The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 655 - AVS | Home Theater Discussions And Reviews
post #19621 of 19639 Old 05-24-2015, 04:40 PM
tcreech's Avatar
dual HDMI out problem
I'm having a problem with the dual HDMI monitor functionality, I hope someone can help. One output goes to an LCD flat screen, and the other to an Optoma projector. With the amp set to "Dual" outputs and both displays on, it works fine. But if I turn the flat screen (LCD) off, the projector loses it's signal. Occasionally the projector will flash a moment of video and the audio will work for a moment, but then it's all gone again. It seems as if the projector is searching for an input but can't lock on. Again, this is only when the other display (LCD) is turned off. When the LCD is on, they both work fine.
If I go into the menu and select either output 1 or 2 (I've tried switching them; 1 for projector, 2 for LCD, and vice versa) instead of dual, then the projector works fine. This is currently my only option for using the projector, which is a bit of a PITA.
suggestions?
Thanks in advance,
TC
tcreech is offline
post #19622 of 19639 Old 05-24-2015, 05:28 PM
Davird_Jr's Avatar
Wow the firmware update came out on March 4th and I just got prompted for it today? Wonder what took so long.
Dave
Davird_Jr is offline
post #19623 of 19639 Old 05-24-2015, 06:02 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4059 Post(s)
Liked: 2259
suggestions?
Thanks in advance,
TC
Try powering on just the PJ, wait a few seconds, then the AVR, wait a few seconds, and the the source. Also try unplugging the power cord to the AVR for 10 minutes.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #19624 of 19639 Old 05-26-2015, 12:21 PM
JudgeSmails's Avatar
Quoted: 79 Post(s)
Liked: 98
Has anyone ever had their XX12 receiver repaired? Here is why I ask. The headphone jack on my unit is dying. I've verified it is the jack itself and not the headphones. Unfortunately I use my Denon a lot at night when the family is asleep so headphones are critical for me. I contacted Denon who sent me a list of approved repair facilities. None of which are in my city or even my state. So I assume to get something like this fixed I would have to mail the unit out. And since it weighs slightly less than a blue whale the shipping costs would be extreme. Not to mention not having a working AVR for weeks would be painful.
So I'm shopping for replacements. And I got to thinking, does anyone mail these things out for repairs? And if so did it cost a fortune and take a long time? It seems like if you are out of warranty this is a nightmare (and my unit is of course just out of warranty).
Just curious how others have dealt with this. Thanks.
Big Trouble in Little China - greatest film ever made
Gamertag: Team Banzai
JudgeSmails is offline
post #19625 of 19639 Old 05-26-2015, 12:32 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2259
If the unit is still under warranty, it should only cost about $40 or less to ship it to the factory repair facility PanurgyOEM in NJ, with turn around time on average < 2 weeks from the date it's shipped. Denon pays the repair cost and return shipping as well. If the unit is out of warranty or not otherwise purchased from an authorized dealer, you're more likely better served investing in a 2014 model on clearance (eg. X2100W) or one of the newer 2015 models soon to be released.
Another option if you have an "X" series model with Zone 2 pre-outs and use a set of "wireless" headphones, is to plug the transmitter in to the Zone 2 pre-outs and also connect an analog cable from the source to the AVR in addition to the HDMI cable. Set Zone 2 to ON and to the source you want to listen to with the main zone muted.
JudgeSmails likes this.
post #19626 of 19639 Old 05-26-2015, 05:54 PM
deniseb's Avatar
Can anyone explain this?
I had a problem with my AVR-1912 yesterday that I eventually managed to fix, but I still don't know what happened. I'm hoping someone can enlighten me.
I muted the device. Later I tried to unmute it, but the sound never came back on. The mute icon would go on and off the screen when I pushed the remote, but no sound either way. I tried everything I knew how to do: checked the connections, powered the unit off and on, ascertained that there was no sound regardless of which source I used and whether I was using speakers or headphones.
Before looking for a repair service I decided to try doing a factory reset. In preparation I went through all the settings and wrote them down. Someone else set it up for me originally and I never knew what they all were. When I saw that there was a setting for level of muting, set to Full, I thought I'd try changing it to -40dB and see what happened. As soon as I did, the sound came back on (it wasn't even on Mute at that point). Then I changed it back to Full. Still working. Everything is fine now.
I'm posting this in part for the benefit of anyone else who might experience the same thing, but I'd also appreciate an explanation of what might have happened, if anyone has one. Thanks.
deniseb is offline
post #19627 of 19639 Old 05-26-2015, 06:00 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2259
No explanation other than as these AVRs are microprocessors ... sometimes they just hiccup. In such instances, a soft reset (unplugging the power cord for 10 minutes) will generally resolve the issue.
post #19628 of 19639 Old 05-26-2015, 06:54 PM
deniseb's Avatar
10 minutes? I didn't know that - I only did 10 seconds. Maybe that would have saved me a lot of trouble. Thanks.
deniseb is offline
post #19629 of 19639 Old 05-27-2015, 01:22 PM
Herman Trivilino's Avatar
I have the Denon AVR-591. When I play a blu-ray disc with a dts-HD High Resolution audio track the AVR-591 on-screen display shows DTS-HD High Res. When I play blu-ray discs with dts-HD Master audio tracks all I see is DTS.
