"Official" Onkyo TX-NR809 Thread - Page 210 - AVS | Home Theater Discussions And Reviews
post #6271 of 6279 Old 05-08-2015, 06:30 PM
sooner2k1's Avatar
No Network Settings Option
Is there an explanation for why the settings menu for hardware only goes from 7.1 - 7.5 for me? I'm missing the network option and the firmware option. I've googled this about 20 different ways, and I can't find anybody else describing the exact same issue.
I've downloaded the firmware and plugged it into both the front and back USB, but since I can't get the settings to work, it just says initialized and does nothing.
I'm setup through a control 4 system and my receiver doesn't output to a tv monitor to see the settings. Is there something here that I can only see on a TV?
sooner2k1 is offline
post #6272 of 6279 Old 05-08-2015, 09:14 PM
ltd76gold's Avatar
Can you take a pic of just what you are seeing please?
I think I have it but want to be sure.
Temporarily connect a small monitor to any output HDMI display.
Hit setup and go from there.
Imaging Science Foundation Technician ( Almost Retired )
www.6500kcalibrations.com
ltd76gold is offline
post #6273 of 6279 Old 05-17-2015, 01:34 AM
PeterTHX's Avatar
Quoted: 98 Post(s)
Liked: 56
Well, ARC isn't working anymore.
When I power on the receiver the TV picks it up and tries to send audio, after a few seconds it gives up and turns back on the TV speakers.
Tried powering off and unplugging the unit, powering off and unplugging the TV, replacing the HDMI cable, running through SETUP again (RIHD set to ON, ARC auto, TV/CD on ARC).
Nada.
Out of ideas, anyone have something similar occur?
My opinions do not reflect the policies of my company
PeterTHX is offline
post #6274 of 6279 Old 05-19-2015, 07:21 AM
gitarzan's Avatar
I have two problems...1. I have a new DirecTV setup and a new Samsung 75HU8550 4K. I use HDMI control on all three. When I use trick play controls on my DirecTV remote like rewind the Onkyo makes relay clicking noises as if when detecting a change in audio formats. Is this good and should it be doing it? 2. When I turn on my TV, receiver and DirecTV the input always switches to TV from CBL/SAT. I have turned off the audio return channel setting on my Onkyo but it still does it. Is there a solution to that issue? Thanks!
gitarzan is offline
post #6275 of 6279 Old 05-19-2015, 08:46 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3942 Post(s)
Liked: 2240
1. Yup.
2. Set Anynet+ to OFF and instead connect an optical cable from the TV if you want to pass smart app audio to the AVR.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #6276 of 6279 Old Yesterday, 02:42 PM
mbusby's Avatar
Liked: 2
That is an indication of a board failure and one of the reasons (the other being no audio) that I had to return it for repair.
mbusby is offline
post #6277 of 6279 Old Yesterday, 10:56 PM
PeterTHX's Avatar
Quoted: 98 Post(s)
Liked: 56
Nada.
Nobody?
PeterTHX is offline
post #6278 of 6279 Unread Today, 01:39 PM
spellitlikethis's Avatar
Hey All,
I had a quick question that I think I know the answer to but wanted some confirmation/advice. My NR809 lost functionality in an hdmi port recently (the hdmi sees no signal and just stays on the blue screen). I was disappointed, but I had a few more ports open so I just swapped to another one. It's been a couple of months now and I have lost functionality in most of my hdmi ports now. Is this indicative of the hdmi board failure that so many have experienced? I bought my receiver in December 2012 and haven't had any issue with it until a couple of months ago. Should I even try my luck with warranty support? Or is it time to move on? Do any of you suggest trying something else to get it working? I feel so upset that I might have lost my receiver...
Thanks everyone.
All Calibrations for UNXXH7150 posted to the forums compiled into an Excel Spreadsheet for easy access: Download Here from my dropbox!
spellitlikethis is online now
post #6279 of 6279 Unread Today, 01:45 PM
ilal2ielli's Avatar
Liked: 0
Originally Posted by spellitlikethis View Post
Hey All,
Thanks everyone.
There's a sticky in this forum that I cannot link yet, but yes go through the warranty, Onkyo has acknowledged and extended the warranty for these failures until 2018.
ilal2ielli is online now
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
Gear in this thread - Nr809 by PriceGrabber.com
