The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 646 - AVS Forum
post #19351 of 19368 Old 12-10-2014, 09:49 PM
Liked: 2
Originally Posted by kolopuadoug View Post
Thanks. The follow up by Denon was very good. They called the repairman and got him straightened out and called me back to tell me to call the repairman and request a dra number from him concerning the parts needed to fix the unit in a week. Apparently, the repairman had not done anything. Hoping a call from denon will get him on the job. We shall see. Just FYI about the world we live in the repairman at one time had 13 people working for him fixing electronics, tvs,stereos etc. Now it is just him. Sad. Nothing gets fixed, just thrown away.
Finally got a replacement from denon after some wrangling here and there. All in all very satisfied with support. Got a refurbished AVrx2000 as an upgrade replacement so I am happy. Thanks to Denon Team Support.
kolopuadoug is offline
post #19352 of 19368 Old 12-11-2014, 03:57 PM
Mr.G's Avatar
Quoted: 150 Post(s)
Liked: 127
Did I make a mistake?
My daughter owns the Denon AVR-1612 and I just purchased a pair of Micca MB42 speakers for her to use as left/right surrounds.
I see now that the MB42's are rated at 4 ohms, 75 watts with 85 dB sensitivity. 60-20,000 Hz. 4" woofer and .75" silk tweeter.
Presently she is only using some Sony floor speakers and center channel. No subwoofer.
Trying to decide if I should I send them unopened when they arrive?
All I Really Need to Know I Learned in Movies
Mr.G is offline
post #19353 of 19368 Old 12-11-2014, 04:01 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 2196 Post(s)
Liked: 1801
Surrounds don't draw much power and if she doesn't listen too loud, should be fine.
"JD" – jd@avscience.com ; Direct line 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #19354 of 19368 Old 12-11-2014, 04:02 PM - Thread Starter
batpig's Avatar
Quoted: 1201 Post(s)
Liked: 1612
It all depends on how loud she listens -- at 85dB sensitivity, with low power handling, these speakers are not designed to play very loud. It's impossible to get precise with the numbers but if she never really goes about -20dB volume (60 out of 80 on the absolute scale) it's probably fine.
Mr.G likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #19355 of 19368 Old 12-16-2014, 10:12 AM
poochpa's Avatar
Anyone using a NAS to stream audio to their AVR-1912? My 1912 is connected directly via ethernet to my home network's wireless router. I'm presently using the receiver's DLNA function to stream audio from a networked PC, but would like to do away with having to run the PC to listen to music. What I'm looking for:
NAS able to stream without PC running.
Ability to stream high-quality FLAC (24/96) and ALAC files.
Easy to set up and use, with control from an itunes app or a tv with the Denon remote.
Must be able to play gapless audio tracks and show album art/info.
I don't need massive amounts of storage.
Thanks for any help.
Mike
poochpa is offline
post #19356 of 19368 Old 12-16-2014, 10:51 AM
djqwik's Avatar
spotify & XM RADIO?
Has there been any firmware updates that allow SPOTIFY Connect and XM RADIO on the 2112CI receiver? I see newer models have it.
Thanks .... Dave
djqwik is offline
post #19357 of 19368 Old 12-16-2014, 11:26 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1801
Nope. Spotify Connect is a new feature only available on the new 2014 models. SiriusXM is featured on the XX13 and newer models.
Daily 8am – 8pm EST
post #19358 of 19368 Old 12-17-2014, 07:06 PM
Skylinestar's Avatar
Quoted: 225 Post(s)
Liked: 73
The Crown XLI amp has a 0.775v or 1.4v switch. I guess 1.4v is +4dBu, which is pro gear level. Is 0.775v the correct setting?
The miniDSP also has a similar thing... 0.9vrms or 2vrms, which I'm also confused.
Which should I get for gain-structure-matching with Denon 3312 preouts?
Skylinestar is online now
post #19359 of 19368 Old 12-17-2014, 09:00 PM
aasoror's Avatar
Question Is the 1712 fully 3D capable ?
Been having an issue with my 1712 since day one, checking if its something on my side or if there is a setting I am missing some where.
Noticed that receiver fails to declares itself as 3D capable device during auto negotiation with other devices (say PS3 or HTPC), yet once forced it works just fine (connect PS3 directly to the 3DTV, enable 3D on PS3, unplug same cable from TV and into the 1712 and run 3D content).
