Onkyo TX NR709 Owners' Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 62Likes
post #361 of 2590 Old 11-30-2011, 08:06 AM
jdsmoothie's Avatar
Quoted: 15009 Post(s)
Liked: 7236
Lots of folks are forced to connect 2 HDMI cables to the TV due to HDMI handshake issues with numerous models/mfr cable/sat boxes. You might consider adding an HDMI switch between the 722/709 and TV. Another option is to connect both HDMI/optical from the 722 to the 709 and use the Audio Selector feature to select audio from the optical input, although this may disable the audio pass through to the TV feature.
jdsmoothie is online now
post #362 of 2590 Old 11-30-2011, 10:35 AM
atlind01's Avatar
Originally Posted by atlind01 View Post
I just got my NR709 and I am in the process of fine tuning the setup.
I am hooking up by Dish 722 DVR thru the receiver to my Panny Plasma.
Since my wife doesn't want to mess with the new receiver, I have setup the dish as my HDMI pass thru.
But the problem is now I am getting only 2.0 PCM output thru HDMI. In researching other places, I found out that with Dish 722 only the Toslink gives you a 5.1 audio output.
My question is what is the easiest way to retain the HDMI pass thru but still get 5.1 audio out whenever required?
Okay, got this one resolved and working perfectly. For those who are interested, here are the details:
PHYSICAL CONNECTION: It is true that with Dish 722 DVR you need a toslink to get 5.1 output, so you need to hookup a HDMI cable as well as a toslink cable to 709.
CONFIGURATION SETUP:
1. Make sure that you first select the source as "CBL/SAT".
2. Select "Setup" thru Remote
3. Choose "7. Hardware Setup", from the submenu select "3.HDMI"
4. In the second line "HDMI Through", choose "CBL/SAT".
5. In the next line "Audio TV Out" would have been set to "Off" , just LEAVE it as it is, DO NOT change it to "ON".
Come out of the "Hardware Setup"
6. Choose "1. Input/Output Assign" from Main Setup Menu
7. Select "4. Digital Audio Input" submenu
8. Assign the correct optical input "OPTICAL 1/2" against CBL/SAT input.
come out of the "Input/Output Assign"
Make sure that you are still under "CBL/SAT" source, because these options are saved individually for each source.
9. Choose "4. Source Setup" from Main Setup Menu
10. Select "6.Audio Selector" submenu
11. You should now choose "Optical"
This should take care of this, what's more interesting is that when the Receiver is switched the TV volume is automatically muted and the receiver is pumping the audio and when you go to standby, TV speakers will pickup the audio.
atlind01 is offline
post #363 of 2590 Old 11-30-2011, 10:45 AM
jdsmoothie's Avatar
Liked: 7236
post #364 of 2590 Old 11-30-2011, 02:11 PM
oskaalb's Avatar
No. Analog path remains.
For Pure Audio and Direct listening modes only - or all analog sources?
oskaalb is offline
post #365 of 2590 Old 11-30-2011, 03:08 PM
jdsmoothie's Avatar
Liked: 7236
Pure and Direct ..... an analog--> digital conversion is required to use Audyssey/bass management.
post #366 of 2590 Old 12-01-2011, 08:22 AM
Avenger's Avatar
I noticed that the 709 has a VGA input. If I attach a PC or Mac to the receiver do I have to use the VGA input or can I use one of the HDMI inputs? The reason I ask is that I have two PC's (a mac and a windows pc) that I want to connect to it. Can one attach to the HDMI input without any issues (any problem recognizing the monitor within the OS, etc.?). Thanks.
Avenger is offline
post #367 of 2590 Old 12-01-2011, 09:08 AM
jdsmoothie's Avatar
Liked: 7236
Either HDMI or VGA should work (although some PC video cards have issues with HDMI connections).
post #368 of 2590 Old 12-02-2011, 10:45 AM
sectornine's Avatar
I have several questions pertaining to my set-up based on the 709:
First: When I initially turn on the receiver and the tv, no sound is output. If I switch to my blu-ray source and then back to the tv, then sound is output. Any thoughts on the lack of initial output?
Second: I have a three-channel setup, however, on certain movies; the receiver will only output two channels, even though I specified 5.1 in the menu. While I don't have 5.1, I assume it would utilize the towers and center.
Third: The android app freezes on me quite frequently. It will work fine and then I will go to adjust something and it will sit on acquiring data. I can then no longer adjust via the app or the receiver and must turn it off and then back on. Anyone else experiencing this?
