"Official" Onkyo TX-NR809 Thread - Page 209 - AVS | Home Theater Discussions And Reviews
post #6241 of 6258 Old 03-07-2015, 01:35 PM
Rob Reff's Avatar
Wink Please help me Drive 6 speakers same music on TX-NR809
All,
I need to re-purpose my receiver. I want to use it for a bathroom and have 6 speakers playing music (no-surround). How would you recommend I set it up?
Thanks in advance for your help!
Rob
Rob Reff is offline
post #6242 of 6258 Old 03-08-2015, 01:13 PM
ltd76gold's Avatar
Quoted: 14 Post(s)
Set it on a shelf near the tub. When somebody is in your tub that you have issues with (and perhaps is reaching for your ppk), knock it into the tub.
Should work as well as a heater... a sparkling theater, so to speak.
Doug k
ltd76gold is online now
post #6243 of 6258 Old 03-12-2015, 08:16 PM
GregF's Avatar
Question HDMI audio from TV?
Hi
I have HDMI out going to my plasma TV. I thought there was the ability for the audio from the TV to travel to AVR if I'm watching OTA channels. Am I wrong about that?
My sincere thanks to everyone who makes AVSforum such an awesome resource.
GregF is offline
post #6244 of 6258 Old 03-13-2015, 01:58 PM
bob brennan's Avatar
Quoted: 53 Post(s)
Liked: 120
Originally Posted by GregF View Post
Hi
your correct - it's called ARC (Audio Return Channel)
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony 880
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #6245 of 6258 Old 03-13-2015, 09:09 PM
GregF's Avatar
Ah but where is the setting?? I just poured over the setup menus of the Onkyo yet again and couldn't find it.
GregF is offline
post #6246 of 6258 Old 03-13-2015, 11:41 PM
mbusby's Avatar
Liked: 2
It is on page 61 of the user manual under Audio Return Channel.
GregF likes this.
mbusby is offline
post #6247 of 6258 Old 03-15-2015, 06:00 AM
dr_gallup's Avatar
Quoted: 22 Post(s)
I took me awhile to get that working. I don't remember the details but I had to set multiple things on both the TV and the receiver.
dr_gallup is offline
post #6248 of 6258 Old 03-22-2015, 06:49 PM
Replacement's Avatar
The other day my 809 stopped playing audio through HDMI, but the picture was fine. I tried FM and radio work fine as well. I unplugged it and waited a few mins and plugged it back in. I had to do that for a couple of days and then the "work around" stopped working. I did a factory reset and that didn't get it working again either. I almost connected my old 803 and decided to try the 809 before I unconnected everything and it has been working since. I didn't do anything different, it just started working again.
What issue am I looking at with my 809 and audio not playing as it should over HDMI?
Is it the HDMI board, or something else? If it is the HDMI board, what is the cost to repair?
"Having a smoking section in a restaurant is like having a peeing section in a pool."
Replacement is offline
post #6249 of 6258 Old 03-22-2015, 07:11 PM
old corps's Avatar
Quoted: 121 Post(s)
Liked: 67
Here's your solution Onkyo acknowledges failed units and extending warrranties until 2018
After you get it repaired for FREE send me a check!
BTW, this is right at the top of the audio section under "stickies". You can't miss it............well, I guess you can!
Yer welcome!
Ed
old corps is offline
post #6250 of 6258 Old 03-22-2015, 07:36 PM
GregF's Avatar
How could i miss it? Repeatedly! Thank you. Now I'm set up.
GregF is offline
post #6251 of 6258 Old 03-22-2015, 07:36 PM
GregF's Avatar
Yer welcome!
Ed
Damn I guess I bought that extended warranty for nothing!
GregF is offline
post #6252 of 6258 Old 03-23-2015, 03:09 AM
Quoted: 53 Post(s)
Liked: 120
Not really - I also bought the extended warranty. It wasn't that expensive and when I s/w Onkyo they stated that the extension only covers this one issue! Nothing else!
