The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #12781 of 20176 Old 05-28-2012, 09:52 AM
lseguy's Avatar
Hi All:
Purchased my 1912 from Overstock.com (Refurb) back in december. Just got around to hooking it up in my new home a couple months ago. I had it hooked up to 3 different sets of speakers via good speaker wire and banana plugs. I have the 3 sets connected to Front, surround, and Amp assign. two zone configuration. The speakers are built into the ceiling with wiring running through the walls. All was working fine (I only use the Denon for audio..Airplay and Internet Radio at this time) until 2 days ago when the Denon began shutting down with the flashing red light issue about 30 minutes after use. the receiver is in an open, air conditioned room with plenty of ventilation. Volume on the Denon is set to about 60%..same as always. No other variables have changed from prior to two days ago. Checked all wiring from the Denon to the wall outlets and no stray strands are touching, all banana plug ends are fine/intact.
I've performed a processor reset to no avail.
Google searches took me to various tech answer for pay type forums where it appears this issue seems to be somewhat common with 1912's..and repairs are required by authorized service centers.
Is this accurate? Since my in home wiring hasnt been touched since move in and since the setup was working perfectly fine..sometimes with all 3 sets of speakers playing across both zones just fine for hours..Im guessing the most likely suspect is my refurb 1912.
Correct?
lseguy is offline
post #12782 of 20176 Old 05-28-2012, 09:56 AM
BeechTom's Avatar
Millot, welcome to the forum. I've learned a lot from AVS over the years, though I haven't posted much. My suggestion would be to go with the 1712 because of the Audyssey MultiEQ XT vs. the 1612's next lower version of Audyssey (better hurry, they are selling out fast) and pass on the Pioneer SW-8 sub. I have the BS-21's and CS-21 and love them, but even though I consider Andrew Jones a genius, building a budget subwoofer has certain laws of physics, size and power, that greatly differ from the rest of the speaker system, and even Andrew can't bend those enough to get a truly good subwoofer for under $100.
There is a good thread in the subwoofer forum by Jim Wilson you might check out, Budget Subwoofers Under $300. I would post over there with your room measurements and listening habits. Even if you have to wait to save some more money for a true subwoofer, that would be better than throwing money at the SW-8 (IMHO). And then, if you truly come to appreciate true bass, you can look at the internet direct companies and their offerings ($400+). Watch out, it is a slippery slope! This is coming from a former Yamaha HTIB sub to an SVS PC-12NSD, it still makes me smile years later. And there's a lot more slope for me to slide down... Good luck!
BeechTom is offline
post #12783 of 20176 Old 05-28-2012, 11:00 AM
jdsmoothie's Avatar
Quoted: 12208 Post(s)
Liked: 5559
Originally Posted by bladerunner6 View Post
Thanks for the info.
So what do I need to do to make this work for me. I understand I probably need to set up the system initially to 5.1 but then what do I need to do to switch back and forth.
While my wife and I are intelligent people, I don't want this to be a complicated process to do whenever we trot into the dining room to eat dinner or play a game.
Connect the Front B speakers to the SBL/SBR speaker posts. Set to "Front B". Set to "B". Then press the "DIRECT" button on the remote when you want to use Front B (or setup a Quick Select for STEREO mode).
jdsmoothie is offline
post #12784 of 20176 Old 05-28-2012, 11:14 AM
jimbo1mcm's Avatar
I use my Iphone 4 with Airplay quite a bit with my Denon 2312CI. I am intrigued by the Galaxy s3. It will be available in the US soon, and has been released in other countries. My question is about the All Share Play feature. Obviously, the first question is, will it work with the Denon 2312 CI ? Will it also have the same music quality as the IOS feature? If anyone has a new S3, please post. Thanks.
jimbo1mcm is offline
post #12785 of 20176 Old 05-28-2012, 11:14 AM
jdsmoothie's Avatar
Liked: 5559
Originally Posted by lseguy View Post
Hi All:
Correct?
