Marantz SR5006 / Marantz SR6006 Receiver Thread - Page 69 - AVS | Home Theater Discussions And Reviews
post #2041 of 2045 Old Yesterday, 01:38 PM
Wildgift's Avatar
Using ARC or optical for 4k tv
Hi guys--I have an sr5006, which sounds great and is dialed in for my directv box, Apple TV, ps4 and Denon bluray player. My LG plasma just died, and I want to get a vizio 4k TV. I understand that the sr5006 does not pass 4k, so I want to be able to use the tv's Amazon, Netflix etc apps to get 4k programming. Right now, I have all inputs going into the marantz, and a single hdmi cable going to the dumb lg TV. It's all controlled by a harmony one (though the marantz is pretty finicky). The vizio are arc compatible as is the marantz from what I can see, though the crc seems to be fussy.
So: can anyone help me out with what I need to do to get sound from my tv when I use the built in apps? Now, Apple TV and ps4 handle those apps. I don't want to plug all inputs to the TV because what a nightmare and I will lose the lossless audio from my bluray.
Thanks for any help and especially specificity!
Wildgift is online now
post #2042 of 2045 Old Yesterday, 06:19 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3903 Post(s)
Liked: 2233
HDMI(ARC) can be more trouble than it's worth. Instead just connect an optical cable from the TV to the AVR and you'll be good to go.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #2043 of 2045 Old Yesterday, 07:25 PM
Wildgift's Avatar
JD, thanks. Then, I just set the harmony to look for optical in for activity like Netflix etc, right?
post #2044 of 2045 Old Today, 02:26 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2233
Yes, that is correct. Any TV smart app audio would pass from the optical out to the AVR. You'll likely also have to change the TV's audio to either "external speakers" or "home theater."
post #2045 of 2045 Old Today, 05:24 PM
Wildgift's Avatar
Pulled the trigger on a Sony Xbr-65x-850b. I was told it will output DD 5.1 for the apps like Netflix. I'll use my marantz for lossless audio from bluray. Thanks for your help.
Marantz Sr5006 Av Receiver , Marantz Sr6006 Av Receiver
Gear in this thread - Sr5006 by PriceGrabber.com
