Onkyo TX NR709 Owners' Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #271 of 2580 Old 10-30-2011, 01:40 PM
hlkc's Avatar
If both monitors are HDCP certified, same resolution, and same HDMI level (1.3 or 1.4) then yes ... that is the purpose of 2 monitor out jacks.
Thank you.
hlkc is offline
post #272 of 2580 Old 11-01-2011, 01:20 PM
DMJ
DMJ's Avatar
Originally Posted by DMJ View Post
I used a wireless adapter (N speed Cisco FWIW) and couldn't get it to show up in USB mode. Then I tried using my netbook as a bridge/gateway, but the 709 only recognized that it was plugged in to the ethernet cable.
any help? is there a setup guide out there?
thanks
Come on, I can't be the first person to want to do this.
Dan
DMJ is offline
post #273 of 2580 Old 11-01-2011, 02:49 PM
eddieb187's Avatar
Has anyone else noticed these issues?
I get no audio, just white noise (static) sometimes when switching between HDMI inputs or when using a DVR after I fast FWD or RWD live TV or swap tuners. Most times it's just for several seconds and then the audio outputs fine. Sometimes the receiver gets stuck on this static noise and I have to turn it off and back on to get audio back or switch inputs till I get audio. Not all the time, it's intermittent. I ran Audyssey speaker full calibration setup for a second time last night. Tried a new HDMI cable, different HDMI port, and still get intermittent no audio just noise for a few seconds. I have had two Onkyo receivers prior to the 709 and never had this issue. Tested it again this morning and was fine until it warmed up. Then the issue returned. As long as I don't fast fwd or rewind the audio is rock solid. I have a TiVo Premiere connected via HDMI. Same thing happens when playing a Blu-Ray but not as often as Cable TV with the TiVo.
Another thing I noticed was the DTS Bomb when playing the newly released Star Wars Blu-Ray Episode Four with my Oppo BDP-83. If I skip to chapter 16 (The Death Star) I hear a loud noise similar to a Gun Shot immediately as the audio starts and then it plays fine. Funny thing is if I just play through that exact same spot without the chapter skip the issue does not occur. This can be reproduced every time I skip to or start from chapter 16.
I thought Onkyo fixed that issue long ago.
I remember having the same problem with my older Onkyo 705 more than 6 years ago.
eddieb187 is offline
post #274 of 2580 Old 11-01-2011, 03:24 PM
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
1) Does anyone know if they have ever considered or are considering use of Replay Gain data to enable volume leveling between tracks?
2) When I have it set to shuffled playback it always begins playback with the same track even when pressing play on a playlist (playlist level rather than file list).
3) Why don't they provide video menu output of any network audio via the secondary HDMI output?
I know I will have to send these question to Onkyo but I was wondering if anyone has already addressed these issues and gotten a response?
crbaldwin is online now
post #275 of 2580 Old 11-03-2011, 09:01 PM
wierzt's Avatar
I am interested in this receiver but I read a review saying it does not pass through caption information to the tv. Has anyone else with this unit experienced a similar problem? If so what sources, blu-ray, cable, etc?
thanks
wierzt is offline
post #276 of 2580 Old 11-04-2011, 01:51 AM
dowop's Avatar
Quoted: 42 Post(s)
I just tried CC on mine & it works. I tried it with TWC Cable.
dowop is offline
post #277 of 2580 Old 11-04-2011, 04:01 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
need some help guys...if i hook up my brp to the tv instead i only get pcm 2.0 coming from the arc. is there anyway to get lossless sent? i do this because for some reason i can't display colormode ybc422 only rgb in ybc it casts a orangeish hue when i send my player through the 709. any reason why that is?
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #278 of 2580 Old 11-04-2011, 05:17 AM
Crwaters's Avatar
If you could be more clear with how you're hooked-up, you might get a better answer to your question. I've read your post three times and can only guess what it is you're asking.
We're selling our Photo Annuals and giving the proceeds to Curesearch so they can fight cancer in kids. Please have a look.
