Onkyo TX NR709 Owners' Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 02-04-2012, 11:57 PM
Mugenstylus1's Avatar
what is the best audio setting for movie watching? I kinda just set mine to thx, or am i better doing direct? mostly blu-rays.
Also, could i hook up the second output to the same tv, and use output 1 for regular, and output 2 for 3d content?
Mugenstylus1 is offline
Old 02-05-2012, 05:25 AM
howardru's Avatar
For Blu-ray i would recommend setting your player for bitstream output so the receiver does the decoding. This way the receiver will play the best audio stream on the disc. You can always setup the default audio format for the DVD/Blu-Ray player. Do this, in the source mode, and select the default for the input source for that mode. You'll see a lot of "Last Valid" on this screen. For me, I have used Dolby Digital Expanded for my 7.1 and recently switched to THX Surround Expanded after reading that they Dolby licensed the THX technology.
Not quite what you are asking on your 2nd question, but I do have two audio out sources. Primary audio from the TV is over HDMI from the video source such as my Tivo, PS-3 or other. I also have an Optical output from the TV if I want to use the built-in tuner from the TV for picture in picture or other reason.
howardru is offline
Old 02-05-2012, 06:19 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Originally Posted by Baherrick View Post
Looks like I am ok. I can actually can start hearing at -60db and at -30 db it is fairly loud. I guess i thought there was an issue because the bar graph is over half and I relate that to turning the the knob on my old stereo up half way. It would be way to loud. I appreciate your help and patience.
You can't compare your old stereo to the newer models which use logarithmic scales such that the volume must be turned up beyond half way to get loud. Also note that once using the "relative" volume mode, you're better served keeping the volume below 0db as going above that requires an excessive amount of extra power.
jdsmoothie is online now
Old 02-05-2012, 06:59 AM
Muzikal-JRNE's Avatar
I bought the 709 a few weeks ago and it is awesome! The sound quality, video processing and Audussey XT are great. The only issue I have is when I switch sources, change a listening modes or mute when there is sound going through the speakers, there is a pop sound immediately after I initiate the command. I upgraded from a 607 that did not do this. Any thoughts or suggestions are greatly appreciated.
Cheers, Joe
Muzikal-JRNE is offline
Old 02-05-2012, 08:30 AM
I think what I am asking is if I can use both hdmi outputs on the 709 to the same tv. Using one for just 3d viewing. ( i ask only cause it is a pain in the ass to turn my tv's 3d mode on)
Old 02-05-2012, 08:38 AM
jdsmoothie's Avatar
Liked: 5508
The fact the outputs are going to the same TV shouldn't matter, although the 3D vs. 2D setting may limit both outputs to 2D only. Give it a try and report back with your results.
Old 02-05-2012, 08:42 AM
I will try it out. Like i said, it would be easier to switch inputs on my tv with one having 3d always on, and the other not.
Old 02-05-2012, 08:53 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Mugenstylus1, curious about your tv. So you're able to set 3d mode for each individual HDMI input?
Example:
HDMI-1 (2d)
HDMI-2 (3d)
HDMI-3 (2d)
HDMI-4 (2d)
JChin is offline
Old 02-05-2012, 09:07 AM
Example:
HDMI-1 (2d)
HDMI-2 (3d)
HDMI-3 (2d)
HDMI-4 (2d)
Yes i am able to. Just leave 3d turned on one of my inputs
Its a Mitsubishi 65737 (if im
Not mistaken)
Old 02-05-2012, 10:52 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Not mistaken)
Thats good to know when I shop for a 3d tv, thanks.
JChin is offline
Old 02-05-2012, 01:00 PM
bh82930's Avatar
I've posted this on the Onkyo USA Product Support forum and I'm wondering is anyone here has experienced this:
I have a TX-NR709 connected to an external amp for front, center and surround channels and using the receiver's amp for front height channels (7.1) and single surround rear channel (6.1).
I've noticed that during Blu-ray or HD DVD playback when there is a change in audio format, say from PCM in a menu to Dolby D or back for a main feature or extra, a subtle but audible snap or pop in the left / right surround speakers - predominately in the left surround - right before normal audio resumes. These pops are not random but directly related to the change in audio format. The sound is coming from the speakers, not from a relay in the receiver.
My problem sources are an Oppo BDP-83 for Blu-ray and Toshiba HD-XA2 for HD DVD.
My Dish Network receiver - 722k - does not produce this loud of a sound (there is a sound during format change, but your ear has to be right up next to the speaker to hear - not an issue for normal usage).
All are audio over HDMI.
Has anyone else experienced this?
Thanks for any feedback.
bh82930 is offline
Old 02-05-2012, 03:03 PM
Mine is a rear projection lcd. If that helps
Old 02-05-2012, 07:56 PM
charlievoviii's Avatar
Originally Posted by primetimeguy View Post
You can adjuster the center channel level and audio sync in the Audio menu but hose are only temporary settings. You need to go into the setup and speakr level menus for those changes to be permanent. But I do not believe the audio sync has a permanent option.
thanks for your answer, yeah i have figured out the speakers audio, but man that suck i have to manually adjust AV sync every time i turn it on. hopefully next firmware fix this issues.
charlievoviii is offline
Old 02-05-2012, 08:40 PM
Baherrick's Avatar
Thanks for the info.
