"Official" Onkyo TX-NR809 Thread - Page 206 - AVS Forum
post #6151 of 6158 Old 10-19-2014, 09:30 AM
aaranddeeman's Avatar
Quoted: 66 Post(s)
Originally Posted by fivehead1 View Post
Hi guys, I have a question...
I found an old equalizer in my basement, and I would like to hook it up to my NR809. Can I connect it to the "front" RCA outputs, into the EQ, and back into the "front" RCA's? Will this allow me to shape the sound for Pandora?
Thanks a lot for any info on this!
The front RCA on 809 are inputs and not outputs. May be if you could draw a picture as to what your intent is, that would help.
aaranddeeman is offline
post #6152 of 6158 Old 10-19-2014, 09:49 AM
fivehead1's Avatar
On the back of the receiver, there are rca's labeled "front" in the preamp section. I'm sorry for any confusion.
fivehead1 is offline
post #6153 of 6158 Old 10-20-2014, 05:58 AM
dr_gallup's Avatar
I don't think you can do what you suggest as you would have to use the front panel jacks as an input, eliminating Pandora as a source. However, you could set zone 2 to the Pandora source, take the zone 2 line out into your EQ and send the output into the any of the unused inputs front or back.
dr_gallup is offline
post #6154 of 6158 Old Yesterday, 03:13 PM
vcrpro3's Avatar
Quoted: 29 Post(s)
I am ready to put a refurb TX-NR809 in to service that i got from AC4LS almost 2 years ago but never used...any tips to protect agaisnt the dreaded HDMI board failure syndrome? I am putting the unit on a stand, not in a cabinet so there will be adequate ventilation around it.
vcrpro3 is online now
post #6155 of 6158 Old Yesterday, 03:32 PM
rfb6435's Avatar
Quoted: 18 Post(s)
Add a laptop cooling pad on top that has a 180 - 220 mm fan that sucks upward. That drops the temp significantly.
rfb6435 is offline
post #6156 of 6158 Old Yesterday, 04:00 PM
Ray77085's Avatar
Quoted: 81 Post(s)
Liked: 93
Good info on the fans !! I have had a ANTEC A/V COOLER on my 809 since day one and on low speed 24-7 !!
vcrpro3 likes this.
MY 7.4 SET UP. Not Perfect But Let's Just Say I'm Happy !!
Onkyo TX-NR809, (Klipsch-KF-28 mains),( Center KC-25), (Front wide- Primus P363), (AR-Stature S20 side surrounds).2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #6157 of 6158 Old Today, 04:38 PM
dawg's Avatar
Help with HDMI ARC problem
I have a Samsung UN75f8000 setup using anynet+ and the Onkyo 809 setup using HDMI control. I use the DirectTV to remote to power on the TV which in turns powers up the 809. It works momentarily but after a few seconds the audio goes out and the receiver shows 'analog' on the screen vs HDMI. To get the audio back on, I have to switch the TV input off the satellite and then back onto the satellite. Then I have audio again. I can reproduce this every single time and I have also found other posts on the internet that seem to describe the same symptoms. I do not know if this applies to all firmwares as my TV and Onkyo are all upgraded to the latest. I did read a post elsewhere where the owner had the same problem but only after upgrading to latest firmware. My receiver did work well before with ARC using a Vizio TV and older Onkyo firmware but when I recently got this new TV I upgraded my Onkyo firmware at the same time. Is there a fix for this? Is this potentially related to that repair recall?
dawg is offline
post #6158 of 6158 Old Today, 07:44 PM
Quoted: 66 Post(s)
Oh okay.
IMHO that is not such a good idea just to use that old EQ. Not much you can get apart from the complicating the connections and possibly landing into some ground loop hum..
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
Gear in this thread - Nr809 by PriceGrabber.com