The most common reason for the AVR to shut down in protection mode is due to either a loose speaker wire from one post touching another post or, in your case, with in wall wiring, it's possible a nail has broken the speaker wire casing somewhere inside the wall. Try using a multimeter to check the continuity of the speaker wire to ensure there's no short. Or if not available, disconnect all speakers and add one back at a time for 30 minutes each to see if the issue is the result of a particular speaker. If warranty work is required, AFAIK Overstock.com is not an authorized Denon reseller so there would be no warranty.
post #12786 of 20176 Old 05-28-2012, 11:21 AM
Millott's Avatar
Thank-You, Beechtom.
I had figured much the same thing in regards to that Sub being worth while after the reading i've been doing the last months. I must admit its a little over-whelming just how much there is to learn on the audio side of this Home Theater obsession as i've been basically consumed by the video side of things in my pursuit over the years do to some bad luck with my TV choices when I first got into this.
I had originally planned to get involved in upgrading my audio back when I first grabbed my Onkyo SR-606 as Circuit City was closing its doors back around 08?
I then started to have issues with our JVC HD-ILA set (my first set that I skipped the warranty on ) which was followed by our bedroom sets also dying around the same time period (one of them was due to go but one wasn't) so I was scrambling for a bit. Of course this lead to me being forced to grab a low budget solution TV for my HT and my first Plasma a Panny 50X1 which abruptly turned me into a plasma guy so it all worked out on that end.
That said once I had bought some short term solutions for bedroom sets with 32" Toshiba and Samsung 720P LCD models my HDMI went out on the Onkyo just as I was getting set to upgrade my speakers.
At this point I turned my attention towards getting back up to a 1080P display and found a steal of a deal on a 50VT20 open box from BB at the begining of the year for the same price I bought my 50X1 for back in 09 so I pulled the trigger.
So only now have I finally turned my attention back to the audio side of my home theater, first came the C-21 as i'd always had an issue with the dialog not being crisp enough through the old center speaker and it was a night and day difference just wow but it over whelmed my other speakers and even my untrained ears could tell the soundstage was poorly balanced.
I then came across newegg running the promo code on the BS-21's for $50 a pair and pounced on it to get my fronts and side speakers for a 5.1 set up.
Now i'm focused on in on getting back to the HD audio codecs for my new speakers. As you said the 1712 seams like the more ideal reciever for me but i'm kinda torn on the idea because i'm not sure I can get $400 up before they sell out and I was floored by the HD codecs when I had them even on crap speakers so i'm sure to be thrilled with the 1612 plus the wife already wants to kill me....
She doesn't even know i'm planning to grab either a 65VT50 or 65VT60 next year around April or May depending on if the VT60 hits 9G Kuro blacks.
Millott is offline
post #12787 of 20176 Old 05-28-2012, 11:28 AM
bajanjack's Avatar
Quoted: 18 Post(s)
When trying to do the latest firmware update on my 2112, after a couple of minutes the osd tells me it's "connected" to the server, and goes to "update". It indicates 21 minutes. However when I press enter on the remote nothing happens. The return and "menu" buttons work and gets me out of the screen. I have read the previous posts-maybe I'm lucky I haven't been able to do it?
bajanjack is offline
post #12788 of 20176 Old 05-28-2012, 11:40 AM
jdsmoothie's Avatar
Liked: 5559
post #12789 of 20176 Old 05-28-2012, 11:45 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
I understand the need to connect the speakers.
Then, every time I want to listen to the speakers in the other room, I have to do the following three steps?
And then to switch back, I do what?
Thanks for the help, I am pretty serious about buying this, but I want to be sure what we need to do before I ask the wife about this.
bladerunner6 is offline
post #12790 of 20176 Old 05-28-2012, 12:05 PM
jdsmoothie's Avatar
Liked: 5559
No ... every time the unit is receiving a STEREO 2.0 signal and you want to pass it to the Front B speakers, just press the button on the remote if it doesn't switch to them automatically.
post #12791 of 20176 Old 05-28-2012, 12:26 PM
Quoted: 20 Post(s)
Liked: 59
I use the feed from our Dish Network through an HDMI input for a lot of music in the dining room.
