The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 425 - AVS | Home Theater Discussions And Reviews
post #12721 of 19630 Old 05-26-2012, 11:47 AM
captbly's Avatar
Originally Posted by BIslander View Post
Older PS3s bitstream standard DD 5.1 and DTS, no problem. They cannot bitstream the newer lossless audio codecs. So, if you are not seeing the regular codecs on your AVR display, it's a setup problem with your PS3. And, as jdsmoothie indicated, you get the same audio quality with the lossless codecs when they are decoded by your player. The exact same PCM is produced no matter where the decoding is done.
Originally Posted by hdSigmaChi View Post
Anyone have two blu ray players just so when you play movies you don't see "Multi Ch In" on the receivers display ? My older PS3 does not' allow my Denon to display Dolby Digital or DTS .. Kinda bothers me ..
I had the same issue when I first setup the system. I had to reset the PS3 before I got the DD 5.1 to work. While the ps3 is on standby mode press and hold the on button for about 5 seconds and it should beep twice
captbly is offline
post #12722 of 19630 Old 05-26-2012, 11:53 AM
Selden Ball's Avatar
Quoted: 1296 Post(s)
Liked: 691
Remember that being able to see the AVR decode the audio means that you cannot hear the menu sounds or the secondary audio channels. Of course, there aren't all that many BDs with secondary audio and video streams, but I enjoyed watching the one on TinTin.
Selden
Marantz SR7009+MM9000/Atmos 7.1.4 (FH+TM:DefTech PM1000)/LCR+TM amped
Selden Ball is offline
post #12723 of 19630 Old 05-26-2012, 12:07 PM
Szeppelin75's Avatar
Originally Posted by johnsills1 View Post
Ok, I need some tech help..... Nothing was wrong with me Denon before I attempted the update this morning. Now I've been stuck in an EIMG Loop for hours. I've tried the Update Retry route to no avail. Can someone give me some guidance as to what I need to do to fix this. I'm dying here......
I've already reset my router and that didn't help the situation. Thanks in advance
Same here, anyone? Batpig? Jdsmoothie?
Szeppelin75 is offline
post #12724 of 19630 Old 05-26-2012, 12:13 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4040 Post(s)
Liked: 2255
A few others that were having issues with the update said it eventually completed so you can either let it go, or you can simply unplug the AVR for a few minutes, power back on, and try the update again.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #12725 of 19630 Old 05-26-2012, 12:17 PM
O.K., just upnlugged it and pluged it back in after a few minutes, it says now "Update retry" and it stays there, guess i'll leave it like that to see if it updates.
post #12726 of 19630 Old 05-26-2012, 12:31 PM
Well it took a few minutes but it's updating now. Thanks again.
post #12727 of 19630 Old 05-26-2012, 12:36 PM
B.Ellis's Avatar
Worked fine for a few hours, now can not get the gui to show up, the TV just says no signal.
Cable is good
Tried microprocessor reset
Tried unplugging it for a while
Any setting that would have caused this? Only had it one day.........
B. Ellis
B.Ellis is offline
post #12728 of 19630 Old 05-26-2012, 12:39 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
Ensure the HDMI cable connections are securely fitted into the jacks.
post #12729 of 19630 Old 05-26-2012, 12:59 PM
saj2001ind's Avatar
Hi I got stuck too, did you finally manage to update it ?
saj2001ind is offline
post #12730 of 19630 Old 05-26-2012, 01:02 PM
johnsills1's Avatar
My advice is to just let it keep going. After I held the power button for 5 seconds and did the update retry, I just walked away and let it do it's thing. It finally worked itself out. It sure did scare the crap out of me though for a while.
johnsills1 is offline
post #12731 of 19630 Old 05-26-2012, 01:05 PM
saj2001ind's Avatar
I am stuck too at the EIMG...took the plug off and on , it retried and again same looping...how long did it finish in ur case ?
post #12732 of 19630 Old 05-26-2012, 01:09 PM
B.Ellis's Avatar
They are secure. Nothing....
