The Official Yamaha RX-V867 Owners Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #1291 of 1317 Old 08-22-2016, 08:18 AM
KNace's Avatar
I've been pretty good about keeping my Firmware up to date. I just got the message that the new firmware is available and in the middle of the update, it stopped and popped up "System Error" on the screen. I tried again, and it did the same thing. Anyone else try this update yet?
KNace is offline
post #1292 of 1317 Old 08-22-2016, 08:22 AM
Quoted: 915 Post(s)
Liked: 367
You must be using a mobile device. Check the two previous posts.
JoeKustra is offline
post #1293 of 1317 Old 08-22-2016, 08:25 AM
KNace's Avatar
Rephrase, anyone have an issue with the latest update? :-) My unit goes from S1-10: 22% and then rushes to 50% and fails.
KNace is offline
post #1294 of 1317 Old 08-26-2016, 07:28 PM
BadEyes's Avatar
I am in the middle of updating. It is taking a bit of time. I think it has been going for about 7 or 8 minutes now.
I started having trouble running my Roku 3 through the receiver yesterday. It doesn't seem to be passing through 1080p but does fine at 720. I have tried every possible setting I can find, changed cables, tried different hdmi inputs and nothing has worked. The Roku shows 1080 fine when hooked directly into my TV. When run through the receiver and set to output 1080p, the Roku menu is very large and most of it extends beyond the edges of the TV.
So, I am hoping that by some miracle this Yamaha update might fix the problem. I think the chances of this are slim to none.
BadEyes is offline
post #1295 of 1317 Old 08-26-2016, 07:34 PM
BadEyes's Avatar
Well, my receiver update finished fine. Nothing seems to be amiss but my Roku is still displaying incorrectly. I think there was a Roku update recently and that probably broke something in the compatibility between my Roku and my receiver. I will continue to experiment but so far the Roku works fine at 1080p directly wired to both my TV's. It doesn't work at 1080p through any of the Yamaha inputs. Oh, my TIVO and blu-ray player both still run at 1080 through the Yamaha. I guess its the Roku.
BadEyes is offline
post #1296 of 1317 Old 08-27-2016, 05:34 AM
Quoted: 915 Post(s)
Liked: 367
I use my Roku 3 daily (but just for music) at 1080p and never have any issues. There was an update months ago to a new Amazon interface and the ads are more colorful lately. As for TiVo, I have a Premium and basic Roamio, I can switch the Roamio from 1080p60 and 1080i, and never see any difference. I usually leave it at 1080i and let my TV change it. Blu-ray is a Sony S6500 and it works great.
post #1297 of 1317 Old 08-27-2016, 06:02 AM
djc11369's Avatar
Quoted: 285 Post(s)
Liked: 160
Try resetting the Roku either by the pin hole in the back with a paper clip and hold for 15 seconds or through the menu system (Settings, System, Advanced system settings, Factory reset)
djc11369 is online now
post #1298 of 1317 Old 08-27-2016, 07:22 PM
BadEyes's Avatar
Well, after lots of troubleshooting, factory resetting, and etc., I gave up working over the Roku and the receiver and focused on the TV. I finally figured out that a "pixel interpretation" setting on my Sharp TV had been changed. This seemed to have been showing up solely in the look of the Roku menu. Everything else looked ok and was maybe a tiny bit stretched when I went back and double checked. The Roku menu was totally expanded with most of the letters off the edge of the screen.
After discussing this with my wife, I believe that I fell prey to one of the biggest problems we all face ... a one year old who grabs the remote and starts pressing buttons! I am surprised that nothing else was wacky.
Anyway, I love my Yamaha receiver. It has been a workhorse for the past handful of years. It puts out great sound and seems very reliable.
BadEyes is offline
post #1299 of 1317 Old 10-20-2016, 04:39 PM
Hootowls's Avatar
I see that Yamaha has posted an update to their AV Controller app in the iTunes store. I really appreciate that they maintain this and that the app's still compatible with what is now an older receiver. It's an app I use all the time.
HT_Laggard likes this.
Hootowls is online now
post #1300 of 1317 Old 10-31-2016, 10:24 AM
Elton Noway's Avatar
Quoted: 264 Post(s)
Liked: 231
Firmware 2.70
Nothing about what it does, but if you hit On Screen there will be a message for new firmware. I loaded it and detect no changes.
Like others... I was notified of this firmware update several months ago ... came here first to investigate before installing. As you identified I also was unable to find any definitive answers about what it does so... I decided "if it ain't broken don't fix it" and did not install the update.
I've been super busy with work and have pretty much ignored my home theater setup for several months. Just yesterday I fired up the RX-V867 and switched to Pandora for some background music. Hmmm... got the message "No Connection". I then tried Sirius... same thing "No Connection" but when I tried Internet Radio it worked. Just for grins I checked all my connections as well as the receivers network settings and everything was fine. Since I was obviously was connected to the internet I couldn't explain the "No Connection" message when switching to Pandora/Sirius. At this point I figured I had nothing to lose so I installed the 2.70 firmware update following these step-by-step instructions. As per past updates this update easily took a full 15 to 16 minutes. I still can't say what the update does but I can say that Pandora and Sirius are now both working again.