Crwaters is offline
post #279 of 2580 Old 11-04-2011, 05:22 AM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
Can't speak to the PQ issue, but the best audio some TVs can pass with connected sources is DD 5.1, while the vast majority (as in your case) can only pass PCM 2.0 (regardless of whether you're using ARC or the optical audio out). If you cannot resolve the PQ issue, you may want to consider a dual HDMI BDP ... video to the TV with HD lossless audio to the 709.
jdsmoothie is online now
post #280 of 2580 Old 11-04-2011, 06:57 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
thank you...
post #281 of 2580 Old 11-04-2011, 08:11 PM
DMJ
DMJ's Avatar
thanks
Dan
DMJ is offline
post #282 of 2580 Old 11-04-2011, 11:29 PM
qweasd123's Avatar
Long time lurker; however, I recently picked up one of these and had a quick question about the internal Nidec fan. Is it temperature controlled, or should it be spinning as soon as the unit is powered on?
qweasd123 is offline
post #283 of 2580 Old 11-05-2011, 07:42 PM
howardru's Avatar
Originally Posted by B|G1 View Post
Hello.
I play media on my TV with USB and Philips mediaconnect.
What settings to turn on so that my Onkyo TX-NR709 receiver can receive audio from the TV? TV is connected to main out ARC. And my TV (Philips 55PFL7606 have ARC (audio return channel)).
Enable HDMI control and it's all magic..... The 709 will automatically switch to TV/CD when it receives the HDMI-CEC signal (I don't like this, but there is no way to disable this);
howardru is offline
post #284 of 2580 Old 11-05-2011, 07:57 PM
jdsmoothie's Avatar
Liked: 5502
You have a few options ...
(a) Disable HDMI-CEC on the TV when not using ARC
(b) Connect optical cable from TV to AVR instead of using ARC
(c) Use Harmony remote or Onkyo remote macro commands to select correct source device after AVR switches to TV source
post #285 of 2580 Old 11-06-2011, 07:10 AM
Avenger's Avatar
I am interested in this receiver since it seems to have a lot of bang for the buck. Has anyone tested hooking the 709 to a Mac via an hdmi input? I use the Mac to watch movies on my TV so it would be nice if it would work. I had an older Denon and the Mac could not connect via HDMI properly to the receiver.
Avenger is offline
post #286 of 2580 Old 11-06-2011, 10:28 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hello.
Hi B|G1, did your tv detected the HDMI input connection?
For ARC to work enable the receiver HDMI Control and ARC (see page 17) . On the Tv enable HDMI-CEC feature call EasyLink and set the speaker output. But make sure that EasyLink has detected the HDMI (receiver) connection.
The HDTV PVR decoder is connected to HDMI 7 (TV/CD)
The TV is connected to main output.
Why should I change to TV/CD when I want sound coming from the TV (main output) and not the decoder??
Reasons in OM:
Do not assign an HDMI IN to the TV/CD selector while "HDMI Control (RIHD)" is set to "ON" (-> page 58), otherwise appropriate CEC (Consumer Electronics Control) operation will not be guaranteed.
To use this function, you must select the TV/CD input selector and your TV must be ARC Capable.
If you set "Audio Return Channel" to "Auto", the "Audio Selector" settings of the TV/CD input selector will be automatically switched to "ARC" (-> page 55).
Suggest to reassign HDMI-7 to "CBL/SAT" or connect HDTV PVR decoder to HDMI-3 (CBL/SAT).
JChin is offline
post #287 of 2580 Old 11-06-2011, 11:08 AM
jdsmoothie's Avatar
Liked: 5502
The HDMI 1.3 cable is fine as there is no difference as long as it passes 1080p it's "High Speed". Did you reassign the PVR to another source name leaving the TV/CD source unassigned?
post #288 of 2580 Old 11-06-2011, 11:34 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
It seems like the Philips and Onkyo can't talk together...
After the settings (EasyLink & HDMI Control) try turning tv off and back on (with the receiver still on).
Also some tv has a scan feature for HDMI-CEC, see if your tv has this.
