The **OFFICIAL** Denon AVR-XX12 Model Owner's Thread - Page 676 - AVS Forum | Home Theater Discussions And Reviews
 289Likes
post #20251 of 20265 Old 10-01-2017, 10:41 AM
ericuf's Avatar
Quoted: 23 Post(s)
Hi all. How do I select game 2? Even from remote nothing happens ...?
ericuf is offline
post #20252 of 20265 Old 10-01-2017, 11:59 AM
jdsmoothie's Avatar
Quoted: 15366 Post(s)
Liked: 7516
What is "Game 2"? Is that one of your video games?
jdsmoothie is offline
post #20253 of 20265 Old 10-01-2017, 02:53 PM
ericuf's Avatar
Quoted: 23 Post(s)
It’s apparently an input on the receiver. But I don’t know how to access.
ericuf is offline
post #20254 of 20265 Old 10-02-2017, 12:48 AM
jdsmoothie's Avatar
Liked: 7516
Use the INPUT ASSIGN setting in your Owner's manual (p. 97).
ericuf likes this.
post #20255 of 20265 Old 10-02-2017, 02:21 AM
bat0nas's Avatar
As noted in the INPUT ASSIGN setting in your Owner's manual .. there is only (1) GAME source.
There are 2 game sources (both hdmi) in 1912 model. I have two game consoles connected.
As noted above: input assign should solve the problem.
Sent from my SM-N910C using Tapatalk
ericuf likes this.
bat0nas is offline
post #20256 of 20265 Old 10-02-2017, 02:37 PM
ericuf's Avatar
Quoted: 23 Post(s)
Yep that was it, for some reason it was turned off. Thanks!
ericuf is offline
post #20257 of 20265 Old 10-05-2017, 08:57 AM
raist3001's Avatar
Hey guys, I have a Denon 2312CI.
I recently received a Samsung KS8000, so this is my first foray into 4K UHD HDR.
I also have a Roku Ultra and an Oppo 103 BRP.
My 2312CI HDMI ports are 1.4a.
My Roku is connected to my TV.
My Oppo is connected to my 2312 (I use the Oppo to access my Plex server in order to pass full HD Audio - Video is always 1080p)
I guess my question is should I be considering upgrading to the X3300? My 2312 is still running great since it was purchased in 2013.
If I wish to have everything connecting to my AVR, I believe the answer may be yes.
If I choose to leave my set up as is, I believe the answer may be no.
I have gotten some mixed advice and looking for a solid plan.
raist3001 is offline
post #20258 of 20265 Old 10-05-2017, 02:41 PM
Kalani's Avatar
Quoted: 113 Post(s)
Liked: 26
I think you answered your own question:
"If I wish to have everything connecting to my AVR, I believe the answer may be yes.
If I choose to leave my set up as is, I believe the answer may be no."
If you want all devices connecting through the AVR, as you said, yes, you need a new AVR that supports all current pass-through options for 4K, HDR and DV.
If you want to leave the setup as is... then leave it as is.
Kalani is offline
post #20259 of 20265 Old 10-05-2017, 02:44 PM
raist3001's Avatar
Thanks Kalani 😀
post #20260 of 20265 Old 10-05-2017, 02:46 PM
Kalani's Avatar
Quoted: 113 Post(s)
Liked: 26
Thanks Kalani 😀
You bet.
Note that, unfortunately, the current 2017 lineup of Denon AVRs (if you want to stick with Denon) do not support graphic overlays at 4K+DV at 60fps, only 30fps. If that matters to you. (I like seeing the volume bar on the TV, since I can't see the AVR screen where it sits) I'm hoping the 2018 lineup does, and my current AVRs (3312 and 2112) don't crap out before they're released... Passthrough should be fine, though.
Kalani is offline
post #20261 of 20265 Old 10-06-2017, 11:43 AM
tpezanko's Avatar
Unhappy Issues with Samsung TV ARC controls
Hi,
So I’ve got an issue I’ve been facing for a while, and frankly, I’ve been too lazy to address it, but I’m pulling my stereo cabinet away from the wall tomorrow to re-wire, so now’s the best chance to fix this.
