The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #1561 of 19998 Old 06-17-2011, 05:54 PM
ChrisDixon's Avatar
Originally Posted by htpc-geek View Post
The 3312 will be a really big leap forward for me I just wish it had one or two more opticals, but they seem to be going out of fashion in a hurry these days.
You could always use something like this:
http://www.amazon.com/gp/product/B0002GV876
It converts optical to coax, and is only $20. I used one of these for a year or two without issue. The only downside is that it's powered so you'll need another spot on your power strip.
ChrisDixon is offline
post #1562 of 19998 Old 06-17-2011, 05:56 PM
nuttybardude's Avatar
As a reminder, before posting a question in this thread, please review posts #1-#6 on page 1 as your question will likely already be answered there. Thanks.
hehe well now i feel pretty dumb. So i guess i had the hdmi handshake problem with my xbox to denon. So now i have the hdmi from xbox directly to tv, and i have an optical running from tv to denon for audio. Question is how do i get my 1912 to play the audio from the optical cable?
nuttybardude is offline
post #1563 of 19998 Old 06-17-2011, 06:07 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 7363 Post(s)
Liked: 3391
The way you have it currently configured, you would select the "TV" source on the 1912 which is what the optical input defaults to; however, the reason the xBox wasn't working was more likely a setting on the xBox rather than an HDMI handshake so you could actually try to get that connection to work correctly.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Sony, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
post #1564 of 19998 Old 06-17-2011, 06:11 PM
JChin's Avatar
Quoted: 244 Post(s)
Liked: 175
Hi nuttybardude, I agree with jdsmoothie that its possible with a setting with the xbox (try a xbox reset).
Otherwise for audio from tv to receiver, use ARC (on panny) instead of optical cable.
JChin is offline
post #1565 of 19998 Old 06-17-2011, 06:16 PM
supie's Avatar
Hi,
I am considering the AVR-1912 or AVR-2112 and after a lot of research, and calling Denon, I cannot find the answers to the following:
Can I use my Universal Remote such as Harmony or URC MX-980 without any problems, after doing the programming?
How much heat does it generate? Can I install the Receiver in a ventilated cabinet with at least 8 clearance on top and 4 sides and back?
Did anyone compare the Onkyo TX-NR609 with Denon AVR-1912/AVR-2112, if so why did you prefer the Denon?
Thanks in advance
Supie
supie is offline
post #1566 of 19998 Old 06-17-2011, 06:19 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3391
1. Yes, Harmony remotes work just fine with Denon AVRs. You can download your model from the Logitech data base.
2. Denon AVR's don't generally generate much heat (luke warm) so the amount of ventilation space you're providing is more than sufficient.
3. Nothing below the 709 will compare to Denon AVRs as they only use Audyssey 2EQ which has at least 1/2 the number of EQ filters and does no sub EQ.
post #1567 of 19998 Old 06-17-2011, 06:49 PM
Kalani's Avatar
Quoted: 108 Post(s)
Liked: 26
Except it won't worth with my Harmony One. All of my gear is in another room in a closet on the other side of the wall from my TV. Everything is controlled perfectly with my Harmony One and an IR repeater, and I love how it works today, and I'm not going to get up and go in the other room to switch an input.
I don't have the Denon unit yet, but I will be getting the 3312 very soon. It is one optical input short of what I need, but I think I've found a way to make it work anyway. Just trying making sure it'll all work before I pull the trigger. I'm running off an old Sony STRDA555ES from 10 years ago with 4 optical inputs.
Coming from a Sony STRDA1000ES myself, I can pretty much promise you'll love the 3312.
Kalani is offline
post #1568 of 19998 Old 06-17-2011, 07:00 PM
Dextar's Avatar
Do you think 599 is too much to pay for the 2112?
Dextar is offline
post #1569 of 19998 Old 06-17-2011, 07:26 PM
supie's Avatar
Hi,
Thanks for the replies.
Another question, I have an iPhone 3GS and 400 or more songs and some music videos on iTunes. I am wondering if you can organize and play songs on iTunes so that the AVR-1912 or AVR-2112 so it can select a single playlist like; Favorites or Jazz or Rock, etc. If not, how does Airplay work on the Denon can you select groups or is it Play All or Select One Song and/or can you do random play?