Setup:
Samsung PN50C7000
Samsung 6900 Blu-Ray
Martin Logan Motion 12's
Martin Logan Motion 8
Thank you in advance for any assistance.
sectornine is offline
post #369 of 2590 Old 12-02-2011, 06:00 PM
howardru's Avatar
Setup:
Samsung PN50C7000
1.What HDMI input is your TV setup for? TV/CD? If the connection is HDMI, then what input on the receiver is it going into? Are you using HDMI control? I've found that the receiver always switches to TV/CD input whether you have HDMI control enabled on your TV whether. the ARC (Audio Return Channel) get's into play here. Upon powering up the TV which uses HDMI control to turn on the Receiver, it always switches to TV/CD. I have to press DVR Input to select the receiver to switch audio to my Tivo. If I disable HDMI on my TV, the 709 thinks I want to use my TV speakers and disables audio on the receiver. It's a catch 22 and it sucks. I'm guessing it's a bug.
If you don't have any of these problems, then perhaps your audio input on the receiver isn't matched to the correct audio input in the 709 menus.
Second. What's the source of your audio? How the receiver responds to the audio stream depends on how you are inputting to the 709. The receiver will take any Dolby signal and split it out to 5.1. If it's an analog signal from a vinyl album, I don't know. Have you played around with all the listening modes while playing the source?
Third: I only have the IPhone/IPad app and it's really not all the useful but it hasn't hung on me.
Good luck!
howardru is offline
post #370 of 2590 Old 12-02-2011, 06:42 PM
socaldodger's Avatar
Hi,
I'm thinking about getting a NR709. I'm slowly building a B&W 5.1. I already have the CM1's. Next is a sub, CMC2 then the CM9's. Is this amp good enough or should I get a 809? It would be a temporary receiver until I get the CM9 then I would go with separates and move the 709/809 to my bedroom. Any information, opinions, or advice would be greatly appreciated.
socaldodger is offline
post #371 of 2590 Old 12-02-2011, 08:39 PM
howardru's Avatar
Originally Posted by socaldodger View Post
Hi,
Well, the 709 only pumps out 100W Per channel and your speakers handle 200 W PC. Does it get loud enough? It's all relative I guess. I'm not the audiophile, so I can't add much value here. I got two Polk VM30's rated for 225 WPC, VM20 center, DSW Pro 600 and another 2 front Dolby IIz Height and 4 rear surround in-walls and they all sound good to me. You'll always have the option of hooking up an external amp to the speakers of the 100W doesn't cut it for you.
howardru is offline
post #372 of 2590 Old 12-02-2011, 10:55 PM
jdsmoothie's Avatar
Liked: 7236
Hi,
The CM1's are small and inefficient speakers and although the 25W difference with the 809 is not likely to make much difference, if you listen at louder volume, still would be your better choice, especially if it will be awhile before the sub is introduced.
post #373 of 2590 Old 12-04-2011, 04:49 PM
rick.m650's Avatar
Just installed my TX-NR709 and tried to run the firmware update. Looked like when it finished downloading it stopped and displayed... Error!! 3-81. Now the receiver is stuck.
Any help or suggestions would be greatly appreciated.
rick.m650 is offline
post #374 of 2590 Old 12-04-2011, 05:08 PM
howardru's Avatar
Ouch! You disabled HCMI control first, correct?
howardru is offline
post #375 of 2590 Old 12-04-2011, 05:10 PM
slammin86's Avatar
Quoted: 25 Post(s)
Liked: 32
I just bought one of these to replace my rc270 that gave me the flashing red light of death. When the 270 gets repaired under warranty I will just sell it. Paid $499 shipped for the 709.
slammin86 is offline
post #376 of 2590 Old 12-04-2011, 05:26 PM
WSZsr's Avatar
Use the reset procedure in the manual. Then follow the Onkyo instructions for updating the firmware.
Onkyo TX-NR809
Polk Audio RTI A3 Bookshelf Speakers
Polk Audio RTI A1 Bookshelf Speakers
Boston Acoustic VR10 Center
Energy ESW-310 Subwoofer
WSZsr is offline
post #377 of 2590 Old 12-04-2011, 07:19 PM
oqvist's Avatar
I got this receiver some days ago. A really nice upgrade from my previous Yamaha RX-V663. Some problems though Audessey setup for some reason loose my sub. Initially it output the signal to calibrate for 75 db but then when testing the speakers the sub get no signal whatsoever and thus it fails waiting for it. I then tried to hook up to the RCA under the sub pre out (since it´s not marked thought it maybe is dual sub preouts). However after that also when connecting back to preout 1 the receiver shut itself off during audessey calibration. It works great otherwise. Latest firmware installed.