Baherrick is offline
Old 02-06-2012, 10:26 AM
volzalum's Avatar
This is not my receiver, but a friends. I have read all 31 pages of this thread and the owners manual but have not found the answer to this:
Set-up:
Dish HDMI to HDMI 3 in
Dish Analog sound to Analog 3 in
Blue Ray to HDMI 1 in
Blue Ray Analog sound to Analog 1 in
AppleTV HDMI to HDMI 5 in
AppleTV optical sound converted to analog sound to Analog 5 in
709 HDMI main to TV1 HDMI 1 in
709 HDMI sub to TV2 HDMI 1 in
709 wired to speakers for 5.1 + FrontWide/Zone 2 in location with TV2
709 Zone 2 analog pre-out to TV 2 Analog 1 in for HDMI 1
709 Zone 2 powered speaker 'off'
709 Monitor Out 'both'
709 Zone 2 'on'
When watching/listening to same source, all sound works: i.e., Main Room has 5.1, second location has sound out of FrontWide speakers controlled by 709 and TV2 controlled by TV2.
My friend would like to be able to turn on the monitors (TV1 and TV2) for a single video source (say basketball game), but listen to sound from different source say AppleTV out of the 709 wired speakers (5.1 + FrontWide).
1) Is this possible with this receiver?
2) If so, can it do digital sound sources (HDMI ones) or can the alternate sound only be the analog choices?
3) If so, How?
I am assuming this is possible since every HT receiver I have ever owned back to the late 80's has been able to choose different video sources to output, but we were not able to figure it out on the 709.
volzalum is offline
Old 02-07-2012, 09:15 AM
pimp's Avatar
Hi All,
Im tryin to connect my LG Blu-Ray player, BD610, to my 709, but no picture will show. I see the "LG" splash screen but the screen goes blank after that. I hear the audio but no picture shows. "HDMI" & "No Signal" blinks on the receiver as the sound cuts in & out. I plugged the player directly to the tv(Sharp LC60E79U) and it works, but not thru the 709. I've changed to different inputs on the 709 but to no avail. I've also changed inputs on the TV & still does not show picture. I've also plugged my PS3 to every input the LG didnt work in and the PS3 works perfectly every time. Is there a setting that I need to change in the 709 to get the picture to show? Please Help!!!
P.S. I have also tried different HDMI cables in different inputs.
Thanks in Advance!!!
pimp is offline
Old 02-07-2012, 09:21 AM
enthuzist's Avatar
I know this may sound crazy, but do you have another HDMI cable? If so, then try it if it is a different model cable. I had the same issue with my Samsung brp.
Mitsubishi WD-92842, Onkyo HT-S9400THX, Oppo BDP-93, XBOX 360 w/Kinect, XBOX (modded), WD My Book Essential, FiOS Bundle
enthuzist is offline
Old 02-07-2012, 09:35 AM
Any thoughts or comments about this issue?
Thanks, Joe
Old 02-07-2012, 09:48 AM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 376
Thanks, Joe
I have no idea? Mine never does this and that's not normal behavior.
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT L/R Bypass ~ Power Sound Audio XV15
D Bone is offline
Old 02-07-2012, 09:56 AM
jbug's Avatar
Quoted: 248 Post(s)
Liked: 127
I have a SACD player connected via analog inputs. I'd like to know how you are supposed to get analog pass-through. It would have been nice to see a input selection for this but I guess multi-channel sound is a thing of the past now. Anyway, I don't want any surround sound processing of the rear channels, just straight decode but I haven't found that option. The analog input is selected with the BD/DVD button but again I've seen no way to bypass all the processing options.
jbug is offline
Old 02-07-2012, 09:57 AM
pimp's Avatar
Yes, I have tried different cables. Still not working.
pimp is offline
Old 02-07-2012, 10:02 AM
jdsmoothie's Avatar
Liked: 5508
Originally Posted by pimp View Post
Hi All,
fF the BD610 has a "Deep Color Output" setting, then set it to OFF.
Old 02-07-2012, 10:04 AM
enthuzist's Avatar
Have you tried using different power on sequences? Does the LG have the latest firmware?
Old 02-07-2012, 10:06 AM
enthuzist's Avatar
I keep reading this on this forum. What are the issues with "Deep Color"?
Old 02-07-2012, 10:15 AM
jdsmoothie's Avatar
Liked: 5508
It can cause issues with some brands of AVRs (often with the PS3) and as there is no such content available yet, setting it to OFF is no issue.
Old 02-07-2012, 10:23 AM
pimp's Avatar
Thanks, but unfortunately the BD610 does not have this setting like my PS3 does. I have tried different startup sequences also. Something happens after the splash screen to make the screen go black. Im reading the manual online to see what settings could create this issue. I have realized that there is a firmware update available for this player. I will update it when I get home. The manual also states to turn the "receiver" on 1st for 30secs before turning the player on. I will try the firmware update and this startup sequence and report back. I highly doubt this will work, since small adjustments like these never work for me like they do for others, but I still will give it a try.
pimp is offline
Old 02-07-2012, 10:30 AM
jdsmoothie's Avatar
Liked: 5508
You'd be surprised .. both up to date firmware and startup sequence can make a huge difference. Ensure the 709 firmware is up to date as well.
Old 02-07-2012, 10:46 AM
jimmy3d's Avatar
I'm having the same problem with a LG BD570. If I leave the Onkyo off, the BD player has no trouble connecting to my Sharp LC60 835. However running through the receiver, connecting is hit or miss. Firmware on my LG is up to date but I haven't run it on the Onkyo yet.
jimmy3d is offline
Old 02-07-2012, 10:47 AM
pimp's Avatar
My fingers are definately crossed. My 709 is definately up-to-date. Is the standard startup sequence: TV->Receiver->Source?
pimp is offline
Old 02-07-2012, 10:49 AM
jdsmoothie's Avatar
Liked: 5508
Denon has used firmware updates to resolve issues with specific BDPs having issues connecting, so definitely make sure the AVR's firmware is up to date. Yes, that is the "standard" startup sequence to mitigate HDMI handshake issues, although when it doesn't work, sometimes turning the AVR on first will do the trick.
Receivers Amplifiers , Onkyo Tx Nr709