My Equipment:
TV- 60 Pioneer PDP-6010FD w/Cable Card
PVR - Tivo S3 -- SD-1561 / HD-165 Hours
DVD - Sony DVP-NS75H
Blu-Ray DVD - Sony BDP-S550
A/V Recv - Sony STRDE945 (to be upgraded soon)
CD Player 300 CD's - Pioneer PDF1007
URC MX-980
Supie
supie is offline
post #1570 of 19998 Old 06-17-2011, 08:05 PM
Kalani's Avatar
Quoted: 108 Post(s)
Liked: 26
Yes. Try Electronics Expo, and see what you can talk them down to (have to call it in, no net sales). With MSRP up $100 from before, you probably won't get the $399 deals others did, but you should still be able to do better than $599.
Kalani is offline
post #1571 of 19998 Old 06-17-2011, 08:06 PM - Thread Starter
batpig's Avatar
Quoted: 2858 Post(s)
Liked: 2754
^^^^^ supie -- if you are using Airplay the Denon doesn't control anything, it just plays what you send it. It's effectively just a "speaker" for the iTunes content. All the control (e.g. selecting a playlist) will be done on your iPhone, iPad, or computer.
if you plug the iPhone into the USB port of the receiver, then you can navigate the GUI on your TV screen using the Denon remote and select artists, playlists, etc.
just depends on your preferred method of control.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #1572 of 19998 Old 06-17-2011, 08:17 PM
RyanA3's Avatar
Are you able to use hdmi on any of your components?
Photo Tour of my home - 2ch, 3.1, & 5.1 builds
But a whole new house is getting wired now!
New media room shaping up: Sony XBR70X850B 4K, Denon AVR-X4100W, Studio 60s
Thanks to all the AVS members. This is a great community.
RyanA3 is offline
post #1573 of 19998 Old 06-17-2011, 08:45 PM
Snootch4183's Avatar
So i went out and bought a wireless gaming adapter for my 2112ci, and i can't seem to get a proper connection with it. I tried using a 2nd router as an access point and its giving me the same problems. With DHCP on, it gives me an ip address that isnt part of my dhcp pool and gives me a wrong subnet mask (255.255.000.000). I just can't seem to figure it out. The gaming adapter works fine with my 360 and PS3. (its a trendnet TEW-647GA)
[Edit]-I also tried setting a static ip and resetting the processor, with no luck. Some more info if its helpful: Im using a linksys e1200, with comcast internet.
Any help is appreciated.
Thanks in advance
Snootch4183 is offline
post #1574 of 19998 Old 06-17-2011, 08:59 PM
htpc-geek's Avatar
Great to hear! I've been wondering how much of a difference it really is. The ES Sony has been a trooper, but I know things have come a long way. I appreciate the reassurance.
Denon: AVR-2313CI
Definitive Technology: R/L: Mythos 2, C: Mythos 9, S: ProMonitor 1000's
SVS: PC-2000
Samsung: PN58C8000 Plasma
Misc: Dish, Apple TV, PS3, Mac mini w/ Plex, Harmony One Remote
htpc-geek is offline
post #1575 of 19998 Old 06-17-2011, 09:10 PM
Boofster's Avatar
Originally Posted by batpig View Post
it's not just the PS3, people have tested with other Blu-ray players. This would indicate that it's clipping BTB/WTW on any source.
Some of us are able to reproduce the full range (0-255) on TV's such as the VT30. I understand movies are pre-clipped but things like the PS3 games + gui and PC media centers are still in full range. I am not happy about this.
Boofster is offline
post #1576 of 19998 Old 06-17-2011, 09:38 PM
Foos-Man's Avatar
Quoted: 17 Post(s)
Electronics Expo quoted me $599 for the 2312 last week.
Foos-Man is offline
post #1577 of 19998 Old 06-17-2011, 09:53 PM
theanimala's Avatar
I thought I was the only old guy here. Just upgraded from a strda30es to a 991 a few weeks ago. To he honest, it took a while to get used to the new more accurate sound after using audessey, but now I really do love it!
theanimala is offline
post #1578 of 19998 Old 06-17-2011, 10:11 PM
jake9's Avatar
Quoted: 14 Post(s)
That's a sweet deal. I imagine you have to call to get this price??
