The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 652 - AVS | Home Theater Discussions And Reviews
post #19531 of 19543 Old 03-18-2015, 02:14 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3331 Post(s)
Liked: 2078
Originally Posted by bgraversen View Post
Can someone with a 2312CI that has the latest firmware from 3/5/15 tell me what package is displayed? I never received a message stating that there was a new firmware nor have I installed a new firmware in some time. I currently am running package 0012.
I've done a Network Reset, Microprocessor reset, and removed the plug for ten minutes and it says I'm on the latest firmware. Yet, I still have distortion for DD+ on Netflix.
Do you own a USA unit? Are the network functions working?
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience - We sell Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #19532 of 19543 Old 03-18-2015, 06:18 AM
bgraversen's Avatar
Liked: 0
I'm assuming that I have a USA receiver since I purchased it from a domestic retailer Worldwide Stereo. Is there a way to confirm this?
My network functions work from what I can tell. I can connect through web control and run my entire system via up control. I've also been able to save and load my config.dat. If I select start firmware update without the network cable connected it hangs at authenticating but if the cable is connected it goes from authenticating to showing firmware:latest
Are there any other troubleshooting steps that I should be doing?
bgraversen is offline
post #19533 of 19543 Old 03-18-2015, 06:51 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2078
If you purchased in the USA ... you have a USA unit, although you can confirm by looking at the OEM box and the end of the model number should be either "EU" or "E3." If your unit indicates it is "Up to date", there's nothing more to be done. If your unit didn't receive the latest update, it's possible that D&M may have pulled it for your model for some reason.
post #19534 of 19543 Old 03-18-2015, 01:58 PM
JudgeSmails's Avatar
Quoted: 62 Post(s)
Liked: 86
Anyone ever had a problem with the PCM/DIG button flashing? This just started on mine yesterday. I'm hoping it is just a loose or bad HDMI cable somewhere but afraid the video processor on the receiver may be going. Assuming this is some kind of HDCP handshake issue. Any thoughts or advice here? I am going to have to spend some time taking connections apart and minimizing middle men devices to try and isolate this. Thanks.
Big Trouble in Little China - greatest film ever made
Gamertag: Team Banzai
JudgeSmails is offline
post #19535 of 19543 Old 03-19-2015, 05:50 PM
bgraversen's Avatar
Liked: 0
I was able to confirm that I have a USA model since I have E3 at the end. Thanks for the help. I think I must have missed the update for some reason. I'm going to contact Denon and see if they have any additional information.
post #19536 of 19543 Old 03-20-2015, 09:33 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2078
Perhaps another 2312CI owner who did the update can provide the firmware number listed in the AVR?
post #19537 of 19543 Old 03-24-2015, 11:08 PM
Liked: 0
I'm hoping to have this answered as quickly as possible cuz if I can't figure it out I will be forced to return the receiver. I recently purchased the avr 2312ci from a private seller on Amazon. I have a 2313 back at home(I'm at school now) and I had a very easy to me setting it up. For some reason the 2312 will not display a picture on my TV through hdmi. I am receiving audio from the cable box through the receiver but no picture. I have tried different cables and have gone through all the settings with no luck. I know I'm connecting the wires how they are supposed to go so basically I'm asking if there's something different on the 2312 or if I was sold a receiver with a busted hdmi out port
Tyler9x is offline
post #19538 of 19543 Old Yesterday, 03:19 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2078
Nothing different. Try resetting the microprocessor as described in post ##5 of this thread.
post #19539 of 19543 Old Yesterday, 04:12 AM
bogart219's Avatar
Hello all. Can anyone help me. I have a Panasonic st30 smart tv hooked up to my Denon 1312. I'm starting to use NETFLIX now. I can't get any sound watching netflix through my Denon 1312.
If I use the tv speakers I get sound. I bought a TOSlink cable and have that hooked up now but still can't get any sound. Does anyone know what I have to do to get netflix to work with my Denon?
For instance, what buttons do I need to push or inputs to set? Thanks!
bogart219 is online now
post #19540 of 19543 Old Yesterday, 04:48 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2078
The 1312 does not support HDMI(ARC) so you cannot pass audio from the TV back to the AVR via the HDMI cable that connects them. However, by setting the TV's VieraLink Speaker Output from "TV" --> "Home Theater" and connecting the optical cable from the TV's optical audio output to the AVR's optical input (TV), you should be able to select TV on the 1312 remote control and hear the TV's audio from your surround speakers.
post #19541 of 19543 Unread Today, 03:39 AM
bogart219's Avatar
Thanks for the info smoothie, I'll see if I can do that and post back!
post #19542 of 19543 Unread Today, 03:57 AM
bogart219's Avatar
On a side note, anyone know where I can get a replacement remote control for my 1312 at a decent price ? Some of the buttons don't seem to respond anymore even with new batteries. Thanks!
post #19543 of 19543 Unread Today, 04:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2078
Although you can purchase a remote directly from Denon, you may be better served purchasing a Harmony universal remote (eg. 650) which would be able to control the AVR and several other devices as well.
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
