liked: 46
I am having a problem with my AVR-1712, where some buttons on the remote are not enabled while watching a movie. For example, I press the Menu or the CH Level buttons on the remote, but nothing happens. This has occurred several times while watching movies in PLII (networked via an Xbox from my HTPC). Other than this disabled button glitch, the movies seem to play fine.
The only fix I have found is this: hit the button for selecting sources, view the sources, and then hit the return button. Then magically the Menu and CH Level buttons are enabled. I am wondering if anyone else has run into this sort of glitch, where buttons on the remote that should be enabled, for some reason are not enabled?
indio22 is offline
post #11382 of 20242 Old 04-29-2012, 10:17 AM
jdsmoothie's Avatar
Liked: 7286
The Denon remote is a preprogrammed remote with the abilty to control other devices. If you want to control the AVR itself you must first press the "AMP" button.
post #11383 of 20242 Old 04-29-2012, 10:50 AM
indio22's Avatar
Quoted: 21 Post(s)
Liked: 46
I have never tried to use the remote for anything but controlling the receiver. But you think the remote could somehow on it's own switch from the AMP mode? I will do some testing to see if that is the case. If the solution is simply to press the AMP button when this situation occurs, before trying to press the Menu/CH Channel buttons, I can live with that. Thanks.
indio22 is offline
post #11384 of 20242 Old 04-29-2012, 12:26 PM
iSean's Avatar
I currently own a Yamaha V663. I am deciding whether or not to get the Denon AVR-2112CI. I am happy with my V663, but I would like a bit more options. I am worried that I may regret the purchase if I do decide to upgrade.
iSean is offline
post #11385 of 20242 Old 04-29-2012, 01:20 PM
RamHemiTX's Avatar
Is there a question that I am missing?
RamHemiTX is online now
post #11386 of 20242 Old 04-29-2012, 01:22 PM
spager's Avatar
Check page 1 of this forum. You will find a detailed description and features of all 12 series Denon Avr's. Also if you phone some online Dealers like Electron Expo, J&R and AV Science you will get a substantial discount.
spager is offline
post #11387 of 20242 Old 04-29-2012, 01:28 PM
mtmcd's Avatar
Originally Posted by spager View Post
In Sat/Cable go to Menu and in Input Assign select the component-rca you have assigned for your universe box and assign the component to any name source, so you may as well use the name source you are using which is Sat/Cable. Hdmi control can be on or off.
Go into Net/USB select Input Setup/Video/Video Select and select Sat/Cable and you should have video from your universe box while in Net/USB...Airplay.
Got it working! Last question on this topic: can I adjust the aspect ratio of the video input? The tv comes in widescreen mode and looks very non-HD...
mtmcd is offline
post #11388 of 20242 Old 04-29-2012, 03:32 PM
spager's Avatar
Try Input Setup/Video and scroll down to aspect. Also check your source and Tv Settings.
spager is offline
post #11389 of 20242 Old 04-29-2012, 04:33 PM
alokeprasad's Avatar
Quoted: 43 Post(s)
I am a refugee from the Onkyo TX-SR707 thread. My TX-SR707 just "died" (no sound from the speakers) 5 months after the warranty expired.
I am considering the AVR2312CI or AVR2112CI. The AVR2112CI is cheaper but I like the HDMI input in front to attach my videocamera.
I got burned (figuratively) by the Onkyo because of a (now) known hardware problem with them.
Are there any known hardware issues with the AVR2312CI or AVR2112CI?
Aloke
alokeprasad is offline
post #11390 of 20242 Old 04-29-2012, 05:17 PM
jdsmoothie's Avatar
Liked: 7286
The two known outstanding issues with some 2312CI units are listed in post #4 of this thread. Note all of the new XX13 models include a front HDMI jack.
post #11391 of 20242 Old 04-29-2012, 07:04 PM
Quoted: 43 Post(s)
Thanks for the reply. The XX12 models are much discounted compared to the new unreleased XX13.
I can't wait for XX13. The puny sound through my TV speakers is driving me up the wall.
PS: Does Denon monitor this AVS forum? or is there a different forum to communicate with Denon engineers?
post #11392 of 20242 Old 04-29-2012, 07:25 PM
jdsmoothie's Avatar
Liked: 7286
It's a public forum so anyone is able to monitor the threads and to communicate with Denon you can call the Denon CSR line.
post #11393 of 20242 Old 04-29-2012, 07:28 PM
Quoted: 43 Post(s)
I was wondering where the responses from Denon in Post # 4 have been collected from.
post #11394 of 20242 Old 04-29-2012, 07:39 PM
jdsmoothie's Avatar
Liked: 7286
I summarize the information members posting in this thread have received from Denon CSRs as well as information I have received from my contacts at Denon.
post #11395 of 20242 Old 04-29-2012, 08:07 PM
rikemomo's Avatar
hey all-
I've been thinking about getting a new Denon to replace my current 2808CI, and I just noticed that Amazon just slashed the price of the 2312CI from the list ($849) to $599. When I checked last night, the price was $849! Glad I slept on it!
The 2112CI is currently at $470, down from $649 list.
Apologies if one is not supposed to talk about price on this particular board, it's just that I figured folks who were thinking about 'em would be interested to know of this very recent price drop..
mike
rikemomo is offline
post #11396 of 20242 Old 04-29-2012, 08:34 PM
CitznFish's Avatar
Correct. Currently the sub gain is too strong so you must lower it's gain/volume such that the AVR can calibrate it to the 75db test tone.
Yes, it's very possible that with the AVR able to put out a stronger signal, will indeed resolve your current issue.
ok, by turning the gain down to about 20% it finally registered as -7.5db in audessy. I will see what happens now. After setup I upped it to -6.5db
CitznFish is offline
post #11397 of 20242 Old 04-29-2012, 10:24 PM
Klynn's Avatar
Well, after much deliberation, I finally settled on a 3312CI from Electronics Expo (Best price I could find). I'm excited to finally join the family after having read nearly this entire thread. Between JD and Batpig I don't think there's any question I could have that could go unanswered. They should really pay you guys.
Klynn is offline
post #11398 of 20242 Old 04-30-2012, 04:10 AM
jdsmoothie's Avatar
Liked: 7286
That's okay ... after running AUTO SETUP, you can raise the sub channel level via the remote up a few db to suit your preference.
post #11399 of 20242 Old 04-30-2012, 05:43 AM
darkhorror's Avatar
Originally Posted by rikemomo View Post
hey all-
mike
May I ask what you are looking to get out of the 2312 that you didn't get from the 2808ci. Also I would like to hear what you think soundwise between the two after you get it.
post #11400 of 20242 Old 04-30-2012, 06:45 AM
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
Auddessy in my 889 set my Polk PSW10 to 0dB. I was thinking of dropping it by a dB or two but it does sound good. I know the PSW10 doesn't get any respect in these parts but it works pretty well for me..
Sammy2 is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