5.1 System
Denon AVR-2312CI | Oppo BDP-105D | Martin Logan Dynamo 1000 | Energy Take Classic | Toshiba 42RV530U HDTV
2.1 System
Oppo BDP-105D | Parasound Halo A 21 | Parasound New Classic 2100 | Rega RP-3 | Martin Logan Theos | Martin Logan Dynamo 1000
jake9 is offline
post #1579 of 19998 Old 06-17-2011, 10:38 PM
**OptimusPrime**'s Avatar
Originally Posted by **OptimusPrime** View Post
Anyone do a video quality comparison from last years' models? I read a review that says the picture quality was "blurry" on a satellite feed though the 1912. However, no info on whether or not it was through HDMI or component cable.
With Father's Day coming soon, and my birthday right around the corner, I will be in receipt of several BB gift cards and RZ certificates...I am contemplating either the 1912 or the 2112 for my 7.1 setup. Anyone experience any kind of video issues on the 1912? My buddy has a 791, and says the video quality is outstanding. I am wondering how both these models compare.
Based on what I am reading in this thread, it seems that BB is overpriced on both the models I'm looking at. Suggestions?
**OptimusPrime** is offline
post #1580 of 19998 Old 06-17-2011, 11:06 PM
Dextar's Avatar
That's my problem too, I'm limited to Best Buy. I got a 10% off coupon but the 2112ci is 649 at BB so it only brings it down to 584+tax
Dextar is offline
post #1581 of 19998 Old 06-17-2011, 11:46 PM
mariob33's Avatar
Quoted: 46 Post(s)
Liked: 35
Send a message via Skype™ to mariob33
You can negotiate them down. Should be able to et it down to 550-575 easily. They need. The business.
In search of video bliss...
mariob33 is online now
post #1582 of 19998 Old 06-18-2011, 12:35 AM
Is that true?? I've asked about price matching. They used to do it, but I was recently told they can now only price match with "real" brick and mortar stores (and within a certain distance)...not online. If this can be done, I'm ready to wheel and deal.
post #1583 of 19998 Old 06-18-2011, 12:59 AM
Boofster's Avatar
You can probably call Chris @ Cleveland Plasma (board sponsor up top) and he'll give you a better deal than anyone else
Boofster is offline
post #1584 of 19998 Old 06-18-2011, 01:38 AM
aforkosh's Avatar
1. The HDMI from SAT to AVR is the best option as it passes both video and audio to the AVR. If you get an HDMI handshake issue and it won't work correctly, then connect the HDMI from SAT to TV directly with optical from SAT to AVR (for HDMI 1.3 TV) or use ARC (HDMI 1.4 TV).
In the past, many TVs would only pass DD5.1 only from their own tuners and components over an optical connection to the receiver. Thus if you connected a cable box directly to a TV and an optical cable from the TV to the Denon, you would only get stereo sound even if cable box was sending DD5.1. Is this still a problem for TVs supporting ARC or will they now pass DD5.1 from any connected source to both ARC and the optical cable?
Alan Forkosh
Oakland, CA USA
aforkosh is offline
post #1585 of 19998 Old 06-18-2011, 02:22 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3391
Many will now pass DD 5.1 (and some even DTS 5.1) from any connected source.
post #1586 of 19998 Old 06-18-2011, 02:32 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3391
Overpriced? No, rather like most of the authorized resellers they sell at MSRP. Gift cards can be cashed in using this site.
Why does that limit you? Some authorized resellers offer from 20-30% discounts ... however, you must call them to get their best price.
post #1587 of 19998 Old 06-18-2011, 04:53 AM
Slickman's Avatar
Quoted: 83 Post(s)
Liked: 56
Me either, and almost every problem I hear about Denons has to do with video. Yes, they do have great audio, but if the video isn't up to snuff then it's a waste.
Slickman is offline
post #1588 of 19998 Old 06-18-2011, 05:47 AM
fatboy9's Avatar
Was notified that a firmware update for the 3312 was available this morning. Took about 30 minutes for it to install.
Does anybody know what issues this update addresses?
fatboy9 is offline
post #1589 of 19998 Old 06-18-2011, 07:02 AM
JChin's Avatar
Quoted: 244 Post(s)
Liked: 175
Hi fatboy9, go back one page and this is what jdsmoothie posted.
Denon will be releasing the firmware changelog information soon.
JChin is offline
post #1590 of 19998 Old 06-18-2011, 07:05 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3391
As a reminder, before posting a question in this thread, please review posts #1-#6 on page 1 as they are updated regularly and
your question may already be answered there. Thanks.
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