B.Ellis is offline
post #12733 of 19630 Old 05-26-2012, 01:16 PM
Well it did, but now it's been stuck in that EING phase for 10 minuts it goes 3 minutes, 2, 1 and then it starts with 3 minutes again. I tell you, this is frustrating.
post #12734 of 19630 Old 05-26-2012, 01:22 PM
fjccurry's Avatar
I'm in the same boat, did the press standby for 5 secs and also power recycle - same results. From what I gather you just have to wait it out and it will eventually complete - so far I've read it can take up to 4 hrs...
fjccurry is offline
post #12735 of 19630 Old 05-26-2012, 02:40 PM
Well, mine finally finished. Guess you just have to wait. Good luck.
post #12736 of 19630 Old 05-26-2012, 04:24 PM
darshparsh's Avatar
Oh man, what a terrible experience. Too bad Denon couldn't figure fix the status bar. I read that you could pause the update by pulling out the network cable on the 1912avr, luckily that stopped it. Reset the Auddysey EQ settings and seems to be back to normal. Attempting an update overnight but I don't plan on keeping this thing running during the day. Four hours for the update eh? What was the consensus for people that got it it to work - how long did it take? 2-3 hours?
darshparsh is offline
post #12737 of 19630 Old 05-26-2012, 04:32 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
If you review all the posts in this thread for the past few days, you'll note that the update took anywhere from about 1-4 hours; however, in every case the update eventually completed. As I noted in post #6 of this thread, if the update hasn't been started yet, it's best to wait a week or so to let Denon work out the bugs in the update as it normally shouldn't take more than about 30 minutes to load.
post #12738 of 19630 Old 05-26-2012, 04:35 PM
QuiGonJosh's Avatar
Quoted: 120 Post(s)
Liked: 64
Quick question - when the 1712 is on standby should the green light turn red like it did on my 590 or just go off completely? Mine goes off completely, but I just want to make sure this is right. Thanks.
QuiGonJosh is online now
post #12739 of 19630 Old 05-26-2012, 04:37 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
It only turns red when you have HDMI Control set to ON.
post #12740 of 19630 Old 05-26-2012, 04:38 PM
QuiGonJosh's Avatar
Quoted: 120 Post(s)
Liked: 64
Cool. Thanks.
post #12741 of 19630 Old 05-26-2012, 04:50 PM
Sammy2's Avatar
Quoted: 147 Post(s)
Liked: 202
Guess I won't be doing a f/w update to my 2312ci for a while..
Sammy2 is offline
post #12742 of 19630 Old 05-26-2012, 04:53 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
With the 2313CI due to be released in a week or two, the 2312CI won't likely have too many more updates to have to worry about.
post #12743 of 19630 Old 05-26-2012, 04:56 PM
Sammy2's Avatar
Quoted: 147 Post(s)
Liked: 202
So far it is working great so I don't see a need for any.
Sammy2 is offline
post #12744 of 19630 Old 05-26-2012, 06:04 PM
alokeprasad's Avatar
It was too good to last.
Like before, the AVR is controllable via web browser (and is therefore connected to my PC) but Airplay option has disappeared from iTunes.
Any idea what could cause this inconsistent network behavior?
alokeprasad is offline
post #12745 of 19630 Old 05-26-2012, 06:05 PM
BBCheese's Avatar
I just got the Denon 1612 and I think it's great so far.
I ran the calibration but I moved the subwoofer by two feet afterwards.
Can I just adjust the distance manually or should I run the audyssey calibration again? Or can I just leave the setting alone? Which was further than the actual distance.
BBCheese is offline
post #12746 of 19630 Old 05-26-2012, 06:25 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
Have you tried the suggestions listed in the Troubleshooting section of post #3?
http://www.avsforum.com/avs-vb/showt...p?t=1334369#L1
post #12747 of 19630 Old 05-26-2012, 06:27 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
Any movement of either sub/speakers or furniture requires a rerun of Audyssey. Also note the "distance" shown for the sub is actually a "delay" setting to allow for the filters in the sub. Also if you're able to move the sub about the room, try doing the "sub crawl" to determine the best location.
post #12748 of 19630 Old 05-26-2012, 06:31 PM
BBCheese's Avatar
Alright thanks. I'll just rerun the calibration tomorrow. Just moved the sub from a corner to next to between the right speaker and TV.
And just to double check. The best settings are 120hz for sub crossover, and 60-80 for the rest right?
BBCheese is offline
post #12749 of 19630 Old 05-26-2012, 06:34 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2255
The best setting for the sub(ie. LPF for LFE) setting is the factory default setting of 120hz while the best setting for the speakers is whatever the AVR sets them to unless it's < 80hz in which case you would change the speaker to SMALL and "raise" the crossover to either 60hz or 80hz.
post #12750 of 19630 Old 05-26-2012, 06:39 PM
BBCheese's Avatar
Thanks. Just one more quick question. Do I move my couch to set up my mic stand or try to set it up on my couch and surrounding area?
BBCheese is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
