Marantz SR5006 / Marantz SR6006 Receiver Thread - Page 68 - AVS | Home Theater Discussions And Reviews
post #2011 of 2040 Old 09-25-2014, 06:15 AM
wookierookie's Avatar
jdsmoothie,
Can you elaborate a bit? What connection would I use to hard wire it? I assume since the ethernet port for both components will be occupied for network connections, I have to use USB? Thanks for the help!
wookierookie is offline
post #2012 of 2040 Old 09-25-2014, 06:46 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3710 Post(s)
Liked: 2181
Correct. The AVR ethernet connection is to a router only, so either USB (or HDMI if available) must be used.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #2013 of 2040 Old 09-25-2014, 08:44 AM
I would prefer HDMI. Having trouble finding a NAS with HDMI out. Guess I should be looking more for a media player/NAS combo? Any recommendations?
post #2014 of 2040 Old 09-25-2014, 09:05 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
None, from me. No. However, there is likely a dedicated thread elsewhere on this forum (ie. outside of the Receivers, Amps, and Processors) where you can get some suggestions.
post #2015 of 2040 Old 09-26-2014, 09:18 PM
OK, so audio is playing great through the USB port, but the video won't play. I'm trying to play h.264 (.mp4 file), and the audio is very jumpy, and no video. What am I doing wrong?
post #2016 of 2040 Old 09-29-2014, 05:28 AM
voodoo2crue's Avatar
Sorry,this may have been covered before but I did a search and can’t find anything specific to my problem. I have a 6006 and hard wired it to my linksy router that is attached to a hughesnet modem. All other devices in the home are running wireless connections from the Linksys router. I can get the 6006 to connect and play fine but I lose my wireless connection to the router. If I reset and get the wifi connection running again I lose the 6006 connection.
voodoo2crue is offline
post #2017 of 2040 Old 10-05-2014, 05:24 AM
justinto's Avatar
Turning On - Perplexed
I have a strange problem that is intermittent. I have two 6006s; one in the living room and one in the bedroom. On three occasions, the one in the living room turned itself on early in the morning (5 this morning - 6 on the other two). It turns on to the last station I was listening to on the internet radio even though when I turned it off, it was on HDMI 3 (Sat). Has anyone had this problem? What should I look for? The one in the bedroom does not do this.
Justin
Panasonic 50" Plasma TC-P50-GT30
Panasonic 58" Plasma TC-P58V10
Panasonic Blu Ray Player DMP-BDT 210 and 110
Marantz SR6006 (2)
Aperion Verus Grand Speakers
justinto is offline
post #2018 of 2040 Old 10-05-2014, 05:32 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Nothing. USB is audio only.
post #2019 of 2040 Old 10-05-2014, 05:35 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Each unit will respond to the same remote as well as phone remote apps.
post #2020 of 2040 Old 10-12-2014, 09:50 AM
justinto's Avatar
It has nothing to do with a remote. The last two mornings, at 5 am, the unit turned itself on. This is spooky - I think Halloween is getting close. I checked my cellphone that has the app, but the app was connected to the other unit, so that was not it. I checked the setup on the unit and could not find any reason why. I unplugged it this morning, hopefully to cure it. I do not want to reset it yet, though I have a backup.
Justin
Marantz SR6006 (2)
justinto is offline
post #2021 of 2040 Old 10-18-2014, 02:28 PM
I got rid of the old Linksys wrtg54 and problem solved.
post #2022 of 2040 Old 10-23-2014, 07:47 AM
kemetblk's Avatar
Lately I have noticed that the sound from my 6006 isn't as loud as it used to be. I used to run the audio at a volume level between -50 and -40 and that would be plenty loud for tv show watching (Audyssey on, Dynamic Volume on Light). Now i need to crank it up to between -30 and -20 to get the same level. Same thing when watching blu-rays, i used to run it between -20 and -10 (Audyssey on, Dynamic Volume off), but now i have to crank it up to 0 (and 0 used to be much too loud for me). Has anyone had this issue?
I will most likely try a microprocessor reset this weekend, but would like to avoid it if possible because i hate having to re-run the Audyssey set up again.
HD-DVD: 55 / Blu-ray: 83
newest: Brotherhood of the Wolf / Battlestar Galactica (series), TDKR Part 2, Ip Man 2
AVR: Marantz SR6006
F/C/R: Polk RTi A9's / CSi A6 / Speakercraft AIMWIDE 3
Sub: SVS PB12-NSD
Samsung PN58C8000 Samsung BD-P2550, Toshiba HD-A30, SA 8240HDC, Xbox360 Elite, PS3, WDTV Live
kemetblk is offline
post #2023 of 2040 Old 10-23-2014, 08:07 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Confirm that Dynamic Volume is still turned on for that source (as it is source dependent).
post #2024 of 2040 Old 10-23-2014, 06:28 PM
kemetblk's Avatar
It's set the same as it always has been. Its on on my cable input and off on my blu-ray input.
