"Official" Onkyo TX-NR809 Thread - Page 212 - AVS Forum | Home Theater Discussions And Reviews
post #6331 of 6345 Old 08-16-2015, 03:28 PM
ltd76gold's Avatar
Quoted: 29 Post(s)
Ok, any ARC or rich are off on the lg correct?
Is it possible to run component cables to thed Lg with either an analog audio or coax/toslink digital to the Lg? Hassle....I know but just to check if for some reason a handshake issue is in play with the Lg and Sony both coming off of the 809's HDMI out.
Imaging Science Foundation Technician ( Almost Retired )
www.6500kcalibrations.com
ltd76gold is online now
post #6332 of 6345 Old 08-16-2015, 03:33 PM
caryt's Avatar
No not directly as I don't want sound from the Sony...
But when I had the 809 set for TV sound I didn't have any sound from the 5c speakers
caryt is offline
post #6333 of 6345 Old 08-16-2015, 03:39 PM
caryt's Avatar
LG is basic and doesn't have ARC or rich.
I have it set for HDMI input.
My LG placement required a 70' long Redmire HDMI cable.
Really don't want to run additional cables...it was a real pain to fish even the HDMI in..
I could remove the LG from its mount and bring it into the 809 area and get some componit cables..I may have some of them and analog audio or coax/toslink digitals.
caryt is offline
post #6334 of 6345 Old 08-16-2015, 03:44 PM
JChin's Avatar
Quoted: 202 Post(s)
Liked: 158
Even when the source is set to PCM?
JChin is offline
post #6335 of 6345 Old 08-16-2015, 03:52 PM
ltd76gold's Avatar
Quoted: 29 Post(s)
OK, just for grins... Remove the hdmi from the Sony. See if the LG works as you would like. Then connect the Sony if possible with component / digital cable.
II have a hunch that the 70' hdmi may be a bit much in conjunction with the Sony run.
post #6336 of 6345 Old 08-16-2015, 04:20 PM
ltd76gold's Avatar
Quoted: 29 Post(s)
And Chin is correct for you to try pcm as well.
At this point.... Any Port in the Storm!!
post #6337 of 6345 Old 08-16-2015, 04:26 PM
caryt's Avatar
10-4, I play with it more tomorrow.
Thanks very much for the help!
caryt is offline
post #6338 of 6345 Old 08-17-2015, 01:51 PM
designmule's Avatar
Do any of you know of a way to watch video from one HDMI source while listening to audio from another HDMI source. I like to have music on most evening but it would be nice to also keep an eye on the game. I'm pretty sure the 809 can't do this but its worth double checking.
Thanks for the help
Matt
designmule is offline
post #6339 of 6345 Old 08-17-2015, 02:53 PM
ltd76gold's Avatar
Quoted: 29 Post(s)
http://forums.onkyousa.com/viewtopic...e76e7&start=10
Read through the posts in the above link.
I just use an analog out of the device I wish to listen to, assign that to an open source, then when viewing something thru hdmi I can press home and switch the audio to the music source I assigned.
All of this is one possibility. If you want to listen to music in another room with different speaker's in play, look into using the zone protocol.
Doug k
post #6340 of 6345 Old 08-18-2015, 01:22 PM
designmule's Avatar
Thanks. That's interesting. It won't work in my case (both my sources are HDMI) but it's good to know.
post #6341 of 6345 Old 08-18-2015, 01:30 PM
caryt's Avatar
Try PCM also
Tried all.
Still works as before with the exception using componit to the sony results in no picture to the sony.
caryt is offline
post #6342 of 6345 Old 08-18-2015, 09:39 PM
ltd76gold's Avatar
Quoted: 29 Post(s)
Tried all.
You did change the input on the Sony to Component and the output from the source through the Onkyo to Component?
post #6343 of 6345 Old 08-24-2015, 03:05 AM
bob brennan's Avatar
Quoted: 62 Post(s)
Liked: 126
Had internet repair in April - unit died yesterday - will not start - had bought 2 year extended warranty on "SHOP ONKYO" for $ 69.00.
Will take unit to AAA Electronics in Queens NY today (Onkyo approved service center!)
Annoyed!!!
Panasonic TC-P65ZT60 - Oppo BDP-103D - Panasonic DMP-BDT220 - Toshiba HD-DVD-3A - OPPO DV-981HD - Harmony 880
Onkyo TX-NR809 --- Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #6344 of 6345 Old 08-27-2015, 05:48 PM
mtrot's Avatar
Quoted: 56 Post(s)
Liked: 30
SiriusXM via NET input--update required by Sept. 30?
Just got a letter today from SiriusXM saying that an update will be required to my Onkyo device in order to continue to play the the enhanced streaming service as of Sept. 30.
Does anybody know anything about this? And will Onkyo make an update available?
mtrot is offline
post #6345 of 6345 Unread Today, 07:25 PM
ltd76gold's Avatar
Quoted: 29 Post(s)
Removing old server from list.
Odd situ... My 809 while using DLNA now shows an old laptop as my server even if I wish to use my phone. I have to fire up either my phone or my desktop to dial in dnla
To use my phone, I have to exit from dnla and enter my smartphone from the Onkyo Android app. When I do this, when ever I try to change the volume in a different zone, I have to repeat the entire process of streaming from the main page of the app.
I think that somehow the 809 went home to momma to even find my old laptop as a source and there in lays the problem.
App upgrade doing this to anyone else?
Ideas?
Doug k
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
Gear in this thread - Nr809 by PriceGrabber.com
