Marantz SR5006 / Marantz SR6006 Receiver Thread - Page 72 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #2131 of 2136 Old 08-13-2017, 03:58 AM
Liked: 0
Hello Everyone,
I have an SR6006 and recently encountered a strange problem. The subwoofer output has stopped working.
I have tried the subwoofer on another avr and it works fine in that.
Even when i go to settings and enable or disable the settings for subwoofer nothing happens and it does not power the sub.
I have done a reset as well.
any help would be much appreciated.
ryanrodigues is offline
post #2132 of 2136 Old 08-13-2017, 11:53 AM
jdsmoothie's Avatar
Quoted: 15327 Post(s)
Liked: 7483
Originally Posted by ryanrodigues View Post
Hello Everyone,
Refer to p. 150 of your SR6006 Owner's manual and do a microprocessor reset.
jdsmoothie is offline
post #2133 of 2136 Old 08-30-2017, 02:49 AM
Liked: 0
did a microprocessor reset as well as a network reset. still no output. it has two subwoofer ports and both dont work.
is there a way to reinstall the firmware ? via usb
post #2134 of 2136 Old 08-30-2017, 02:57 AM
jdsmoothie's Avatar
Liked: 7483
On more current models (ie. 2015 and newer), yes, but not on the SR6006. Ensure the sub pre-outs are enabled (ie. subwoofer not set to NONE in Manual Setup), otherwise, repair would be the next step.
ryanrodigues likes this.
post #2135 of 2136 Old 08-30-2017, 03:09 AM
Liked: 0
thanks, i had tried that as well, funny thing is that one onescreen i had seen that though the subwoofer was set to"ON" the status showed as off on one of the web pages , that the reason i feel that its a software related issue.
i guess i may have to take it in for repairs only.
thanks again for the quick reply
post #2136 of 2136 Old 09-17-2017, 06:14 PM
kain0rer's Avatar
Quoted: 25 Post(s)
Hi all,
Hopefully I'll have some luck here with my issue I posted in another thread: System intermittently playing audio through TV
Was told to try my luck here. If anyone could help that would be great.
Marantz SR6006 Receiver | Studio 60 v.5 Fronts (Bi-Amped) | SVS PB-2000 | Samsung JU7000 75" (Firmware: 1501) | Harmony Hub (Firmware: 4.13.100)
kain0rer is offline
Marantz Sr5006 Av Receiver , Marantz Sr6006 Av Receiver
