"Official" Onkyo TX-NR809 Thread - Page 207 - AVS Forum
post #6181 of 6191 Old 11-09-2014, 09:51 PM
swamp2's Avatar
Originally Posted by wrstdude View Post
Is this the type of cable you got? http://www.monoprice.com/Product?c_i...seq=1&format=2
I just did the same thing and I'm currently trying to figure out how to get sound back to my speakers and not through my TV. I'm reading in the manual right now and I can't seem to figure out how to select the ARC through my Onkyo...
That looks equivalent to the cable I bought - its just a standard "TOSLINK" or optical cable.
You will have to make changes on both your TV and receiver to route the sound back to the receiver. I don't have the receiver setting memorized but I can double check if you can't get it working.
I DON'T have an ARC TV and am pretty sure to use ARC you need both the TV and receiver to be ARC.
swamp2 is offline
post #6182 of 6191 Old 11-10-2014, 08:13 AM
wrstdude's Avatar
I actually figured out how to activate the ARC setting in the receiver as I have an ARC TV. So, thankfully, I don't need to buy any additional cables. Thanks for your help!
wrstdude is offline
post #6183 of 6191 Old 11-11-2014, 09:48 PM
hdtv00's Avatar
Quoted: 16 Post(s)
Amazing to me how these units seem to be dropping like flies. Add another one to the pile. Today mine went silent. It first did it on Nov. 3rd but I was hurrying to make an important phone call at the time and I thought not so much of it. After on and off later that day it came back, it was not showing the speaker channel icons on front display making no audio from any type of source, video via hdmi would still work just fine. So not a single issue since the Nov 3rd but today it wouldn't' turn on sound wise at all. And lasted 6 hrs or so. Finally started showing speaker icons again and has sound.
Went through same process went to site entered my serial # and it said congrats you can get repair or $175 off another overpriced unit direct from Onkyo. Anyway so I guess I leave my unit on until the box to ship it in comes.
This is my 2nd failure from Onkyo receiver first was 876 model. Which they refused to fix , amoung first units to have hdmi board issues and they never made it right and took me for $1000 then, now this unit screwing up costing me $800 more from a failed model. I think my time with Onkyo is over, you won't steal from me again.
Anyway SIX years later nice to finally take some kind of action Onkyo albeit to late for many.
i7 4770K/16 gig 2133/GTX 680 840 PRO SSD
Paradigm Studio 100/570/20's/2200 Sub
Onkyo 809 42" LCD/Panny AE4000
hdtv00 is offline
post #6184 of 6191 Old 11-12-2014, 11:16 AM
CCSchoch's Avatar
Quoted: 23 Post(s)
Understand your frustration. But follow link I posted on here last week and get it touch with Jose w/ email provided on this thread. I sent off my receiver on a Sat from Fed Ex and got it back by Thursday. (All w/ prepaid freight from Onkyo).
From first email to Jose to getting back my receiver was only 2 weeks downtime. Frustrating yes, but back up and running now w/ no issues.
Good Luck
CCSchoch is offline
post #6185 of 6191 Old 11-12-2014, 05:37 PM
Liked: 0
Does anyone know if I can use the Air Port Express with my Zone 2. My book seems to say that zone 2 devices have to be an analog devices. The air Port Express needs a digital input from what I can tell.
Rich
rwilabee is offline
post #6186 of 6191 Old 11-18-2014, 04:36 PM
morpheus305's Avatar
Who's jose and how do i contact him?
morpheus305 is offline
post #6187 of 6191 Old 11-19-2014, 11:08 AM
Titanite's Avatar
TX-NR 809 2nd Zone Question
Hello,
I have tried to connect my 2nd zone to a pair of outdoor speakers. These speakers are 8 ohms, and I have set them as 6 ohm and up in the speaker set up section. When the 2nd zone is activated (powered) I have very little volume out of the speakers. I do have a volume limit switch by the door, however it is turned up all the way. I then tried hooking it up to just the main right/left speakers (Not 2nd zone) and I have lots of volume when wired that way. Is there anything hidden or different I need to do to get volume on the 2nd zone?
Thank you!
Titanite is offline
post #6188 of 6191 Old 11-19-2014, 02:29 PM
razrsharp's Avatar
So it's now been at least 3 times that my onkyo 809 goes into "audio-only" mode where no video signal is present on any source. What's worse is that it won't even allow passthrough, which it actually did before i had the HDMI board repaired.
It comes to life again after a soft reset (unplug/reboot) but this seems to be a sign of pending doom, and is highly annoying as my AV gear setup needs to be moved around in order to unplug it (making it difficult for my wife/kids to do it, and you know how that goes).
Am I over-reacting? Should I part ways with this amp (and brand) and move on?
razrsharp is offline
post #6189 of 6191 Old 11-20-2014, 07:32 AM
ltd76gold's Avatar
"When the 2nd zone is activated (powered) I have very little volume out of the speakers. I do have a volume limit switch by the door, however it is turned up all the way."
Set the zone two output to "variable". The default is "fixed" and would be used if you hooked it up to a separate amp.
Doug k
Imaging Science Foundation Technician ( Almost Retired )
www.6500kcalibrations.com
ltd76gold is offline
post #6190 of 6191 Old Yesterday, 11:45 AM
Photokid1970's Avatar
I have been busy at work and didn't get to post my day-by-day replies, but here is how it went:
The Friday following my post here, the box arrives. I pack up the 809 with the included supplies - they even gave me a roll of packing tape to seal the box! I drop it off at the Fedex store on Monday. It arrives at Onkyo on Tuesday. I thought that would start my 6-8 week waiting period. But, I got a text on Thursday from Fedex saying that I should expect a package on Monday! I had it re-routed to the Fedex Office since it required a signature.
Turns out, the text was wrong - they tried to deliver it on Saturday! If I had been home, I would have gotten it even earlier than I did. But, as it turned out, I picked it up after work Monday. Everything works just as it did on day 1. No hassles at all! I'm very impressed with the effort by Onkyo to fix this for me.
Photokid1970 is offline
post #6191 of 6191 Old Today, 12:10 AM
mbusby's Avatar
Liked: 1
I had mine serviced by a local "authorized repair facility" about three miles from my residence. It was two months before I got it back. Apparently the part needed comes from Japan which causes a month delay. Also, the first shipment they got was defective and they had to order another one. This caused another month delay. I think it would have been faster to just ship it directly to the main Onkyo service center.
mbusby is offline
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
Gear in this thread - Nr809 by PriceGrabber.com
