12 volt trigger - AVS | Home Theater Discussions And Reviews
Old 05-13-2011, 09:31 AM - Thread Starter
Jayohio19's Avatar
My pioneer Sc 37 has two 12 volt triggers on the back of it. Would these be used to make a screen operate? I have a dalite cosmo electric screen shipped today and was just curious if this is doable without adding anything to the screen
Oops I Crapped My Pants
Jayohio19 is offline
Old 05-13-2011, 09:35 AM
Toys7505's Avatar
Quoted: 53 Post(s)
Liked: 24
Those 12v triggers can be used for an array on items from Amp "turn on" to control of a projector screen, so to answer your question - Yes.
Denon AVR-3311CI, Denon DVP-602CI, B&K EX4420, B&K TX4430, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
Old 05-13-2011, 12:51 PM
schan1269's Avatar
Personally, I would use the 12V trigger from the projector to run the screen, but yes. It comes down to which is the closest, and if you have other uses for the ones on the receiver(2nd zone, a subwoofer with a 12v).
There are 12v controlled outlets(like a timer/light sensing outlet), so you could use one to power your sub, even if the sub doesn't have a 12v. Just buy a "soft shut-off" for the sub.
schan1269 is offline