The blu-ray player is a Sony BDPS1200. Does this mean the player is not outputting Master Audio?
Before this I had a Sony BDPS500 that behaved exactly the same, but I know that player cannot output dts-HD Master Audio.
Herman Trivilino is offline
post #19630 of 19639 Old 05-27-2015, 02:52 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2259
As noted on p. 91 in your Owner's manual, if a DTS HD-MA signal is being received, then DTS HD-MSTR should be displayed on the front panel display. Ensure the HD audio track is selected on the BD as it may not be the default audio track.
post #19631 of 19639 Old Yesterday, 01:47 PM
Liked: 0
Hello
I have a Denon 1912 which I bought new in 2011. It has given me excellent service from day one until now. I have it hooked up to a Samsung flat screen HDTV and driving a modest 5.1 speaker setup.
The problem I'm having is in setting (and keeping) the standby HDMI input. The sat/cable box is plugged into the default port #3 and the BluRay box is plugged into the default port #1 . When I watch cable TV with the Denon supplying audio, no problem. When I switch off the denon, no problem. when I power up the TV to watch without the Denon, it will hold the signal for about 5 seconds and then switch to HDMI input #1 . I then have to power on the Denon (from standby mode) and manually switch to Sat/Cbl input. Then I can put the Denon back in standby without further issues and watch TV without Denon audio.
I have tried to set the HDMI control to "on", then setting the Standby Source to "HDMI 3" and "Last" with neither setting having a positive effect. After doing a full factory reset, running the Audyssey setup and trying the "Last" and "HDMI #3 " settings to no avail, I searched the forums for a similar situation. I found a few loosely related issues regarding ARC passthrough, but nothing directly related to my problem. I hesitate to try switching input asignments in order to swap cable positions, as I feel this doesn't cure the problem.
Can anyone help me out with this issue?
David
n0cash is offline
post #19632 of 19639 Old Yesterday, 01:59 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2259
When a unit changes sources like that it generally will require repair to resolve. Try powering off the unit and unplug the power cord for 10 minutes and do a series of microprocessor resets. If still no joy, then either repair it or try using INPUT ASSIGN to assign HDMI1 to CBL/SAT.
post #19633 of 19639 Old Yesterday, 03:09 PM
Liked: 0
Well it looks like Input Assign didn't do it (still switches to the input the BD is plugged into). I'm hoping it's not a ship to the Denon repair scenario.
Dave
n0cash is offline
post #19634 of 19639 Old Yesterday, 03:28 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2259
What happens if the BDP is not plugged in? If it has a separate HDMI-CEC/Control setting, try setting it to OFF.
post #19635 of 19639 Old Yesterday, 03:50 PM
Liked: 0
Just tried unplugging the BDP. It switched even faster, like 2 sec.
n0cash is offline
post #19636 of 19639 Old Yesterday, 04:17 PM
JChin's Avatar
Quoted: 190 Post(s)
Liked: 153
Originally Posted by n0cash View Post
I have it hooked up to a Samsung flat screen HDTV...
Hi n0cash, try using a different HDMI input on the Samsung TV, same issue?
JChin is offline
post #19637 of 19639 Old Yesterday, 04:46 PM
Liked: 0
Yessir, same. I moved the HDMI cable to the HDMI 2 port on the back of the Samsung. No difference.
n0cash is offline
post #19638 of 19639 Unread Today, 08:09 AM
jake9's Avatar
Quoted: 14 Post(s)
I ran into an issue yesterday with my 2312CI and I thought I would share what happened.
The AVR was not outputting any video/audio content while in standby. I turned on the AVR but content was still not being output (connected to the cable box). I switched the input to BD and content came up, but it was slow and the screen would blink intermittently. Then I switched the input back to cable, and it still showed the BD player on the HDTV. No matter which I input I selected, it showed the BD player on the screen. I recently changed my HDMI cables, so I thought it had something to do with that. I swapped out HDMI cables, but the issue remained. I unplugged the system for about 10 min but that didn't work either. I finally did a reset, and after a while and putting my settings back to the way they were, it began to output video correctly.
This was quite a scare for me as the AVR is just out of warranty. Does anyone know if this was an early sign of a failure? I'm not sure I like the how Denon changed the later models after the xx12 series, so I'd hate to replace it.
MacBook Pro | Apple TV | Oppo BDP-105D | Parasound Halo A 21 | Parasound New Classic 2100 | Rega RP-3 | Martin Logan Theos | Toshiba 42RV530U HDTV |
jake9 is online now
post #19639 of 19639 Unread Today, 08:20 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2259
Can't say it's an indication of future failure or not, but if you purchased with a credit card, the card issuer may add an additional 4th year of warranty.
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
