The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 650 - AVS | Home Theater Discussions And Reviews
post #19471 of 19493 Old 02-11-2015, 03:40 AM
Zoltrix's Avatar
Ah, didn't know they existed. Thanks for the info.
But in theory, connecting the Denon to a 4K TV would work? Or does it depend on the specific TV?
Zoltrix is offline
post #19472 of 19493 Old 02-11-2015, 03:49 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3058 Post(s)
Liked: 2003
They don't yet. Won't likely be released until this fall. When passing a 1080p or lower resolution signal via the AVR, the TV will simply upscale to 4k.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVS - We sell Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #19473 of 19493 Old 02-12-2015, 08:24 AM
Wingsbr's Avatar
What's better (or does it matter), upgrade receiver to 4k or allow TV to scale? I have a Samsung HU8550
Wingsbr is online now
post #19474 of 19493 Old 02-12-2015, 10:01 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
The TV and/or source will likely do just as good of a job.
post #19475 of 19493 Old 02-12-2015, 06:02 PM
Teremei's Avatar
Quoted: 264 Post(s)
Liked: 145
jd, I'm having trouble getting video from my PS2 to the TV. I followed the guide, and put all 3 cables, red white and yellow where the manual says to put them. And went into the menu and went to DVD and set HDMI to none and component to (I've tried RCA-1 and RCA-2) and both of them only give me audio and no video when I switch to DVD. That's where I decided to hook my PS2 as. Do I have to purchase an additional component cable and send that out from the receiver to the TV? The manual doesn't say so, and I think I've hit a wall as far as the manual being able to help me.
Sony KDL-70R550A (passive 3D tv)
Denon x4000 (amazing sound correcting software)
Klipsch RF-62IIs (amazing horns)
Klipsch RC-62II (so clear)
Klipsch RS-41IIs (so full)
SVS PC12-NSD + Klipsch RW12d (so boom)
Teremei is online now
post #19476 of 19493 Old 02-12-2015, 06:07 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
COMP = Component video
post #19477 of 19493 Old 02-12-2015, 06:18 PM
Teremei's Avatar
Quoted: 264 Post(s)
Liked: 145
The denon 1712 is listed in the first post. . I think this is the right thread, I hope. Anyway, I don't see where the option to select what you posted. .
The input menu on the 1712 looks like this. .
http://i.imgur.com/oGdmHrs.jpg
post #19478 of 19493 Old 02-12-2015, 06:25 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
As you failed to post what model you were discussing, I presumed you meant the X4000 that is in your sig. This is the correct thread for the 1712; however, as the 1712 has no video chip installed, you will have to connect the TV with the same type input cable being used from the PS2, in this case, yellow composite video.
post #19479 of 19493 Old 02-12-2015, 06:39 PM
Teremei's Avatar
Quoted: 264 Post(s)
Liked: 145
Ah. Yeah that's complicated, and I would have to change the input on the TV every time I wanted to switch. I'm glad to know that. My TV downstairs doesn't even have any composite video connectors. Sorry for the confusion. Damn.
post #19480 of 19493 Old 02-13-2015, 07:41 AM
Wingsbr's Avatar
JD - I have a 5.2 setup with Klipsch reference floors, center and bookshelves. I can get the x4000 for $799 and have a few questions on possible upgrade from the 2112. Is there a significant upgrade from Audy XT to XT32, is the dual sub mgmt worth it, is DSX worth it...any other things I should consider? I'm really happy with the 2112, but wonder if the benefit is worth the upgrade.
post #19481 of 19493 Old 02-13-2015, 07:46 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
Although there certainly won't be a night and day difference, upgrading to an XT32 model should provide a noticeable increase in audio quality. As you have 2 subs, then using Sub EQ HT will provide for better calibration if not using identical subs each placed equidistant from the main listening position. DSX using Front Wides definitely helps to expand the front sound stage, however, most actually prefer using DTS Neo:X for Front Wides.
post #19482 of 19493 Old 02-13-2015, 07:48 AM
Wingsbr's Avatar
Thanks! The subs are left and right and equally placed from listening. Sounds like I would notice a small difference, not really enough to spend 799
post #19483 of 19493 Old 02-13-2015, 08:00 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
If you can hold off your purchase, better to upgrade to the X4100W's successor in Sep that will include DTS:X and consider possibly adding either Front/Rear height or ceiling speakers for Dolby Atmos.
post #19484 of 19493 Old 02-13-2015, 08:14 AM
Wingsbr's Avatar
Awesome...thanks again!!
post #19485 of 19493 Old 02-17-2015, 01:21 PM
Teremei's Avatar
Quoted: 264 Post(s)
Liked: 145
I have a Denon x4000 upgraded from a 1712 and I can give you my personal opinion. XT32 is much more than a "small difference". The difference to me was huge. I went from having good surround sound to, man that voice is coming from the air around me. I also have Klipsch and XT32 made them shine, as well as the subs seem even more hard hitting now.
post #19486 of 19493 Old 02-19-2015, 05:20 AM
Liked: 0
Helo, i have question on the DENON AVR 1912..
I wonder whether this receiver can play a very popular internet radio -TuneIn ?
The specifications state only Pandora, Napster, vTuner and Rhapsody, and there is no mention TuneIn.
Kik0 is offline
post #19487 of 19493 Old 02-19-2015, 05:49 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
The new Denon HEOS app can stream TuneIn to wireless Denon HEOS speakers. With the Denon HEOS Link connected to the AVR, you could stream TuneIn to the AVR.
http://usa.denon.com/us/heos
post #19488 of 19493 Old 02-22-2015, 12:58 PM
Lindros88's Avatar
Will the 1612 be able to power all of this? I have the Energy Take Classic 5.1 system but I want to upgrade the center and two front speakers. I want to add two Polk Audio Monitor70 Series II speakers and a Polk Audio TSi CS10.
Lindros88 is online now
post #19489 of 19493 Old 02-22-2015, 02:21 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
Should not be a problem as long as you don't listen at extremely loud volume levels.
post #19490 of 19493 Old 02-22-2015, 03:27 PM
Lindros88's Avatar
Thanks for the reply. What would you consider extremely loud? Louder than reference level?
post #19491 of 19493 Old 02-22-2015, 04:23 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2003
Correct.
post #19492 of 19493 Old 02-22-2015, 05:24 PM
Lindros88's Avatar
Correct.
post #19493 of 19493 Old Today, 12:52 PM
Lindros88's Avatar
I've upgraded my Energy Take Classic 5.1 system. I replaced the center speaker with a Polk Audio CS2 and replaced the two front speakers with a pair of Polk Monitor70's. This is being hooked up to the Denon 1612. My question is, will the CS2 and Monitor70's completely overpower the energy rear speakers? Will I have to upgrade my rear speakers as well?
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