AVR: Marantz SR6006
Sub: SVS PB12-NSD
kemetblk is offline
post #2025 of 2040 Old 10-24-2014, 02:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Do a soft reset by simply unplugging the power cable for at least 10 minutes. If no joy, then a microprocessor reset.
post #2026 of 2040 Old 10-24-2014, 04:14 AM
Liked: 0
BD to SR6006 - multiple connections
All,
I have Pioneer BD Player connected to SR6006 via HDMI cable and the ‘HDMI Control’ function is activated as it's really helpful.
Recently, my wife bought a Karaoke set. It’s equipped with RCA connectors only and you plug it to any BD/DVD player on one side and the amplifier on the other side. The instrumental music comes from DVD via RCA in connector, the vocal from the microphone is added on top of it and all together is sent via RCA out to the amplifier.
My wife requested to connect the Karaoke to SR6006 for better experience so I plugged Karaoke RCA connectors to BD player outputs and to SR6006 inputs. Finally I renamed one of SR6006 inputs to ‘Karaoke’ and assigned appropriate RCA connectors to it.
So at the end of the day there is HDMI connection from BD player to SR6006 (named ‘BD’) and parallel RCA connection from BD player via Kraoke set to to SR6006 (named ‘Karaoke’). My objective was to use ‘BD’ input (HDMI) when listening to music or watching video from DVD/BD and use ‘Kraoke’ input when my wife wants to sing karaoke. Unfortunately, when I SR6006 is switched to ‘Karaoke’ input and any function of BD player (e.g. play, pause, ffwd) is used then SR6006 switch the input to ‘BD’ (HDMI) automatically. I understand it's caused by HDMI Control signals but I'd prefer to not disable HDMI Control. Is there any way to tell SR6006 to use RCA only when ‘Karaoke’ input is selected?
Maciej
maciejz is offline
post #2027 of 2040 Old 10-24-2014, 04:20 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Yes, connect the Karaoke RCA cables to the same source name used for the Blu Ray player (eg. BD) and change INPUT MODE to "Analog."
post #2028 of 2040 Old 10-27-2014, 05:50 PM
LeDelmo's Avatar
Quoted: 13 Post(s)
Hey, I need some feedback from everyone. I own a Marantz SR5008 and have been have issues with them. I say them because I have gone through three. The first was a SR5007 which lasted six months than the LCD went out. Got and exchange for the SR5008 "Only thing left" Which I had to pay the difference in cost. Got it home The amp was bad. Did another exchange for my current one and now this one's lcd screen is going out. Its actually happening the exact same way as the first.
So I am wondering if anyone else is having these issues because I dont think I want another Sr after all this. Was thinking about going with the NR or PM.
Or maybe Yamaha?
LeDelmo is offline
post #2029 of 2040 Old 10-28-2014, 06:25 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
As your issue now involves the SR5008, you would be better served posting in that Owner's thread; however, as your issue has crossed over model years, I would also suggest looking at a possible electrical issue (surge?) in your home.
post #2030 of 2040 Old 10-28-2014, 07:51 AM
BacHolz's Avatar
Or maybe Yamaha?
I cant speak directly to your experience, but as someone with three working Marantz products a 1060, 4240 and most recently my SR6005 (an earlier version of your current receiver). The earlier models have needed a few new lamps, caps and transistors over ~ 80 years of use but are all working splendidly. My current 6005 has also been a reliable part of my present HT. As has been suggested, replace the unit as needed, but I would look at external causes to explain the early demise of three receivers in a few short years.
BacHolz is offline
post #2031 of 2040 Old 11-26-2014, 11:14 PM
Liked: 0
Greetings to fellow Marantz SR6006/SR5006 owners. I've been reading the threads to see if anyone else has experienced loss of functionality with the 7.1 analog input selection following the firmware update I downloaded in late September. I was a able to listen to any disk through my Oppo BDP-103 with the analog input until that point. Select the 7.1 input, and good to go - bypassing the Audyssey room correction.
Marantz customer service had me reboot the entire network (M-DAX and Display) and still nothing. I fed the output of the Oppo to my Denon 3801 and got it all. I still have DTS and DD 5.1 surround function of my SACD's through HDMI via PCM, but since the update, I can no longer derive the singular DSD encoding. I have an extensive collection and just started collecting high resolution downloads using JRiver MC20. Looked like I was pretty much set until the next addition to the rack. The LH Geek Pulse Xfi, or simply upgrade to the Oppo 105D for DAC function were the logical choices - both at the economical price point of $1300. (before the Pulse hits the market at $3100)
Hey jdsmoothie; you have a firm hand on the function of these super sounding Marantz power plants, do you have any ideas for resolution to my problem?
Oppo BDP-103
Definitive Tech BP8B LF, RF, LR, RR
Definitive Tech BPX Surround, and Rear
Definitive Tech CLR 1000 Center
Definitive 10" Power Cube Sub
Monster HTPS 7000
Monster M850 optical
Monster M650 HDMI
Ethereal EXS-HMDE DPL SP HDMI
AudioQuest Type 4 speaker, Ruby interconnects.
Samsung PN51D6500 plasma
OregonWineman is offline
post #2032 of 2040 Old 11-27-2014, 11:36 AM
Scot Kight's Avatar
Anyone know if the 5006 can pass through UHD/4k content or is it 1080p max only?
