The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 592 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #17731 of 20198 Old 04-25-2013, 08:25 AM
Billkwando's Avatar
Originally Posted by batpig View Post
I wasn't talking about the volume (gain) knob. I was talking about the crossover / LPF knob. Most subs will have at minimum a volume/gain knob and a crossover/LPF knob.
I don't know what the back of your sub looks like. I was responding to this question: "If I'm not mistaken, the BA manual says to set the sub at a 150mhz crossover (will check manual when I get home), so what would that require me to set the other speakers to individually?" I assumed you were referring to the crossover knob on the subwoofer.
Originally Posted by Billkwando View Post
Hey batpig, I snapped a pic of the MCS 160 manual page from the 1312ba. There's no crossover knob, just volume and a polarity switch.
The two manuals seem to contradict each other. What would you recommend? I have an SPL meter, and I have the DVE disc if I need frequency sweeps or test tones.
Hi batpig!
I wasn't sure if you missed my post. Should I try setting my crossover for all 5 speakers to 150hz as the Boston Acoustics manual seems to suggest, or should I leave them all on 80hz, as the Denon manual suggests (IIRC)?
If I do change my crossover, I shouldn't need to recalibrate channel levels w. spl meter, right?
Edit: here's a link to the whole manual if anyone needs or finds it useful:
http://ca.denon.com/DocumentMaster/US/DHT1312BA_MCS160_Owners_Manual.pdf
Billkwando is offline
post #17732 of 20198 Old 04-25-2013, 09:08 AM
turquoisewords's Avatar
Originally Posted by LitRidge View Post
Thanks for your response. I tried this with a laptop at the AVR end. The laptop had no problem obtaining an IP address as suspected. I am concerned that the AVR NIC hardware needs to be replaced or reflashed. Do you have any other suggestions?
Based on that it certainly sounds like the NIC component on the HDMI board. Nothing left to try other than sending back for repair.
turquoisewords is offline
post #17733 of 20198 Old 04-25-2013, 09:14 AM - Thread Starter
batpig's Avatar
Quoted: 3647 Post(s)
Liked: 3487
The Denon manual does NOT suggest an 80Hz crossover. You may have read that as a general recommendation but it doesn't apply to all sitautions. Those speakers are tiny. Use 150Hz as the manual for the speakers recommends.
Crossovers should affect levels, no need to recalibrate SPL.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #17734 of 20198 Old 04-25-2013, 09:25 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
80 or Higher, if Audyssey sets it that way; I have a pair it sets to 150
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #17735 of 20198 Old 04-25-2013, 09:28 AM - Thread Starter
batpig's Avatar
Liked: 3487
You're missing the original context. The OP purchased the 1312BA system which uses an AVR-1312 (which does NOT have Audyssey) paired with a Boston Acoustics sub/sat speaker setup.
Setup Guide and FAQ
post #17736 of 20198 Old 04-25-2013, 09:33 AM
Quoted: 197 Post(s)
Liked: 511
Right you are
post #17737 of 20198 Old 04-25-2013, 10:12 AM
Billkwando's Avatar
I see now that, aside from reading it everywhere else, the Denon manual just states that 80hz is the default setting for crossover, rather than being recommended necessarily. Let's hope the sub won't be too directional/locate-able. wink.gif
Alas, having a cheap 1312, I haz no Audyssey, which is why I'm doing SPL meters and jumping through fiery hoops. wink.gif
Unfortunately that gets me nowhere EQ-wise (if this thing even has EQ....I just discovered the full manual).
I've noticed that with dialog, when I have it at the perfect (but loudish, admittedly) volume to hear quiet speaking parts, when loud parts come in (like Serenity entering the atmosphere at the beginning of "Serenity") the sound gets really harsh from the fronts (as I perceive it). I only have them maybe 2 inches from the wall (which I'm looking into changing or sticking some acoustic insulation behind them), but wouldn't the wall cause them to be more bassy (they appear to be rear-ported) rather than ear splitty? I think I had the volume around 70-75 (relative).
I'm not sure what I can do to fix it (yes, short of buying better speakers), but I've considered turning up the center channel speaker or using compression/night mode. The speakers are 9 or 10 feet from my ears, and the listening area is a small room. I'm hoping using the recommended crossover will be the magical fix, cos it sounds great until it gets ridiculously loud.
Thoughts?
post #17738 of 20198 Old 04-25-2013, 11:18 AM
LitRidge's Avatar
Originally Posted by Dru the Fu View Post
Hopefully you're not up the same creek as me. After not being able to ever update the firmware successfully, I finally decided to send my 3312 into a repair center in North Hollywood, CA. Turns out after their troubleshooting, that my unit had a bad NIC, and since it's integrated into the HDMI/Motherboard, I need a new board. Glad that I did this while still under warranty, because from the little research I did, a new board out of warranty costs over $500 just for the item (not including labor). I'm still awaiting it to be repaired and delivered, as I was told they were out of stock and had to wait on the shipment from Japan.