GregF likes this.
post #6253 of 6258 Old 04-05-2015, 04:50 AM
dricks's Avatar
Liked: 0
Hi,
I own a txnr809 since 09/2011 and a couple of weeks ago it started to not playing sound on start.
I had to wait like 20minutes and switch between TV and VCR entries before it start playing sound again.
Now, this trick doesn't seems to work anymore.
I still get HDMI display out, but no sound at all on the speaker connected to the 809, and when i use "INFO" to display audio information about the source i'm using, it says "unknown audio", wathever file i'm using (DTS or Dolby or even Stereo).
The speaker icons on the 809 stay off while they are all correctly plugged in.
I tried the factory reset but it's still failing.
I tried the RMA Form linked in this topic for the no sound problem, but after entering the S/N it said me that my unit wasn't concerned by this problem (oh really??)
Do you think it's the same broken HDMI board problem or something else ?
Pretty disappointed by now.
dricks is offline
post #6254 of 6258 Old 04-06-2015, 10:59 AM
cazual's Avatar
I would just call Onkyo and explain your situation. It sounds pretty muck like the same problem I had and I got mine repaired receiver back last Monday. Onkyo has really stepped up to the plate by taking full responsibility for this manufacturing issue.
cazual is offline
post #6255 of 6258 Old 04-13-2015, 10:27 PM
Liked: 0
Originally Posted by Onkyo_supporter View Post
Hello Razrsharp;
You should have NO worries; as we are actively assisting and monitoring all reported issues as presented. As we have done previously; if any further concerns should be addressed- we will promptly do so and inform our customers.
- Onkyo USA Product Support
This is false. here is my story,
I purchased a SR707 receiver beginning of 2010 for $500. Worked great for about 2 years and then it would lose sound intermittently. The tricks I found on forums worked at first .. power on/off, switch between sources, factory reset and soft reset. The issue grew more and more frequent and eventually the tricks couldn't fix it. I contacted Onkyo support and because it was 40 days outside of the 2 year warranty (reading these posts seems like 18 - 28 months is the average failure rate) they in a nutshell said tough luck. Well being pretty upset that my lightly used Onkyo receiver died after 2 years, I didn't like their initial response and escalated within their support dept. I had to jump through hoops .. writing and faxing a letter requesting a 45 warranty extension and sending my sales receipt. I got word back that they approved my warranty extension and was instructed to send the receiver to a Onkyo service center. I unhooked everything and made the drive to the out of the way service center (Onkyo didn't provide free shipping at this time so I figure driving would be cheaper/faster). Left it with them and they said it should be ready for pick up in a week, maybe two. Damn, this isn't going to be quick. I get a call from the service center after a week and a half and they say they don't have the part they need have to wait for Onkyo to send it to them. I'm patient so ok. I pick up my unit 3 weeks from when I dropped it and I'm just happy to have my receiver working again. I wish this was the end..
8 months later, I notice the sound dropping. Again, intermittently then more and more frequent. 1 month later it's permanent. **** me, right? Deal with support, they give me the run around. It's out of warranty. I could try dropping it off at the service center again but I would have to pay for service, wait 3 weeks, and the problem might not be solved again. Huge hassle. I go a couple months doing nothing, I move to a new place and figure, screw it, I got the one lemon, Onkyo is a great brand and pony up another $600 and go with their newer model, the NR717. Whatever issue that plagued the 707, surely it was fixed with the newer version, right? So March 2013 I purchase the 717 and hook it up in my new place. I'm so frustrated with my old 707 that I chuck it in the trash during the move. The 717 worked great. I wish my story ended here.