Scot Kight
"Don't touch that, this isn't your house and that isn't your tv!" she says.
"But look at it, the contrast is completely blown out, the color is all off and that tint. This will only take a sec..."
Scot Kight is offline
post #2033 of 2040 Old 11-27-2014, 03:19 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
1080p only as 4K starts with the SR5007.
post #2034 of 2040 Old 12-29-2014, 09:01 PM
m R g S r's Avatar
More recent issues with my stupid Sr5006. A while back I had a dead surround channel. I searched the internet and found a post (can't find the damn thing now for the life of me) stating how to do a hard hard reset. Not just a hard reset. This was a hard hard reset that even marantz wasn't aware of.
Anyway that one worked for me, and got that channel working again. I can't find it, and don't know what buttons I pressed. Please someone if they're aware of it than lmk!
I have no sound, but picture passes fine. No sound when I do test tone start as well. This thing is really annoying me!
m R g S r is offline
post #2035 of 2040 Old 12-30-2014, 04:59 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
How to reset my SR5006/SR6006
Microprocessor reset - press/hold DISPLAY/ZONE SELECT while powering on AVR
Network reset - press/hold M-DAX/DISPLAY while powering on AVR (includes microprocessor reset)
post #2036 of 2040 Old 12-30-2014, 06:38 AM
m R g S r's Avatar
No not that one. I know about that. Tried it multiple times.
There was another one. I forget where I saw it but I remember the poster (it was deff a forum) saying that even marantz tech support was not aware of this hard hard reset. But that worked for me.
Anyway I think this thing is dead. No sound, it was an intermittent issue (happened on one channel in the past year, then last week no sound at all until I turned the receiver on and off once, but now no sound any channel...sub channel worked after second hard reset, now back to no channels working after another reset) Not very happy it's never been abused, always adequate ventilation etc. I take care of my stuff. It's only about 3 years old as well.
post #2037 of 2040 Old 01-05-2015, 08:40 AM
Liked: 0
Thank you jdsmoothie for the reply. I had only recently some time to test your recommendation but after several hours spent on reconnecting cables and changing SR6006/BD player the settings, I didn't move any step forward
Initially, I left BD player HDMI cable connected to receiver's HDMI input that is assigned to BD source (Input Assign), connected audio RCA to 2ch Analog Audio (BD) Input as you suggested and changed the Input Mode for BD source to Analog. So now the video signal is delivered via HDMI and audio signal via RCA, it works fine with Karaoke but unfortunately in such configuration I can't play multichannel audio from BD player (my BD player doesn't have any multichannel analog outputs).
I tested also another setup: BD player connected to SR6006 via HDMI input (assigned to BD source), BD connected also to SR6006 via RCA to 2ch Analog Audio In (source renamed to Karaoke). In such config it works quite well, i.e. I use Karaoke source for playing Karaoke songs via 2ch audio and BD source for playing multichanel audio (in both cases video is delivered via HDMI cable). Unfortunately that setup works only if BD player's HDMI-CEC function is switched off. When BD player's HDMI-CEC function is switched on then SR6006 source is switched from Karaoke to BD when any change on BD player occurs (e.g. play/FFWD button is pressed/new chapter begins etc.). I tried various setting of Karaoke source: 'Video Select' was changed to BD/Karaoke/Source and 'Input Mode' was changed to Analog/Auto but it didn'thelp at all. HDMI-CEC is always taking over the control and the source is being switched from Karaoke to BD.
Did I miss something in your recommendation or is it just standard HDMI-CEC behaviour/Marantz limitation?
Best regards
Maciej
maciejz is offline
post #2038 of 2040 Old 01-05-2015, 08:56 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2181
Nothing was missed. You will have to switch INPUT MODE back to HDMI when you want to watch a Blu Ray as the Karaoke configuration mode is not permanent.
post #2039 of 2040 Old 01-08-2015, 05:06 PM
hamurabi's Avatar
hello guys. I have a problem for months and still cant find the solution.
I have a Marantz sr 6006.
it is connected to a projector and a media player (ac ryan playon hd2).
I bought the wireless headphones sennheiser rs180.
Since i want to have sound both from the speakers and the headphones i cannot find the way to do it.
I tried 2 x rca from the media player to 2 x rca to the AV's analogue audio in
and then connected the rca cable from the headphones to zone 2. i turned zone 2 on but nothing.
i tried rca cable from the headphones to the vcr analogue audio out but no sound from the headphones. but when i chanched the source to the tuner i can hear radio from the headphones.
any help please?
hamurabi is offline
post #2040 of 2040 Old 01-31-2015, 01:43 PM
pottscb's Avatar
Quoted: 66 Post(s)
Liked: 50
So, as I change speakers quite often, the center channel speaker connections have gotten loose and caused intermittent amp dropouts on several occasions and I've had to take it to an audio shop so they could tighten it up. Maybe a local audio shop could help you (or reset the unit?)
pottscb is offline
Marantz Sr5006 Av Receiver , Marantz Sr6006 Av Receiver
Gear in this thread - Sr5006 by PriceGrabber.com