If you've already tried your resets, it may be advantageous to move your unit next to your router/modem and connect a different Ethernet cable to see if it resolves. If not, I'd then try the same at a friend or family's house (sounds silly, but I also did thias too after reading through this entire thread researching my firmware issue) using their router/modem to see if there is an issue with your network equipment. If both those fail, then you will most likely end up sending your unit in for repair.
Sorry to hear of your troubles, I know I wasn't happy, and still awaiting my unit after being without my little baby for 3 weeks frown.gif
Thanks for the suggestions. I plugged in a laptop at the AVR's cable end to verify router and cable functionality. The laptop worked fine when the router assigned the IP address as expected. Since the AVR has no MAC address the network does not recognize its existence and I cannot connect.
I have to face reality and figure out a way to get this repaired at a reasonable cost. I purchased the unit online in February and discovered that the dealer was not an "authorized Denon dealer" and that the factory warranty does not apply. I contacted the seller and was told to ship it to them for repair. I did this and after several weeks I received it back but it was NOT repaired. It appears to me that the AVR had not even been touched, although I hope that I am wrong. There was no paperwork or any indication of work being done. I am very reluctant to send it back to this seller even if they again, agree to get it repaired since I don't want a repeat. I am starting to look into other options.
65HU8550F, SEK3500, Denon 2313, XBOX, Amazon Fire TV
LitRidge is offline
post #17739 of 20198 Old 04-25-2013, 05:14 PM
spager's Avatar
I would contact them and see if they will swap it out. If they have any business ethics they will do something for you. If not I would post the online reseller with their horrible customer and business dealings.
If need be you can run an apple tv for Airplay and use something like a Blu Ray Player for networking.
Good Luck
spager is offline
post #17740 of 20198 Old 04-25-2013, 07:11 PM
jdsmoothie's Avatar
Quoted: 13126 Post(s)
Liked: 6069
To replace the HDMI/network board is likely to cost upwards of $400+ which is why the seller is going to be reluctant to repair it. If purchased with a credit card, I would also contact the card issuer to see if they can do anything about it.
jdsmoothie is online now
post #17741 of 20198 Old 04-26-2013, 02:23 PM
ed3120's Avatar
I have a Tivo HD connected to my AVR-1712 via HDMI. I'm not sure that my audio is setup properly. I have a 5.1 speaker setup.
If I put on Game of Thones on the HBO HD channel (I assume this is 5.1 content), I can choose between these Movie surround modes:
Virtual
Stereo
PLII Cinema
Pro Logic
Neo 6 Cinema
Multi Channel Stereo
Mono Movie
Which one of these sound modes is best? I assume I can rule out Virtual, Stereo, Pro Logic, and Mono Movie...so should I be choosing PLII Cinema, Neo 6 Cinema, or Multi Channel Stereo?
Also, is there a way to check to make sure that the AVR is receiving a 5.1 signal as opposed to a 2 channel signal? (I assume this changes based on the content)
ed3120 is offline
post #17742 of 20198 Old 04-26-2013, 02:47 PM - Thread Starter
batpig's Avatar
Liked: 3487
Those choices mean that you are getting a 2ch stereo input, not a 5.1 input. You probably need to change the settings on your Tivo box to allow 5.1 output. If it gets a 5.1 signal, it will "lock on" to Dolby Digital as the surround mode.
In the meantime, you should use PLII Cinema to upmix the stereo signal to 5.1 surround.
You can always check the input signal in the INFORMATION sub menu, found either in the GUI or using a web browser.
Setup Guide and FAQ
post #17743 of 20198 Old 04-26-2013, 02:49 PM
Quoted: 197 Post(s)
Liked: 511
That content is coming over as 2.0, PLII will generate extra channels, up to 5.1, PL stands for Pro Logic
post #17744 of 20198 Old 04-26-2013, 05:18 PM
ed3120's Avatar
The Information menu says the following:
Signal: PCM
FS: 48khz
Format: 2/0/.0 (I assume that means 2 channel)
My Tivo only has 2 options in the Audio menu:
Dolby Digital
or
Dolby Digital to PCM
Both yield the Format: 2/0/.0 result
I wonder what I can do to change this.
ed3120 is offline
post #17745 of 20198 Old 04-26-2013, 05:29 PM
jdsmoothie's Avatar
Liked: 6069
If you are using the Dolby Digital setting and getting those readings, then the source material is only 2.0. Note that not all HD content is DD 5.1. Play a movie that is advertised to be DD 5.1 to confirm.
post #17746 of 20198 Old 04-26-2013, 05:37 PM
Quoted: 197 Post(s)
Liked: 511
Game of Thrones should be 5.1; any chance TiVo only recorded in 2.0?
post #17747 of 20198 Old 04-26-2013, 05:52 PM
ed3120's Avatar
I did some more testing. Apparently my Tivo is sending 5.1 through its optical port and 2 channel through the HDMI for some reason. I have set my Tivo's input on the Denon to take the audio from the optical port. For some reason, the Denon is pulling the audio out of the HDMI instead, when both are available.
