Volume Memory feature?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-01-2011, 09:55 AM - Thread Starter
JustinRock's Avatar
I am looking to get a receiver with the ability to return to a specific volume level for each input when switching between sources.
I see several receivers support an initial volume level setting but the ones I have found this only applies to powering up the receiver to an initial volume. I have also seen receivers with the ability to adjust each input with a volume offset allowing consistent audio level between different sources.
I would like information on receivers or companies that support either an initial volume setting per input or possibly just a feature that returns the volume to the last volume level used for a given input.
Thank you for any help.
JustinRock is offline
post #2 of 5 Old 06-01-2011, 10:44 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I believe my last 3 Yamaha receivers had both an initial volume setting, a max volume setting, and a level trim for each channel. They were/are all expensive models, but they may have the same features on cheaper models.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 5 Old 06-01-2011, 11:57 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 421
Those are very common software features..
But you better check the target AVR brand/model before purchasing to verify these are implemented..
Just my $0.02..
M Code is offline
post #4 of 5 Old 06-01-2011, 03:49 PM - Thread Starter
JustinRock's Avatar
With the Yamaha AVRs are you able to set the "initial volume" per input source?
post #5 of 5 Old 06-01-2011, 06:21 PM
Quoted: 266 Post(s)
Liked: 148
No, but you can set a trim for each input. Same thing sort of.