Just last week 4/2015, I hit the EXACT same issue as before. WTF. I go online, I see the the special "Customer Care Program" - I punch my 717's S/N in and it's affected. Just for giggles I punch my old 707 S/N in and its eligible for the program too! So imagine that. I went through hoops to get them to extended the warranty, they try to fix it, it breaks again, tell me, sorry, now's its really out of warranty, and we can't help you.. The whole time, knowing this is a CHRONIC problem with a huge number of receivers. Give them the benefit of the doubt, maybe they couldn't connect the dots and identify the pattern for a couple years .. they had my email and phone number.. wouldn't they want to inform me that the product I've been having serious issues with is now part of a massive recall? No, my guess is, they thought this was a small issue at first. Most of the time the issues would pop up after the 2 year warranty so not giving out of warranty support was their default response.. and quite frankly, the majority of people that ran into issues probably wouldn't go to support after the warranty expired. Well, that helped out a little bit, but more and more of these sound/network failures started popping up, not just across one model, but across multiple platforms. This was now a HUGE customer satisfaction issue for them. They actually lucked out because of the nature of product reviews, rarely does anyone review something 2 years after purchase date .. and their receivers were rock solid for the first year. They had internal meetings to determine what to do to minimize any damage to their reputation while maintaining and maximizing profits and they came up with the special "Customer Care Program" for streamlined service of the systems and minimize PR damage. Oh and the rebate program .. the 2 systems I spent $1100 on for them to FAIL after 2 years .. I can get $275 rebate, which is less than 1/3 of the cost of a comparable receiver. And the suit that came up with that program I can hear him now .. "we can give them a small rebate so they upgrade to our new/more expensive models where we will still make profit on. We can turn this faulty card nightmare into more revenue!" Gold star for that guy.
Onkyo folks - if you are still checking these forums: you screwed up with that faulty card. This is part is OK, people understand that products can't be 100% perfect. The part that is not OK is how you handled this issue for years before communicating any type of responsibility. Your "Customer Care Program" - for the customers that will find it - is probably sufficient for 70% of the people having these issues. And I really, really, hope that your streamed-lined repair service offers a permanent and not a temporary fix..although judging for my experience and some of the recent responses, it's not looking good. As individual consumers you have probably dealt with this issue and your good brand will live on. But taken as an aggregate - all the data points that you can see internally- I'm guessing any lawyer specializing in class action suits or product recalls would salivate after the first round of discovery. The options you have given me in your "Customer Care Program" involve me either putting my trust in Onkyo for the 4th time, which I will not do. Or spending more money with Onkyo for the 2nd time, due to your product issue, which I will not do. Respectfully, you have lost a loyal customer and I will tell others about my experience with your products.
My S/Ns are below, if you feel compelled to reach out to me with other options that eliminate my cost, risk, hassle.
0876DC6980028353
1053DC2311021097
jpdoolin is offline
post #6256 of 6258 Old 04-19-2015, 10:52 PM
astralsfire's Avatar
Quoted: 13 Post(s)
I seem to be getting a very loud hiss from my Monitor Audio spearker. It is only happening with the right surround speaker. I switched them out...same thing. Switched out speaker cables, again, no change. This is happening even when the receiver is in stand by mode. Any ideas what might be happening here?
astralsfire is offline
post #6257 of 6258 Unread Today, 11:40 AM
toofast68's Avatar
Quoted: 110 Post(s)
Liked: 27
Zone 2 Volume with Secondary AMP (AVR)
So I've tried, and I know it is possible (or I think it is)
I have zone 2 pre-outs going to a second AVR to power a set of outdoor speakers.
I want to use my Remote App to control the main AVR (809) instead of running up and down the stairs to control the volume on the secondary AVR.
I know I got this working while testing, but now that I am finally finished, for the life of me I can't figure out what I am doing wrong...any insights would be appreciated.
toofast68 is online now
post #6258 of 6258 Unread Today, 01:16 PM
ltd76gold's Avatar
Quoted: 14 Post(s)
Go to setup menu on avr.
Press 7 Hardware setup
Press 2 Multi Zone
Select the zone you wish to control from the phone.
Switch Out to Variable.
Now I set the power on max volumn to 0db and the power on volumn to -30db
Set the power amp to about mid or slightly more.
Now you can control the volume from the app
Doug k
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
Gear in this thread - Nr809 by PriceGrabber.com