If I yank the HDMI out between the Tivo and the Denon, and leave the optical cable connected, I get proper 5.1 (and obviously, no picture).
If I put the HDMI back in, the Denon prefers the HDMI audio and it goes back to 2 channel.
Is there any way to set the Denon to prefer the optical input over the audio in the HDMI signal?
ed3120 is offline
post #17748 of 20198 Old 04-26-2013, 05:55 PM
jdsmoothie's Avatar
Liked: 6069
Yup. Assign both inputs to the same source name and then set the INPUT MODE for that source to "Digital". smile.gif
post #17749 of 20198 Old 04-26-2013, 07:13 PM
ed3120's Avatar
That did it. My problems are solved. Thanks guys!
ed3120 is offline
post #17750 of 20198 Old 04-27-2013, 06:06 AM
ed3120's Avatar
I enabled ARC and now I get this "Anynet" volume control overlay on my screen whenever I change the volume. I've always had the volume control in the GUI disabled. I checked and I still do. Is there any way to get rid of this?
ed3120 is offline
post #17751 of 20198 Old 04-27-2013, 07:32 AM
jdsmoothie's Avatar
Liked: 6069
Yup. Turn off Anynet+ on the TV. smile.gif Note that you can use an optical connection from the TV to the AVR for the same ARC capability.
post #17752 of 20198 Old 04-27-2013, 10:44 AM
LitRidge's Avatar
Good Luck
Thanks for the advice. Today, I sent the seller an email asking for an exchange and requested a response by May 4. We'll see what happens.
I have other devices with network access in my home theater system, i.e., TV, Blu-ray player, mini Android PC, and Xbox so media via the network is not that big of a deal. However, if there is ever a need to update firmware or install enhancements, etc. I wouldn't be able to do it. That is my real concern.
LitRidge is offline
post #17753 of 20198 Old 04-27-2013, 02:05 PM
Brian Hampton's Avatar
Quoted: 579 Post(s)
Liked: 307
Hi,
Is the DAC the same for optical as hdmi?
I have the 1912 and I love it.
Recently I got into computer audio and seems using an outboard DAC is very common. But, running optical from my Mac mini directly to my AVR sounds golden to me. (Using BitPerfect with iTunes and lossless files)
Brian Hampton is offline
post #17754 of 20198 Old 04-27-2013, 04:07 PM - Thread Starter
batpig's Avatar
Liked: 3487
The DAC is the DAC. It doesn't matter what the signal path is. All the processing is in the digital domain. The LAST step in the chain is the digital signal passes through the DAC before being sent to the amplifier section. So it doesn't matter what input you use.
Setup Guide and FAQ
post #17755 of 20198 Old 04-27-2013, 05:15 PM
Quoted: 579 Post(s)
Liked: 307
post #17756 of 20198 Old 04-28-2013, 12:56 PM
cglenn's Avatar
Quoted: 26 Post(s)
*Direct: With vs. Without Sub On.*
I use Direct mode when I play CDs with my Oppo, letting it's superior processor handle the audio conversion. But in the Denon, I notice if I turn on the Subwoofer, the display still says 'Direct.'
My question is, when I turn on the subwoofer, does the Denon just extract and process the sub, leaving the L/R processing to the Oppo, or is the display inaccurate and the Denon is now processing all three speakers?
HDMI Main Out to Samsung JS8500 (4K & HDR)
HDMI Audio Only Out to Denon 3312
cglenn is offline
post #17757 of 20198 Old 04-28-2013, 03:09 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
^^ If you are using a digital connection, the Oppo doesn't do any processing. With CDs, it simply sends the PCM to the Denon. What do you mean when you say you are letting the Oppo's "superior processor handle the audio conversion"?
BIslander is offline
post #17758 of 20198 Old 04-28-2013, 04:44 PM
cglenn's Avatar
Quoted: 26 Post(s)
I should have clarified (so much for assumptions). I am using analog out from the Oppo into the Denon.
cglenn is offline
post #17759 of 20198 Old 04-28-2013, 04:59 PM
jdsmoothie's Avatar
Liked: 6069
The only way to engage the subwoofer in DIRECT mode with a 2.0 signal is to set the sub to LFE+Main, however, DIRECT mode is still enabled (ie. no Audyssey).
post #17760 of 20198 Old 04-28-2013, 05:54 PM
cglenn's Avatar
Quoted: 26 Post(s)
Actually, I just press the channel level button on the remote then select sub>on.
But I'm not talking about Audessey, I'm talking DACs. I am asking if, in direct mode, when I turn on the sub via the channel level button, does that cause the Denon's DAC to process the left and right channel too? Or does the Oppo's DAC(s) still process the L/R?
cglenn is offline
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
