Pioneer SX-205 specs - AVS Forum | Home Theater Discussions And Reviews
Old 05-19-2011, 03:55 PM - Thread Starter
Dallas84's Avatar
I did recently got a used Pioneer SX-205 stereo receiver from Thrift World for $20 but my question is that what are the specs for this receiver. Some sites say that are 100 watts per channel but some say only 50 watts per channel. Also I would like to know other specs for this receiver like frequency response etc.
If I can see the owners manual that would be the best but I don't think I can download it since it was made around 1998.
Dallas84 is offline
Old 05-19-2011, 03:57 PM
TJ7
TJ7's Avatar
SX-205
Radio Shack Catalogue Archive 1939-2005
Does your system seem to have a mind of its own?
Turn HDMI Control OFF!!!
TJ7 is offline
Old 05-19-2011, 04:01 PM - Thread Starter
Dallas84's Avatar
I did see that site already and that site says 100 watts but on this site it says like 50.
http://www.fixya.com/support/t482970...ions_and_dimen
It is really hard to read what it says but I think it says that is it 50 watts per channel. But is this the actual specs for the receiver I have? If someone knows that actual specs I would like to know. The Pioneer website doesn't give much info about the receiver. I need full specs of it.
Dallas84 is offline
Old 05-19-2011, 04:08 PM
TJ7
TJ7's Avatar
The link I posed was to the oficial Pioneer site
TJ7 is offline
Old 05-19-2011, 04:20 PM
TJ7
TJ7's Avatar
It is really hard to read what it says ...
I see what you mean - let me see if I can clean it up a bit for you.
TJ7 is offline
Old 05-19-2011, 04:25 PM
TJ7
TJ7's Avatar
If you hold CONTROL and use the mouse wheel you can zoom in
TJ7 is offline
Old 05-19-2011, 04:35 PM - Thread Starter
Dallas84's Avatar
So I guess that the specs there was right and is for the receiver I currently own right? Why does Pioneer say that they are 100 watts per channel but the specs on that site says they are 50 watts per channel?
Dallas84 is offline
Old 05-19-2011, 04:52 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The real rating is 40W with .09% distortion, 20hz-20khz, 8 ohms, both channels driven.
That should be plenty though, especially for $20. What are you connecting to it?
Afro GT
afrogt is offline
Old 05-19-2011, 05:20 PM - Thread Starter
Dallas84's Avatar
Well from the specs say that for CD, Tape, LD/DVD etc is from 5hz to 100kHz -3db so that is pretty good if that's true.
Dallas84 is offline
Old 05-19-2011, 05:33 PM - Thread Starter
Dallas84's Avatar
I don't really need a home theater receiver since I only play music and have a pair of speakers. I usualy connect the receiver to the computer so I use a RCA to 3.5mm cable.
Btw am I able to connect a pair of 4 ohms speakers? I won't connect two pairs of speakers but just one pair.
Dallas84 is offline
Old 05-19-2011, 05:35 PM
afrogt's Avatar
Liked: 755
You should, the receiver does have a 4 ohm rating.
Afro GT
afrogt is offline
Old 05-19-2011, 05:44 PM - Thread Starter
Dallas84's Avatar
Wait a sec I just found out that there was a receiver that was SX-205RDS and mine is just the SX-205. I found a pic of the SX-205RDS and it looks different. Maybe mine then is 100 watts per channel since the one on the Pioneer site shows the same receiver as mine.
I uploaded both receivers.
Mine is the SX-205
Both look similar but are different.
Dallas84 is offline
Old 05-19-2011, 05:45 PM - Thread Starter
Dallas84's Avatar
If the receiver I have is different from the RDS then I need to know the specs for the SX-205.
Dallas84 is offline
Old 05-19-2011, 10:40 PM - Thread Starter
Dallas84's Avatar
Does anyone have a way to find specs for the receiver I have?
Dallas84 is offline
Old 07-18-2014, 09:28 PM
Liked: 0
I know this thread is old, but anyways I have the amp in the second pic, and the two bipolar output transistors say on their datasheet 100W. So you should get up to that with a 8 ohm load. I replaced all the op amps and caps on mine, and it sounds great.
Schematic: http://diagramas.diagramasde.com/audio/PIONEER_SX205_SX255R.pdf
ivandezande is offline
Pioneer Sx 205 Receiver