Another issue was trying to connect my notebook using VGA. it flickered and not until the bluescreen it showned the image on the TV oddly enough. Can´t the 709 handle and upconvert a 1600x900 signal?
oqvist is offline
post #378 of 2590 Old 12-04-2011, 09:48 PM
rick.m650's Avatar
The hard re-set worked and my next attempt at updating the firmware worked. Thanks much!
post #379 of 2590 Old 12-04-2011, 10:40 PM
rick.m650's Avatar
I can't figure out how to configure or what input to select for the ARC over HDMI. Do I need to assign that HDMI (out) connection? How?
Right now, that would only be used for OTA broadcasts that are fed directly into my TV.
post #380 of 2590 Old 12-05-2011, 04:44 AM
jdsmoothie's Avatar
Liked: 7236
The 709 has (2) sub preouts (purple jacks). Either one can be used as they pass the same signal. You may want to leave your sub set to "ON" rather than "AUTO."
AVRs generally only accept standard TV resolution inputs. Owner's manual (p. 85) shows the possible VGA input resolutions .. of which 1600x900 is not listed.
post #381 of 2590 Old 12-05-2011, 04:49 AM
jdsmoothie's Avatar
Liked: 7236
As noted on the 709 back panel, only the HDMI(Main) is ARC capable. Connect the HDMI cable from that jack to the HDMI(ARC) jack on the TV (also generally only 1 jack is ARC capable .... usually HDMI1). See "Audio Return Channel (ARC) function" on p. 17.
post #382 of 2590 Old 12-05-2011, 07:12 AM
rick.m650's Avatar
Yes, I was using the correct HDMI (ARC) port but didn't have RHID enabled. However, when RHID is enabled, HDMI Pass-thru is disabled which I find to be a much more useful feature.
I guess no ARC for me.
post #383 of 2590 Old 12-05-2011, 07:18 AM
jdsmoothie's Avatar
Liked: 7236
RIHD must be set to ON in order for the HDMI pass through feature to work.
post #384 of 2590 Old 12-05-2011, 04:00 PM
howardru's Avatar
Make sure you TV signal back is going to TV/CD HDMI input and the ARC functon is enabled.
howardru is offline
post #385 of 2590 Old 12-05-2011, 09:39 PM
rick.m650's Avatar
I've connected 2 different iPods and the Mode button on the remote does not function to toggle between Standard and Extended control modes. I can't get to either Extended mode using the remote. The Tuning Mode button on the receiver, however, does allow me to toggle between the 3 but with every video I attempt to play, I only get a blue screen on my TV.
So 2 issues I'm struggling with... #1 - why the Mode button on my remote isn't toggling between the various iPod control modes (yes, I'm already on the USB input), and #2- why all videos so far aren't able to be displayed on my TV.
Thanks in advance for your help.
post #386 of 2590 Old 12-06-2011, 01:45 AM
jdsmoothie's Avatar
Liked: 7236
Do you also have a composite video cable connected from the iPod to the 709?
post #387 of 2590 Old 12-06-2011, 07:06 AM
rick.m650's Avatar
In addition to the USB connection? I didn't know such a cable existed. It would be nice if the manual mentioned this when speaking about the USB connection. I guess I'll have to look around for this type of cable. Thanks!
post #388 of 2590 Old 12-06-2011, 08:01 AM
jdsmoothie's Avatar
Liked: 7236
The manual actually does reference it (p. 25) which is the only way to pass the video.
post #389 of 2590 Old 12-06-2011, 09:23 AM
locksmith9's Avatar
Originally Posted by dhartung02 View Post
Will the 709/809 let you listen to 7.1 sound with the speaker setup of powered Zone 2 but with zone 2 physically off? Will it convert down to 5.1 when Zone 2 is turned on?
I would like to have my 7.1 (center backs) setup hooked and in use 90% of the time. But during that 10% when i want to fire up the deck speakers, i would like to simply turn on Zone 2 and have the living room go down to 5.1 while i use the powered Zone 2.
Will the 709/809 function in this manner?
Thanks!!
I just received my 709 last night and had the same disappointment. Is there a practical remedy to this deficiency, or do I have to go through speaker setup each time I want to use my deck speakers to switch between 7.1 and Zone 2 listening?
locksmith9 is offline
post #390 of 2590 Old 12-06-2011, 02:43 PM
howardru's Avatar
I'm pretty sure that with Zone 2 off (which only stays that way until you turn it on), all 7.1 speakers are used. I ran my old 707 that way and I have been running my new 709 this way. My Zone 2 goes to outside rock speakers that I use on my patio during the summer. I've had this setup working fine for the past few summers.
I run my as 7.1 (even though I have 9.1 speakers for Dolby IIZ height setups) 98% of the time and never touch the zone 2 speakers.
howardru is offline
Onkyo Tx Nr709 , Receivers Amplifiers