I really didn't mind till I got a set-top that queries display capabilities at each boot (and/or HDMI re-connection), so I went to manually check the E-DID for the 1712
Code:
Receiver Brand Name: DON
Receiver Product Name: DENON-AVAMP
EDID block number: 0x1
Source Physical Address[a.b.c.d]: 4.2.0.0
native Mode f1, VIC (native 4):
ColorDeepSupport b8, MaxTMDSClock 45
31 16 3 4 5 17 19 20 2 18 32 33 34 14 35 15 36 29 37 30 38
Audio {format, channel, freq, cce}
{1, 7, 7f, 7}
{7, 5, 1e, 0}
{2, 5, 7, 0}
{11, 7, 7e, 1}
{10, 7, 6, 0}
{12, 7, 7e, 0}
Speaker Allocation: 5f
Vendor: c03
Rx 3D Format Support List:
{VIC FramePacking TopBottom SidebySide}
{ 31 0 0 0 }
{ 16 0 0 0 }
{ 3 0 0 0 }
{ 4 0 0 0 }
{ 5 0 0 0 }
{ 17 0 0 0 }
{ 19 0 0 0 }
{ 20 0 0 0 }
{ 2 0 0 0 }
{ 18 0 0 0 }
{ 32 0 0 0 }
{ 33 0 0 0 }
{ 34 0 0 0 }
{ 14 0 0 0 }
{ 35 0 0 0 }
{ 15 0 0 0 }
{ 36 0 0 0 }
{ 29 0 0 0 }
{ 37 0 0 0 }
{ 30 0 0 0 }
{ 38 0 0 0 }
As shown above there is no 3D support reflected on the edid info.
Any insights ?
TIA
aasoror is offline
post #19360 of 19368 Old 12-18-2014, 03:43 AM
alokeprasad's Avatar
Mike
I'm using an old NAS (Netgear ReadyNAS Duo) which has a DLNA server on it. I can stream mp3 files to my 2312ci but prefer to stream audio, pictures and HD video to my PS3. Many newer routers have DLNA servers that can serve media from a USB drive attached to the router.
You'll have to check the specifications about streaming FLAC files....
alokeprasad is offline
post #19361 of 19368 Old 12-18-2014, 06:53 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1801
Any insights ?
TIA
The XX12 models are all HDMI 1.4 certified to pass full 1080p 3D video, however, the 1712 can only display the GUI on 2D video.
aasoror likes this.
Daily 8am – 8pm EST
post #19362 of 19368 Old 12-18-2014, 12:28 PM
aasoror's Avatar
Thanks jdsmoothie for the reply, actually I am aware of that limitation on the 1712, but I am afraid my problem is a different one.
As you can see from the edid info I posted above my 1712 is not detected as a 3D device at all (check the VIC matrix above), yet I know its passing 3D just fine (as it works once forced), this is a particular issue with devices that relies solely on DID querying to determine the capabilities of the connected display.
I was wondering how does the edid info of other 1712 owners looks like ? or if something like a PS3 would display the 3D options during setup when connected to their 1712 (or other XX12 models).
aasoror is offline
post #19363 of 19368 Old Yesterday, 05:58 AM
Liked: 0
1912 and jamoA355
Hi all,
I have a 1912 receiver with Cerwin Vega e-710 front speakers and a Cerwin Vega c95 center.
Today, I bought two surround speakers JamoA355 and two rear speakers JAMO325.
I just notices that the receiver uses 8-16 ohms but the four JAMO speakers are 4 ohms. Can I use these speakers with my receiver or should I look for 8 ohm speakers?
d.kilshtein is online now
post #19364 of 19368 Old Yesterday, 06:03 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1801
The 1912 is rated for 6-16 ohm speakers, however, can power 4-ohm speakers at moderate volume levels, not too mention surrounds require very little power, so shouldn't be a problem. You will notice after running Audyssey, they will likely be set to a higher volume level than your 8-ohm speakers.
Daily 8am – 8pm EST
post #19365 of 19368 Old Yesterday, 11:28 PM
Liked: 0
Thanks a lot,
But will I be able to listen to music (when using all speakers)?
Will I be able to use these speakers as my front speakers (if I will need to replace the ones I currently have? (
post #19366 of 19368 Old Today, 01:22 AM
Liked: 0
hi all. Im a newbie in need of help. I have just got a denon avr 1912. I have a Samsung smart tv. I have connected the 2 via a hdmi, monitor output on receiver going to hdmi 2 with ARC on tv. I have asigned hdmi 2 In the menu but when I select source tv I just get a blank screen. What am I doing wrong??
dannyedwards is online now
post #19367 of 19368 Old Today, 02:41 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1801
Originally Posted by d.kilshtein View Post
Thanks a lot,
Yes and yes.
Daily 8am – 8pm EST
post #19368 of 19368 Old Today, 02:43 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1801
Refer to post 3 on page 1 of this thread under topic HDMI (ARC).
Daily 8am – 8pm EST
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