Elton Noway is offline
post #1301 of 1317 Old 10-31-2016, 11:33 AM
Quoted: 915 Post(s)
Liked: 367
I seldom use the AVR for Pandora or IP Radio, but I that doesn't mean never. I have found the IP Radio very useful when I need news from Philly since KYW streams the traffic. My AVR uses a Netgear EX7000 media bridge/Extender to get to my router downstairs. I have to give it praise for working 18 hours a day. I would buy the RX-V681, but I'm not making the 4k commitment yet. Not too long though.
post #1302 of 1317 Old 12-29-2016, 05:13 PM
modenacart's Avatar
Quoted: 73 Post(s)
Liked: 45
I see the specs in the website states a 192/24bit DAC but the manual states 96/24. Which is correct? Did they up it via a firmware push?
modenacart is offline
post #1303 of 1317 Old 12-30-2016, 08:20 AM
Hootowls's Avatar
I think what you are seeing in the manual is a reference to the encoded sample rate of 96 kHz for the bitstream audio formats. The manual also shows it supporting LPCM audio formats to 192 kHz up to 24 bits. The website DAC spec should be correct.
post #1304 of 1317 Old 12-30-2016, 08:25 AM
modenacart's Avatar
Quoted: 73 Post(s)
Liked: 45
Does this mean only 96 over a network?
post #1305 of 1317 Old 12-30-2016, 10:56 AM
Hootowls's Avatar
That's what it looks like. I looked at the specs of a current model (RX-V781) and see USB/PC/NAS sample rate support of certain audio file formats up to 192 kHz.
Page 145:
http://download.yamaha.com/api/asset...asset_id=67041
post #1306 of 1317 Old 12-30-2016, 11:20 AM
modenacart's Avatar
Quoted: 73 Post(s)
Liked: 45
post #1307 of 1317 Old 06-22-2017, 10:09 AM
Biggen_PCB's Avatar
Quoted: 47 Post(s)
I'm finally retiring the old gal. Been a good little AVR for the last 5 years but it's time to move on to newer and brighter things. I guess I'll try to sell it here on the trading forum just to see if anyone wants it before it heads to the dump.
Biggen_PCB is offline
post #1308 of 1317 Old 06-22-2017, 10:33 AM
Quoted: 915 Post(s)
Liked: 367
What's next? I've been waiting for a nice HDR TV so I will have a reason. But 1080p HDR means I'll be waiting a while.
post #1309 of 1317 Old 06-22-2017, 11:02 AM
gregoryperkins's Avatar
Quoted: 501 Post(s)
Liked: 192
I still use mine, but it is no longer the main. I got a Denon X4200 to do Atmos which is almost non-existent on the discs I get. There isn't a great reason to upgrade otherwise. True 4k pass through is still messed up except for the latest receivers. You can always route the 4k to the display and sound to the receiver using a simple hdmi splitter if the device doesn't have 2 hdmi out...
gregoryperkins is offline
post #1310 of 1317 Old 06-22-2017, 12:42 PM
Biggen_PCB's Avatar
Quoted: 47 Post(s)
I moved on to a 2016 Denon AVR-X1300W. It was the same price I paid for the 867 since I purchased the 867 a year after it had been released. I never used the preouts so the 867 was really not used to its full potential in my home.
Since I purchased a 4K TV, I needed the receiver to do the same. I didn't want to fool with having to split the audio/video. I already get 'looks' from my wife when we switch inputs to do simple stuff as is...
JoeKustra likes this.
post #1311 of 1317 Old 06-23-2017, 01:03 PM
Quoted: 501 Post(s)
Liked: 192
Yeah, I ended up with a couple of Denons too, I have the x4200 in the main theater running 5.4.4. No 4k yet. Waiting for the HDR mess to sort out.
post #1312 of 1317 Old 07-10-2017, 03:36 PM
Quoted: 915 Post(s)
Liked: 367
Interesting feature. My sub is set to only come on with an LFE. Both my front and rear speakers were set to front: large, and rear: large. I changed my rear surround to small and now my sub is enabled with 2ch stereo in a 7ch channel music/Bi-Amp setup. Nice!
Vancelot likes this.
post #1313 of 1317 Old 08-19-2017, 10:15 AM
Liked: 0
For me, the only 4K video available is streaming, NetFlix, YouTube, etc. The 4K signal streams directly to the TV via my network.
The HDMI cable from the 4K TV to the receiver is audio out only.
The only reason to go to a 4K Receiver is if you are not streaming directly to the TV.
In the future, if you have a TiVo Bolt that records the 4K video and you want to sent the recording, via the receiver, to the TV, the receiver will need to be 4K.
jkeese01 is offline
post #1314 of 1317 Old 08-19-2017, 10:24 AM
Liked: 0
Correction: My HDMI cable is connected the the HDMI (ARC) port on the TV. Audio from 4K goes the the Receiver, but HD video from the 4K TiVo is input to the TV as HD. This Tivo Bolt will record 4K if the cable company ever offers 4K broadcast. But until then, I do not need a 4K receiver.
jkeese01 is offline
post #1315 of 1317 Old 08-19-2017, 12:08 PM
Quoted: 915 Post(s)
Liked: 367
If the V683 or V781 had some new feature that got me excited I would get one, but I figure I'll wait until my cable feed has some content in 4k. At this rate, I'll be buying a 1080p HDR TV first.
post #1316 of 1317 Old 08-19-2017, 01:03 PM
Quoted: 501 Post(s)
Liked: 192
I doubt you'll see that, but there are some hdr, 4kish projectors starting to show up at reasonable prices, but not much content...
post #1317 of 1317 Old 08-20-2017, 11:13 AM
modenacart's Avatar
Quoted: 73 Post(s)
Liked: 45
4K receives up convert the signal if you care about that.
Yamaha Rx V867 Receiver
