5.1 "decoder" without the "amplifier"??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-13-2011, 04:45 PM - Thread Starter
dutchswan0311's Avatar
I am putting together a Dinner Theater at a winery and need some help with a preamp or decoder. I am technically savvy, but have never before encountered a situation in which each of my speakers had their own amplifier. I am trying to figure out how to decode a 5.1 or 7.2 surround system, but without a "decoder" that also is an amplifier. That is to say, I need a receiver that will put the 5.1 signal to each amplifier, while the receiver itself does not have to do any amplification. I am sure I am mixing my terms, but just need to get steered in the right direction.
dutchswan0311 is offline
post #2 of 7 Old 06-13-2011, 04:51 PM
hodgjy's Avatar
It sounds like what you're after is a pre-amplifier-decoder and power amplifier combo. Such kits exist.
The preamplifier will decode the signal and send it off to a power amplifier.
I'm not sure why you insist on separate units, but they do exist. Most people just get an integrated amplifier, which has the pre-amp and power amp in one unit.
Edit: I now understand why you need only the pre-amp; it's because your speakers are powered.
This is the type of unit you are looking for:
http://www.audioadvisor.com/prodinfo...umber=MAAV7005
If you search, you are looking for a surround sound pre-amplifier.
hodgjy is offline
post #3 of 7 Old 06-13-2011, 04:55 PM
jdsmoothie's Avatar
Quoted: 14358 Post(s)
Liked: 6782
You can use either a DD 5.1 preamp or AVR with preouts either of which you can connect the powered speakers to play the decoded DD audio.
jdsmoothie is offline
post #4 of 7 Old 06-13-2011, 04:55 PM - Thread Starter
I don't insist; I just want to be sure that I am not overpowering my speakers. For instance, if one of the LCR speakers is a 350w unit, and is being powered by a 350w Amp, I don't want to hook it up to a 5.1 receiver that also amplifies at 100w and have the overall signal transmit at 450w. I am not sure if such a thing is even a danger, but I don't know what I don't know when it comes to using speakers that are amplified independently of the receiver.
post #5 of 7 Old 06-13-2011, 04:59 PM
jdsmoothie's Avatar
Liked: 6782
There is no cumulative addition of power when connecting to an AVR's preouts, rather the power comes from the speaker's amp only and the signal comes from the AVR.
post #6 of 7 Old 06-13-2011, 05:05 PM - Thread Starter
@jds...that is good to know. Forgive my ignorance, but how do I know if I am connecting to the preouts? Rather, do the "preouts" look different than the other "outs". *rolls eyes at self. I am tech savvy....no really.
post #7 of 7 Old 06-13-2011, 05:08 PM - Thread Starter
after examining the back of a AVR with pre-outs...I see that they are just RCA jacks that are labeled "preouts". duh. No wonder there are some really expensive AVRs that have very little amplification; the target audience is not looking for amplification.
