Marantz SR5006 / Marantz SR6006 Receiver Thread - Page 23 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #661 of 2132 Old 02-17-2012, 06:47 PM
thelonebuzz's Avatar
I am currently using the web controller for all commands on a SR5006, hidden in another room. I would like to have the option to use a traditional remote at times.
Has anyone had success using the IR flasher in? What type cable/receiver is required? I assume it's a stereo IR in, but the IR Receiver I tried did not work even after switching off the main IR control.
Failing that any recommendations for a wired IR extender?
thelonebuzz is offline
post #662 of 2132 Old 02-18-2012, 07:50 PM
CGIM5804's Avatar
PS3 Issue with SR6006
Have a question regarding blurriness while playing a video game on the PS3. I just played FIFA on the PS3 and noticed a lot of annoying blurriness on the green playing field, which I never had before. I have the ip scaler off on the GAME input so it should be passing thru the video. Any ideas what is going on? Never had this when the PS3 was connected directly to the TV.
CGIM5804 is offline
post #663 of 2132 Old 02-18-2012, 08:00 PM
levatator's Avatar
Originally Posted by minotauri View Post
I'm having an issue with my new SR6006. I am having really bad screen flickering when connecting my PS3 to it via HDMI. It flickers and sometimes drops video and goes black and then re-displays video again. I have other hdmi devices connected including xbox, cable box, and hd-dvd player and they all work fine. I've tried 4 different hdmi cables that i know work and I have also tried plugging in different inputs on the receiver without luck. Plugging hdmi directly to the TV works fine without flickering. I have a Samsung LN46C650 TV.
Oh, this flickering does not occur when playing a blu-ray movie or game.
Originally Posted by ekkoville View Post
Have you checked the video settings on the PS3? When I reconnected mine from another display I had no video due to settings in the PS3. I had to remove it, hook back up to the previous TV, and change display settings in order make adjustments. Might be something to check.
I'm having a similar PS3 issue, though I'd describe mine as more "snow" or "noise" rather than screen flickering. I see this only while streaming from netflix or vudu, and primarily in the blacks/dark colors, making darker scenes almost unwatchable. Bluray picture is flawless, which makes me unsure of the origin of the noise seen while streaming. any thoughts or suggestions?
levatator is offline
post #664 of 2132 Old 02-19-2012, 01:37 AM
jdsmoothie's Avatar
Quoted: 14587 Post(s)
Liked: 6922
Have you both tried turning the "Deep Color Output" setting on the PS3 to OFF?
jdsmoothie is online now
post #665 of 2132 Old 02-19-2012, 05:59 AM
CGIM5804's Avatar
Tried this but did not help. The blurriness is only when there is movement on the field, if I pause with the ball or if its a close up shot then it's fine. I even tried fooling around with the motion on the TV but that didn't help although that should not be a reason since it was never a problem before having the receiver. Really getting annoyed at this.
CGIM5804 is offline
post #666 of 2132 Old 02-19-2012, 07:01 AM
PackFan72's Avatar
I am sure there is a setting I am not aware of..... I have TiVo connected via HDMI I turn the receiver to standby and eventually sound from the TiVo will be playing. What setting do I need to make to the receiver.
PackFan72 is offline
post #667 of 2132 Old 02-19-2012, 10:30 AM
levatator's Avatar
Yeah I tried this as well, no change. Again the vexing thing about it is that BD playback is fine, while streaming is very noisy. Is this what some have referred to as the signal being molested? Would this be "selective molestation" then, as its only apparent while streaming?
post #668 of 2132 Old 02-19-2012, 12:09 PM
CGIM5804's Avatar
Figured it out, it is the DNR setting that screws it up. If I turn on the feature, it introduces blur. It doesn't affect regular TV watching or movies but for some reason it affect that specific game.
CGIM5804 is offline
post #669 of 2132 Old 02-19-2012, 12:43 PM
levatator's Avatar
Hmmm, I'm not convinced that we're seeing the same problem here. Where is the DNR setting? In the PS3, receiver, or your display?
post #670 of 2132 Old 02-19-2012, 05:32 PM
jimimac's Avatar
I got a good deal on A 5005.It replaced my Denon 3802.audessy makes it sound better.Still very hard for me to set up.I,m 51 and kinda computer challenged though.Awesome recievers though.It drives my big Paradigm 90P V3,s Just fine they will handel 250 watts.
jimimac is offline
post #671 of 2132 Old 02-20-2012, 06:59 AM
jdsmoothie's Avatar
Liked: 6922
Welcome ... although this is the 5006/6006 thread ... try posting in the thread below ...
http://www.avsforum.com/avs-vb/showt...t=marantz+5005
post #672 of 2132 Old 02-20-2012, 10:47 AM
heathriel's Avatar
Hey guys, I think I'm missing something obvious here.
I've got the SR5006, and I'm trying to set up Pandora. In the settings, it's only giving me the option to put in username/password for Rhapsody or Napster. In the Web Controller, if I switch to Pandora, it says "I have an existing Account/Sign Up for a new account" but if I pick either one of them, it says "You can't use the Web Controller for this."
I can't find anywhere else to enter the settings for Pandora.
Help?
A ham doesn't taste like pork chops, but that doesn't mean it's rhinoceros.
