amp question - AVS Forum
post #1 of 4 Old 05-24-2011, 05:39 AM - Thread Starter
Smigro's Avatar
Liked: 94
We were cleaning out some of the stuff at my work from the move and I spotted an AV rack that my boss was getting ready to throw out. I quickly jumped in and loaded it up in my car to bring home. Inside the rack was a TOA 900 seriesII A-906 MK2 mixer. Is there anyway to integrate into my HT setup to use as an amp for any of my speakers? I now it is a mixer, but not too sure what can be done with it. Any help would be appreciated.
Smigro is online now
post #2 of 4 Old 05-24-2011, 05:41 AM
MichaelJHuman's Avatar
Quoted: 65 Post(s)
Liked: 74
If it's not a powered mixer, you can't use it as an amp. It's just a mixer tben. Google it.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 4 Old 05-24-2011, 06:16 AM - Thread Starter
Smigro's Avatar
Liked: 94
Here is what I found:
FEATURES
Modular Eight Channel Mixer/Amplifiers for paging, background/foreground music distribution and music/messaging-on-hold.
Proven TOA Quality and Reliability
Engineered for High Performance with wide frequency response, very low noise and distortion, and excellent output regulation.
Three Models: A-903MK2 (30 W), A-906MK2 (60 W), A-912MK2 (120 W)
Eight Module Slots accept any combination of TOA plug-in modules for custom system configurations.
25 V, 70 V and 8 Ohm Transformer-Isolated Speaker Outputs with screw terminal connector and protective cover plate (A-903MK2: 4 ohm).
Direct Low-Impedance Output Mode bypasses output transformer.
Dual Mute Bus permits multiple levels of paging priority using optional mute-type modules.
External Mute Terminals for activating mute function with external switch closure.
Remote Master Volume Terminals for control with an external 10k ohm linear-taper potentiometer.
Individual Channel and Master Volume Controls.
Bass/Treble Tone Controls with tone defeat switch.
Low Cut Switch to limit low frequency response.
Auxiliary Output for connecting an external mixer or recording device.
Insert Jacks for connecting external signal processing.
Bridging Input/Output for input expansion or recording device.
Normal, Clip, Power, Protect, and Signal Indicators provide unit status.
Rear Panel AC Convenience Outlet for powering external equipment
Turn-On Delay disconnects output during power-up.
Over-current and Thermal Protection Circuitry prevents potential damage from overload, short-circuit and overheating.
Volume Control Security Knobs Included (4)
Optional Rack-Mount Kit, MB-25B
UL / cUL Listed
post #4 of 4 Old 05-24-2011, 07:31 AM - Thread Starter
Smigro's Avatar
Liked: 94
From the researching I have done, it does not look like this will work the way I want it to. I only see one input jack, so looks like this will be stashed away. If anyone has an insight as to whether I have overlooked something please let me know.
User Tag List