So even then, just press the button to switch to the dining room?
And then to switch back to the living room for 5.1 or stereo, do what?
post #12792 of 20176 Old 05-28-2012, 12:30 PM
jdsmoothie's Avatar
Liked: 5559
You can press either the Movie or Music buttons and select whichever mode you want to use, STEREO or DD PLII/5.1.
post #12793 of 20176 Old 05-28-2012, 12:59 PM
Quoted: 20 Post(s)
Liked: 59
Thanks for your help!
I think this is the one I am probably going to buy, assuming I can figure out a good way to wire it up to our network.
post #12794 of 20176 Old 05-28-2012, 02:40 PM
bajanjack's Avatar
Quoted: 18 Post(s)
Geez.....right in front of me and I missed it....thanks!!!
post #12795 of 20176 Old 05-28-2012, 03:16 PM
Quoted: 20 Post(s)
Liked: 59
Thanks for all the help.
I ordered one today (the dealer was out but they have some in the warehouse) for $320 plus tax (339.20)
I think this will work out well.
post #12796 of 20176 Old 05-28-2012, 03:27 PM
Szeppelin75's Avatar
Dumb question:
I know this has been answered in this forum before but..
I Have a 1912
If i watch TV or any other source (Google TV, Internet radio, etc) and i select the following: Dolby Digital, DTS Neo:6, Dolby Pro Logic in the audio output option i only get audio from the center speaker; if i select Multi Channel In or Multi Channel stereo i get sound from all speakers (fronts, center and surrounds) , but it's the same signla from the fl/fr speaker.
'Am i doing something wrong? i thought if you selected The Dolby Digital or Dolby Pro Logic you could still get sound from all speakers.
So in order to get sound from all speakers i have to use the Multi Channel stereo option?
'am i correct or just haven't tweaked it enough yet?
Szeppelin75 is offline
post #12797 of 20176 Old 05-28-2012, 05:42 PM
anuj1450's Avatar
Is there any option for networking with the Denon 1612? It's pretty much at the top of my price range right now, and I'd love to be able to control it via Android if possible..
anuj1450 is offline
post #12798 of 20176 Old 05-28-2012, 06:01 PM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
I have a question about using 7.1 on a 5.1 audio track. For instance on DTS-HD MA tracks I can either use "DTS-HD MA (SB On)" or Neo. Which one is preferred? If someone could point me to a link that explains this it would be much appreciated. Thanks.
QuiGonJosh is offline
post #12799 of 20176 Old 05-28-2012, 06:11 PM
jdsmoothie's Avatar
Liked: 5559
Which one is preferred only you can decide.
post #12800 of 20176 Old 05-28-2012, 06:13 PM
jdsmoothie's Avatar
Liked: 5559
Originally Posted by Szeppelin75 View Post
Dumb question:
I Have a 1912
Something is wrong somewhere .... reset the microprocessor (p. 125) and start the setup over again.
post #12801 of 20176 Old 05-28-2012, 07:08 PM
You shure? am i suppose to hear all the speakers in all the formats? what's Multi channel for then?
post #12802 of 20176 Old 05-28-2012, 08:08 PM
MCF34's Avatar
Quoted: 63 Post(s)
Got my 2312CI hooked up today and thus far I am VERY impressed. The two channel stereo via Pandora is WAY fuller and richer than my old HK AVR 635. Dolby Digital also sounds much fuller and richer as well. And I have not even run Audyssey yet!!! One question. I plugged our Wii into the DVD component in and the DVD audio in and can't figure out how to assign the source. Assigning sources for the DVR and PS3 were easy because they are HDMI. Can't figure out how to assign non HDMI sources. Thanks!! Can't wait to run Audyssey and watch my test scene (Matrix helicopter scene) to see how it sounds compared to old HK.
