Onkyo TX NR709 Owners' Thread - Page 85 - AVS | Home Theater Discussions And Reviews
post #2521 of 2531 Old 06-04-2015, 12:29 PM
diwal's Avatar
Liked: 29
Thank you.
diwal is offline
post #2522 of 2531 Old 06-14-2015, 05:17 PM
barryaz1's Avatar
So after 2 1/2 years of having the 709, I'm just starting to try to use the DLNA function. Most of my music files are on my ASUS PC, on the D: part of the hard drive (and important ones backed up to the Cloud). When I access DLNA, it shows my PC on the network, and then Music, and then Folders, only the C: and Shared Music appear, not the D:, although the Folder I want is on D: and has even been added to my Music Library. How do I get to D: and this Folder. And if I moved it all to an EHD, would it have trouble finding it there, too?
ID:	776425   Click image for larger version
ID:	776433   Click image for larger version
ID:	776441   Click image for larger version
ID:	776449   Click image for larger version
ID:	776465   Click image for larger version
barryaz1 is offline
post #2523 of 2531 Old 06-14-2015, 07:57 PM
azz7686's Avatar
Quoted: 43 Post(s)
Setup that drive/folder to share in my computer under hdd D: otherwise you can't see it on network
2-RTi-10's 1-CSi5 2-TSi400 6-r150's 1-Velodyne DPS-12
Yamaha RX-A3030 and Emotiva XPA-200
Samsung UN65F7100
azz7686 is online now
post #2524 of 2531 Old 06-15-2015, 10:10 PM
barryaz1's Avatar
"How do I get to D: and this Folder?"
"Setup that drive/folder to share in my computer under hdd D: otherwise you can't see it on network"
Got it! Had to share both the d: and the Folder itself.
That's what I love about these Forums. Whether I'm getting advice about my cars, computers or A/V or helping someone else out, these are wonderful resources!
barryaz1 is offline
post #2525 of 2531 Old 06-16-2015, 06:56 PM
azz7686's Avatar
Quoted: 43 Post(s)
I 2nd that also and GLAD to help cause I've received plenty on here.
Samsung UN65F7100
post #2526 of 2531 Old Yesterday, 05:14 AM
Prognathous's Avatar
Quoted: 13 Post(s)
Has anyone managed to identify why and when the NR709 display "Multich" instead of DTS/Dolby Digital? It clearly decodes the signal correctly and everything sounds fine, but the display is just a generic "Multich".
Prognathous is offline
post #2527 of 2531 Old Yesterday, 08:55 AM
azz7686's Avatar
Quoted: 43 Post(s)
The device or source I assume is connected via Hdmi so change the divide from pcm to bitstream.
Samsung UN65F7100
post #2528 of 2531 Old Yesterday, 11:38 AM
Quoted: 13 Post(s)
It's an HTPC connected through HDMI. Using the same players (PowerDVD 14, PotPlayer, Zoom Player Pro and others), the encoding of some files is displayed correctly by the receiver, but for others it just shows "Multich". I configured the players to pass-through the audio to the display. Is this what you mean?
post #2529 of 2531 Old Today, 02:17 PM
MANTI5's Avatar
I'm having an issue playing netflix through the WiiU, audio shows up as Multichannel with no surround sound. Flipping through the various presets makes no difference until it gets to all channel stereo. It's connected by HDMI and I'm sure there must be a setting I'm missing as I don't remember this problem before sending it in for the recall and it being factory reset. I didn't use the WiiU for netflix much until our bluray player died so maybe I'm wrong and it never decoded to surround.
MANTI5 is offline
post #2530 of 2531 Old Today, 05:54 PM
azz7686's Avatar
Quoted: 43 Post(s)
I was thinking more of the lines of you having a ps3-4 usually you see this issue but a pc you will need codecs I believe there is a thread/site to remedy this but I don't remember the site/program will do some hunting!
Samsung UN65F7100
post #2531 of 2531 Old Today, 06:12 PM
azz7686's Avatar
Quoted: 43 Post(s)
try this http://www.shark007.net may help if questions go to maximumpc.com and look up htpc.
Samsung UN65F7100
Receivers Amplifiers , Onkyo Tx Nr709
Gear in this thread - Nr709 by PriceGrabber.com