I own a Denon AVR-2112ci, and a Samsung UN60JU7100 TV. They are connected via HDMI from the “HDMI In 4 (ARC)” input on the TV’s “One Connect Mini” box to the “Monitor Out” output on the Receiver.
The Receiver is from 2012, TV is from 2015. Receiver supports HDMI 1.4a, not sure if firmware updates have changed that since.
My issue is that when using the system combined, I’m able to control volume via the TV remote. This is helpful when launching Netflix from the SmartHub or using one of the attached HDMI devices that connect to the “One Connect Mini” box, as it lets me use a single remote to control things.
The problem is, the devices that get the most usage run through the receiver: FiOS and Xbox. When turning on the TV to watch cable TV, it continually flips the input on the receiver back to TV, despite me being on the one marked “Xbox” or “Cable”.
I’m open to ditching ARC if others have found this situation untenable, but I frankly just want to be able to watch TV without the input flipping back and forth on me. I do like the fact that everything is talking somewhat, but it’s gotten very, very old to have the TV be going, and 45 seconds later it cuts to black because I’m not running anything off the TV’s input.
Thoughts/Suggestions? Thanks in advance.
-Tim
tpezanko is offline
post #20262 of 20265 Old 10-06-2017, 02:22 PM
jdsmoothie's Avatar
Liked: 7516
Originally Posted by tpezanko View Post
Hi,
-Tim
On more current models this issue has been resolved with a dedicated "ARC" setting, however, on your 5 year old model, you must either contend with switching the source back or disable ARC and instead use an optical cable.
post #20263 of 20265 Old 10-06-2017, 10:01 PM
eaadams's Avatar
Quoted: 52 Post(s)
I have a 2112 and my TiVo goes through the Xbox1 to receiver via SAT input. My TiVo remote can turn on TV and that turns on the 2112. I turned off all Xbox auto off features.
But no ARC stuff as I use a Chromecast or the Xbox for streaming. Soon will pickup a Roku also. I gave up on the Vizio's streaming when I saw the picture difference between man in iron castle via tv vs Xbox. Night and day picture quality difference.
Sent from my Pixel XL using Tapatalk
eaadams is offline
post #20264 of 20265 Old Today, 06:29 AM
Liked: 0
Just to share about my finding on my faulty Denon 3312 hopefully other members having similar issue can fix it, symptoms is can not be powered on and no LED indicator at all. After days searching for service manual, finally managed to get a copy of service manual to fix my faulty unit from hifiengine, found out C3082 shorted with measured 18 ohms. Causing MCU reset pin been pulled down and disabling the whole unit.
Initially suspect Standby PSU 5.2v faulty, turn out 5.2v spot on and stable, then come across MCU RX630 reset pin measure LOW, that's how it lead to my problem solved.
Now unit work wonderfully.
darrenting.g is offline
post #20265 of 20265 Old Today, 08:25 AM
poochpa's Avatar
Quoted: 49 Post(s)
For years, I've been using an Ipod Classic 160GB connected to my 1912 to play my iTunes music library stored on the Ipod (lossless format). The Ipod is connected to the 1912's front usb and it has worked great, allowing full remote control of the library, shows album art on the tv, and does gapless playback. I've now maxed out the storage on the Ipod. What alternatives are out there with larger storage? My 1912 is networked via ethernet to a router and pc in another room, but I don't want to have to turn on the pc just to play music on the 1912. I love the simplicity of the Ipod connected directly to the 1912 and that it plays back gapless. Thanks for any suggestions.
Mike
poochpa is online now
Denon , Denon Avr 1312 Receiver , Denon Avr 1612 Receiver , Denon Avr 1712 Receiver , Denon Avr 1912 Receiver , Denon Avr 2112ci Receiver , Denon Avr 2312ci Receiver , Denon Avr3312ci Receiver