Jutter is gone..zipadeedoodah zipadeeday!!!
MCF34 is offline
post #12803 of 20176 Old 05-28-2012, 08:56 PM
rajkumark's Avatar
I connected my MLT-2 speakers with 2312. I ran Audussey AUTO SETUP and calibrated all the speakers/SW for 8 positions. Updated the Firmware yesterday without any issues. I set all the speakers to SMALL.
I connected my Laptop to 2312 using HDMI/HDMI V-AUX [2312] front panel and watched TROY movie. I have set Dyn Vol to MED. For better sound, I increased the sound upto 0 dB. I thought I can get better sound with 45dB atleast. Also SW is not that boomy.
Am I doing mistake somewhere in configurations? Please let me know if I need to change some settings.
Thanks, Raj
rajkumark is offline
post #12804 of 20176 Old 05-28-2012, 09:24 PM
BrTalip's Avatar
Hello guys. Sorry for slipping this question in here. I had posted the question in the speakers forum but nobody responded. It might have been answered before, specifically because people have had their speakers blown out or their receivers cut off. My situation is a little different.
I recently bought my Denon AVR 1712 and am waiting for my RC Micros to be delivered to me. The Denon is rated from 6-16 ohms and I believe the Micros are 8, so they match.
However, while waiting, I borrowed a friends HTIB speakers to give the AVR a test run. A realized a day later that the speakers were @ 4 ohms. The speakers were working well the entire time and to this moment sound great. The receiver doesn't seem to be heating up. But I noticed that my receiver wasn't exactly co-operating. At times it would not play sound when I started up my PS3, or wouldn't recognize audio/video through some HDMI ports. Sometimes turning the power on and off would fix everything. I did a hard reset, but now I have to reset the remote to open the GUI almost every time I change inputs, and audio doesn't always play when HDMI pass through is activated.
My question is, can a receiver be damaged before it is forced to shut off (by what I assume would be an overheat). And would overloading a receiver cause these finicky complications or is it a defective receiver? Has anyone had these problems before?
TL;DR: Don't know if pairing 4 ohm speakers with 8 ohm receiver messed up my receiver, because audio is fine, but receiver is reacting strangely.
BrTalip is offline
post #12805 of 20176 Old 05-29-2012, 01:09 AM
adwa's Avatar
Amazon has the 3312ci for $736.29 by World Wide Stereo which I believe is an authorized dealer. Is this a good price considering the 3313 is just around the corner?
adwa is offline
post #12806 of 20176 Old 05-29-2012, 02:26 AM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
Cool. I didn't know if there was a "right" or a "wrong" way to go about it. Thanks.
post #12807 of 20176 Old 05-29-2012, 04:26 AM
sytyguy's Avatar
Buy.com has it for $697.99
sytyguy is offline
post #12808 of 20176 Old 05-29-2012, 04:29 AM
jdsmoothie's Avatar
Liked: 5559
A lot of folks wonder the same thing. As is the case with most AVR settings, it's personal preference that matters, not what others prefer.
post #12809 of 20176 Old 05-29-2012, 04:31 AM
jdsmoothie's Avatar
Liked: 5559
Likely yes as the 3313CI will be selling closer to MSRP for a little while and yes, WWS is an authorized reseller so the warranty would be valid.
As it turns out, WWS is the seller on Buy.com as well, so this would indeed be the better buy.
post #12810 of 20176 Old 05-29-2012, 04:36 AM
jdsmoothie's Avatar
Liked: 5559
No, the speakers didn't cause this issue. In fact, Denon AVRs can power 4Ω speakers just fine at average volume levels. Note that the "AMP" button must be pressed before pressing the "MENU" button to get the AVR GUI to display. Try using other HDMI inputs as well as swapping out the cables, otherwise you may want to exchange the AVR.
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
