Onkyo TX NR709 Owners' Thread - Page 82 - AVS Forum
post #2431 of 2436 Old Yesterday, 10:17 AM
splatee's Avatar
It was repaired 2 weeks ago. I just picked up the Hafler dh-220 amp yesterday. So before that I never had a need to use the pre-outs on the Onkyo.
Thank you
splatee is online now
post #2432 of 2436 Old Yesterday, 11:56 AM
azz7686's Avatar
I see just got mine back on tuesday but got my new receiver friday so anyway how is the new amplifier working other than the issue and is the issue with any input?
azz7686 is offline
post #2433 of 2436 Old Yesterday, 12:39 PM
splatee's Avatar
Well I have not really had a chance to run it yet. I need to run Audyssey again so it can adjust the levels to the amp. So with the left channel not working it won't even run through the setup. I tested it at the sellers place and it sounded pretty good to me. It is in excellent original condition with barely a scratch on it.
post #2434 of 2436 Old Yesterday, 03:30 PM
splatee's Avatar
Update time......
It is fixed. Took the pre-amp board out and it had a weak solder point on the "left" output. Resolder it and it is working. On e problem though I popped a tweeter on one of the Polks. I guess yesterday when I was swapping RCA cables there was a loud pop sound. That will be another fix..
But the sound is amazing. A lot more depth to it. I still need to run Audyssey again.
Thank you
post #2435 of 2436 Old Yesterday, 05:35 PM
azz7686's Avatar
Sounds good is the output board the one on the bottom that the speaker lugs go to? Ive had mine apart also before I sent it in trying the youtube fix with desoldering caps and the oven trick I am surprised they even fixed it lol.
azz7686 is offline
post #2436 of 2436 Old Yesterday, 06:00 PM
splatee's Avatar
The output board is right above the speaker terminals. Pretty easy to get to, just remove HDMI board, then take back panel off the make it easier to take out the other boards.
Oh and I fixed the issue with the speaker. Turned out I didn't have the terminals on the speaker tightened down so the jumpers did not make a connection with the top. So it is all good now.
Thank you
Receivers Amplifiers , Onkyo Tx Nr709
Gear in this thread - Nr709 by PriceGrabber.com