JChin is offline
post #289 of 2580 Old 11-06-2011, 12:15 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
They don't find each other
After enabling EasyLink, did it give an option for EasyLink Speaker Output settings (EasyLink or EasyLink Auto)?
JChin is offline
post #290 of 2580 Old 11-06-2011, 12:38 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
Hmm, what about turning off and on the tv (with receiver on) and did your tv have a scan feature for HDMI-CEC?
Another suggestion to try would be to disconnect/reconnect tv power cord and see if HDMI input device is detected.
JChin is offline
post #291 of 2580 Old 11-06-2011, 01:01 PM
B|G1's Avatar
I have tried with the receiver on and turned tv off and on.
I don't think the tv have a scan feature. I don't see it in the menu, but I have asked Philips.
I tried to disconnect the power cord.
Cerwin-Vega, Onkyo & NAD 5.1 home cinema:
http://avforum.no/myhometheater/Mikaelft
B|G1 is offline
post #292 of 2580 Old 11-06-2011, 03:49 PM
Avenger's Avatar
I've been trying to decide between an Onkyo 709 and a Denon 2312. I narrowed it down to those two based on the fact that I wanted 7+ HDMI inputs, 4+ digital audio inputs, and at least 1 S-Video input. I'm really only interested in 5.1 audio although these are 7.1/7.2. In any event the Onkyo is less expensive one and even has 8 HDMI inputs plus a PC Input as well. I can pick one up but I am a little leery about some posts I have been following on this forum about the unit catching fire (actually this is about an 809) or about overheating or the HDMI going dead. Are there people out there using a 709 without any issues?
I also have one other problem. My cabinet is open at the front but closed at the sides and the back. I have a Denon AVR-590 sitting there that hasn't had any heating issues so far. Should I automatically disqualify the Onkyo since its too much of a risk to use it in a cabinet space like I have? If so, my only option is the Denon which runs about $850 retail (and I can't find any decent discounts) unless anyone else has any suggestions for me. Thanks!
Avenger is offline
post #293 of 2580 Old 11-07-2011, 01:25 AM
dowop's Avatar
Quoted: 42 Post(s)
I have the 709 that I am using to replace a Denon 891. It runs just as cool or cooler than the Denon.
dowop is offline
post #294 of 2580 Old 11-07-2011, 06:05 AM
DMJ
DMJ's Avatar
thanks
Dan
DMJ is offline
post #295 of 2580 Old 11-07-2011, 06:43 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
If ARC is still not working, suggest running an optical cable from tv "Digital Audio Out" to receiver "TV/CD".
JChin is offline
post #296 of 2580 Old 11-07-2011, 11:32 AM
B|G1's Avatar
Optical cable works.
But I have paid for a receiver and a TV that should support ARC. It's a waste of money if it don't work.
B|G1 is offline
post #297 of 2580 Old 11-07-2011, 01:42 PM
Avenger's Avatar
I happened to be by a Best Buy today and checked out the Onkyo 709 there. The set was turned on (the salesman said it was on since the morning) and it wasn't too hot They keep them in the Magnolia section in a wooden cabinet which is really closed in. I didn't pick it up since there was no sale on the $799 retail price. I guess I'll wait and see.
Avenger is offline
post #298 of 2580 Old 11-07-2011, 02:11 PM
B|G1's Avatar
Mine is not so hot either. There is a fan inside. I keep my on top of the tv-bench.
When it is turned off it is still a little bit hot, I guess some components is still turned on. I can turn it on through the local network with the android app.
B|G1 is offline
post #299 of 2580 Old 11-08-2011, 02:41 AM
dowop's Avatar
Quoted: 42 Post(s)
Once in a while they will price match. Some Magnolia even advertise that way.
dowop is offline
post #300 of 2580 Old 11-10-2011, 04:14 PM
eddieb187's Avatar
If you have "HDMI Through" enabled the unit will be almost as warm off as it is when it's on. When "HDMI Through" is disabled it's cold. The 709 never really gets all that hot even when it's running. I had an Onkyo 705 before the 709 and the 709 runs much cooler.
Receivers Amplifiers , Onkyo Tx Nr709
