"Official" Onkyo TX-NR809 Thread - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #3481 of 6542 Old 02-19-2012, 01:43 AM
wl1
wl1's Avatar
Quoted: 181 Post(s)
Liked: 156
Originally Posted by JBrax View Post
It just seems the commentary or dialogue is very muted with sporting events. I sometimes notice it with movies as well. Previously I had always used THX cinema and just recently started using "through" with dynamic eq on so most cable programming is now Dolby Digital. Since the switch it seems the dialogue is not as loud from my center channel (Klipsch rf-62ii).
Is this relevant?
http://www.avsforum.com/avs-vb/showt...9#post21575179
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #3482 of 6542 Old 02-19-2012, 02:07 AM
JBrax's Avatar
Quoted: 46 Post(s)
Liked: 32
Yes
JBrax is offline
post #3483 of 6542 Old 02-19-2012, 02:21 AM
wl1
wl1's Avatar
Quoted: 181 Post(s)
Liked: 156
Yes
http://www.dolby.com/uploadedFiles/z..._Operation.pdf
I was trying to find a post regarding the "dialog" setting within a broadcast can be changed. But came across this.
I can't recall exactly when my 809 comes up with Dialog, when it first decodes, but it may be relevant.
wl1 is offline
post #3484 of 6542 Old 02-19-2012, 04:17 AM
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
I experience the "drowned" out commentary as well on certain channels when watching sports. I Haven't figured it out yet. The only thing that helped a little was to set dynamic volume to high. The dialouge in movies is typically fine though.
cadett is offline
post #3485 of 6542 Old 02-19-2012, 05:10 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
The last superbowl was bad, I would only guess it was a double dsp processing (source and hardware) matrixing caused the karaoke effect ( very weak commentary or dialogue) with overly loud crowd effects. 5 channel stereo or full mono worked good , stereo and DTS Surround Sensation or T-D (Theater-Dimensional) all sounded great.. Thats why there are so many choices...
joehonest is offline
post #3486 of 6542 Old 02-19-2012, 11:30 AM
wl1
wl1's Avatar
Quoted: 181 Post(s)
Liked: 156
http://en.wikipedia.org/wiki/Dialnorm
This is what I was referring to earlier.
wl1 is offline
post #3487 of 6542 Old 02-19-2012, 11:41 AM
JBrax's Avatar
Quoted: 46 Post(s)
Liked: 32
Exactly!
JBrax is offline
post #3488 of 6542 Old 02-19-2012, 11:44 AM
JBrax's Avatar
Quoted: 46 Post(s)
Liked: 32
You may have lost me a bit on this one but yes that's probably pertinent with my situation.
JBrax is offline
post #3489 of 6542 Old 02-19-2012, 02:36 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Is it possible to shuffle songs played through a USB drive?
I can only advance song by song.
bad1550 is offline
post #3490 of 6542 Old 02-20-2012, 12:35 PM
Islandborn's Avatar
quick question-got my 809 set up yesterday...Does the unit display any light on the power button to signify if it is on or off? My 875 power button would turn red when off..I have the blue light around the volume knob, but was wondering if there is any other lights minus whats in the display? thanks.
Islandborn is offline
post #3491 of 6542 Old 02-20-2012, 12:59 PM
wl1
wl1's Avatar
Quoted: 181 Post(s)
Liked: 156
No. Fewer lights the better for me.
You can also turn off the volume light, and then dim the display down, with consecutive presses of the Dimmer button.
wl1 is offline
post #3492 of 6542 Old 02-20-2012, 01:12 PM
Islandborn's Avatar
Thanks for the reply...Another quick question..can u explain a little about the networking on the 809...I saw some videos on you tube and I really LOVE the idea of doing firmware updates via the internet then having to install manually...
Does the 809 need the Onkyo ufw-1 to function wirelessly? Or can I use any wireless usb adapter? I have a samsung wireless adapter for a bluray player I bought last year...would it work? I guess I could just try it but wanted to ask in advance...Also, I read that the usb wireless adaptersw have to be plugged into the front usb connector and not the back to work correctly..any confirmation to this?
post #3493 of 6542 Old 02-20-2012, 02:09 PM
wl1
wl1's Avatar
Quoted: 181 Post(s)
Liked: 156
Firmware updates are done very infrequently, and most people's goal is to achieve success. On any device, updating firmware is risky - attempting to do this over wifi and the Internet is not recommended.
This amp has Net features, and the manual recommends Wired Ethernet to ensure no dropouts.
There have been other wifi adaptors recommended by others on here, which are much cheaper. I think these are a last resort. Power line Adaptor methods would prove more successful if wired is difficult.
Sorry to be so negative - but wired will get the best results for Net functions. With firmware best done over USB drive.
wl1 is offline
post #3494 of 6542 Old 02-20-2012, 02:50 PM
bigjohns1997SS's Avatar
I all of my sources are 1080p to begin with, does this mean that the hqv video processor isn't going to do anything for me?
Samsung D7000 65"
Onkyo 809
BIH F12
6x Energy RC-10
WMC ceton4 DVR/Media PC
bigjohns1997SS is offline
post #3495 of 6542 Old 02-20-2012, 03:17 PM
Islandborn's Avatar
The hqv is there to either upconvert standard def sources to 1080p output. for instance if you are using an old dvd player you can use the chip in the onkyo to upconvert the signal and enhance detail to 1080p. For the most of us, we will be using the passthrough setting as our blu ray players, stb, etc. will already be decoding via a high def format so set the onkyo to passthrough the high def signal would be my choice.
post #3496 of 6542 Old 02-20-2012, 03:41 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
I recently picked up the 809. My 5.1 speakers are the Boston Accoustics MCS 160. Are the Energy Take Classic 5.1 5.1CH Premium Home Theater System a better choice or should I keep what I have?