Knowing is half the battle.
heathriel is offline
post #673 of 2132 Old 02-20-2012, 11:49 AM
RDHolmes's Avatar
Quoted: 85 Post(s)
Liked: 77
Help?
Go to Net/USB and select Pandora. You will then be able to enter your Email address and password.
Bob Holmes
Curmudgeon
RDHolmes is offline
post #674 of 2132 Old 02-20-2012, 12:30 PM
heathriel's Avatar
When I go to Net/USB (from the remote) it just shows Net/USB on the receiver itself, and nothing displays on the TV. (Except that it's 7.1 surround, and what display it is).
If I hit "Amp Menu", it goes back to showing the Menu onscreen where I can only enter Rhapsody/Napster password.
How do I select Pandora after going to Net/USB without using the Web controller?
post #675 of 2132 Old 02-20-2012, 12:37 PM
jdsmoothie's Avatar
Liked: 6922
Have you already registered for a Pandora account as noted on p. 36 ...
When you first listen to Pandora, it is necessary to subscribe to a Pandora account at the Pandora homepage by your PC and register this machine. See the Pandora homepage for details.
http://www.pandora.com/marantz
post #676 of 2132 Old 02-20-2012, 12:53 PM
heathriel's Avatar
Hmm, could it be this:
"in Net/USB mode, the interface only displays 480p through HDMI and Marantz support confirmed this and this is the only mode for Net/USB"
I'm only outputting HDMI - maybe my tv doesn't sense the change to 480p?
Just tested by plugging the receiver into another TV. I'm getting no signal output detected from the Net/USB, so no OSD on that source.)
(And I still don't see anywhere that says Pandora, except in the Web controller, so I'm assuming the email/password bit is in the OSD for Net/USB?)
post #677 of 2132 Old 02-20-2012, 06:56 PM
CGIM5804's Avatar
It's on the receiver. Go into the AMP menu and into video adjustments and make sure DNR is off.
CGIM5804 is offline
post #678 of 2132 Old 02-20-2012, 09:51 PM
levatator's Avatar
Yeah, I found it there. Setting DNR to high seems to soften the noise slightly but also softens the picture as well. Looks like I'm no closer to the root cause of the noise. Anyone else have any ideas?
post #679 of 2132 Old 02-21-2012, 08:05 PM
LVS
LVS's Avatar
Can these receivers not be set to always up-convert to 1080P? Forgive me if this has been answered earlier in the thread.
LVS is offline
post #680 of 2132 Old 02-22-2012, 04:30 AM
jdsmoothie's Avatar
Liked: 6922
With the 6006, yes (using the i/p Scaler setting just as with your 3808); however, with the 5006, no, as there is no video chip.
post #681 of 2132 Old 02-22-2012, 07:27 AM
LVS
LVS's Avatar
Thanks for the info. Ugh! I didn't do enough research on the differences between the 6006 and the 5006. I guess I don't have to worry about a bad scaling now.
LVS is offline
post #682 of 2132 Old 02-22-2012, 09:41 AM
Ryan1's Avatar
Quoted: 47 Post(s)
Liked: 63
If you have a decent 1080p TV, it will upscale anyway, and often with great results. So, you are not necessarily missing anything.
Ryan1 is offline
post #683 of 2132 Old 02-22-2012, 09:42 AM
ccotenj's Avatar
Liked: 101
even if you have a crappy 1080p tv, it will scale/deinterlace... it has no choice....
- chris
ccotenj is offline
post #684 of 2132 Old 02-22-2012, 09:52 AM
LVS
LVS's Avatar
Using a projector so when viewing broadcast television the projector switches to the mode the channel is broadcast in. 720p on for some, 1080i for others etc.
LVS is offline
post #685 of 2132 Old 02-22-2012, 11:57 AM
ccotenj's Avatar
Liked: 101
on the input side...
in order to display it, it must scale/deinterlace to its native resolution...
- chris
ccotenj is offline
post #686 of 2132 Old 02-22-2012, 12:37 PM
LVS
LVS's Avatar
Oh yea, crap, I am having brain farts lately, to used to seeing it scaled in receiver I guess and showing up as 1080P at the projector. Probably a better deinterlacer in the native display device anyway! Geesh! Thanks for whopping up side the head Chris & Ryan, actually you didn't whop me, because this was flame worthy!
LVS is offline
post #687 of 2132 Old 02-22-2012, 01:08 PM
Hoovie59's Avatar
So I was letting my apartment-mates use my sr6006 and somehow one of them managed to get rid of the on screen volume display just for the BD input. I have been through the settings and manual and cannot for the life of me figure out how it got turned off. It works on every other setting and when the OSD is on just not on BD. I know this has to be an easy fix I just can't figure it out.
There is no replacement for displacement
Hoovie59 is offline
post #688 of 2132 Old 02-22-2012, 01:40 PM
LVS
LVS's Avatar
^^^ Have you tried pressing the DISP key when BD input is selected?
LVS is offline
post #689 of 2132 Old 02-22-2012, 01:55 PM
Hoovie59's Avatar
Haha yea first thing I tried
Hoovie59 is offline
post #690 of 2132 Old 02-22-2012, 02:03 PM
ccotenj's Avatar
Liked: 101
lol...
it happens to all of us at one time or another...
- chris
ccotenj is offline
Marantz Sr5006 Av Receiver , Marantz Sr6006 Av Receiver