Bob
bad1550 is offline
post #3497 of 6542 Old 02-20-2012, 09:52 PM
Replacement's Avatar
Looks like I'm going to join the 809 club. I currently have a 803 (with a 7.1 Klipsch Reference 82's w/surround) and it doesn't handle hdmi 1.4. I'm also getting a Panny 65gt30 delivered in the morning, bb has them on sale (the main reason for the 809 upgrade). I see that the 809 up converts all signals to 1080p, does it do a really good job of this or is SD still going to look bad? I also was wondering what this business of up converting to 4k is. Is that the next resolution that is planned to be available? I can't wait to watch me some HD with my new tv and receiver (I have Terminator 4 in mind).
"Having a smoking section in a restaurant is like having a peeing section in a pool."
Replacement is offline
post #3498 of 6542 Old 02-20-2012, 10:17 PM
Gomez81's Avatar
Posting here as well.......
Am I doing the calibration incorrectly??......
I just bought a new sub and ran audessey. I placed the supplied mic on my tripod and in main listening position. I turned off all ambient noise from surroundings.
I began the test, but sub was not on. On the display, I noticed that the spl level was hovering around 40db.
I am concerned that this is wrong. Should be close to zero in a perfect situation, correct?
What do I do? Is there something wrong with my 809
avr?
Gomez81 is offline
post #3499 of 6542 Old 02-21-2012, 03:29 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
You have to account for background noise ... the only way it would be 0db is if you were in an anachoic chamber.
jdsmoothie is offline
post #3500 of 6542 Old 02-21-2012, 03:37 AM
jdsmoothie's Avatar
Liked: 5508
How well the AVR upscales depends on whether the source or TV can upscale any better. And unless you plan on going to a display > 100", 4K shouldn't even be a consideration.
post #3501 of 6542 Old 02-21-2012, 06:21 AM
FantaXP7's Avatar
Quoted: 44 Post(s)
Liked: 38
THX Loudness Plus...I was looking through my receivers settings and saw this so I turned it off. I am getting much better sounding dialog out of my center.
I don't remember turning it on, maybe Audyssey turned it on? Anyway if anyone has it on, try turning it off. Might help others.
FantaXP7 is offline
post #3502 of 6542 Old 02-21-2012, 03:35 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Can someone recommend a 5.1 speaker system to pair with my 809.
$300-$500 Range?
bad1550 is offline
post #3503 of 6542 Old 02-21-2012, 04:05 PM
PeterTHX's Avatar
Quoted: 327 Post(s)
Liked: 246
$300-$500 Range?
Hmm. That's kind of limited for performance. The power of the 809 could easily destroy speakers of that quality/price-range.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #3504 of 6542 Old 02-21-2012, 04:09 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Any suggestions - I will have to raise my budget
bad1550 is offline
post #3505 of 6542 Old 02-21-2012, 04:20 PM
grendelrt's Avatar
Quoted: 134 Post(s)
Liked: 66
Buy in steps so you can get something higher quality. That's what I did last time and it worked out well. I bought my FL, FR, and Center in one transaction. Then a couple months or so later I bought the RL, RR, and sub. Personally I went with Klipsch reference series stuff, but you really should go listen to some speakers before you make a decision everyone has different tastes.
grendelrt is offline
post #3506 of 6542 Old 02-21-2012, 04:22 PM
wingman1659's Avatar
$300-$500 Range?
You could go with a Polk Monitor series setup (60, 30, center), the sub choice is on you though as I don't recommend a psw
wingman1659 is offline
post #3507 of 6542 Old 02-21-2012, 05:11 PM
jdsmoothie's Avatar
Liked: 5508
$300-$500 Range?
No, but you might want to consider trading in the 809 for a 609 so you can increase your speaker budget. Speaker budget should be 2x-3x that of the AVR budget, otherwise you're just going overkill on the AVR.
post #3508 of 6542 Old 02-21-2012, 05:36 PM
jmpage2's Avatar
Quoted: 12 Post(s)
Liked: 80
Exactly. The speakers are the single most important component in a setup and should take up the lion's share of the budget.
You'd be better off getting a budget AVR and better speakers than springing for a mid-level AVR and getting cheap-o speakers.
Polk monitors are a pretty solid recommendation at the absolute entry level of what is out there that is decent.
jmpage2 is offline
post #3509 of 6542 Old 02-21-2012, 05:38 PM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Thanks for all of the advice.
Wll save for the better speakers!
bad1550 is offline
post #3510 of 6542 Old 02-21-2012, 10:08 PM
korn646's Avatar
+1 for Polk, I went with the Tsi series for my fronts and center, along with a comparable in-ceiling pair of Polks for the rears. I think they sound great with my 809. The monitor series speakers from them are really only cosmetically different from the Tsi, and would make a good choice for you being on a budget. Watch Techbargains for great deals from Newegg... or Polk also has great deals on direct refurbs on Ebay.
65VT50
NR809
TSI500
CS20
RC85i
SB13 Ultra
korn646 is offline
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
