"Official" Onkyo TX-NR809 Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #631 of 6544 Old 08-11-2011, 11:25 AM
Baked's Avatar
Originally Posted by shempgulp View Post
I'm planning on upgrading to either the 809 or 709. Please help me decide.
Is it worth the additional cost for the 809. I know a sales manager at my local ABC that always gives me a smoking deal. If I go this route I will also need to reconfigure my AV rack (additional cost) because of the size and weight of this beast.
Reading this thread I don't think I will be using the video processing on either unit. Most likely just "Through" or "Direct". I'm still a little comfused with the pass through options.
Is it worth the extra $$$ for features I may not need or use?
Thanks for your help.
The 709 doesn't sound as open as the 809. It sounds as though your kit will resolve the difference. Sound is not just about the power rating. The 809 sounds much better than the 808. The additional features are just icing.
The 609, while very good for the price, is budget kit and sounds like it.
You will probably end up changing video modes based upon source material. Direct or Through is a good default to choose, IMO.
I really like the ability to pass through HDMI to allow use of a source without powering up the AVR. I don't really need to watch the news in 5.1.
Unfortunately, it will only pass through a single selected HDMI source. I would prefer that it pass the most recently used.
Some users have had problems with the passthrough failing after the unit has been off. I had this problem when my 809 was connected to a modified sine wave UPS. When voltages needed bucking or boosting, the poor power quality caused my unit to fail. Powering up would restore everything. Plugging the AVR directly into the unconditioned wall socket temporarily solved the problem until I replaced the UPS with a pure sine wave unit.
Baked is offline
post #632 of 6544 Old 08-11-2011, 11:41 AM
PlethoraGreen's Avatar
I'm not at home to check, but I do remember an option when setting the pass through while off to "Last." I have not had a chance to try it myself, but my assumption at the time was that it would do exactly what you're talking about.
Maybe someone else has tried it?
PlethoraGreen is offline
post #633 of 6544 Old 08-11-2011, 12:05 PM
ruger311's Avatar
yes there is a Last and an Auto feature with passthrough
seems like when i am passing through the cbl/sat then turn on the BD the BD takes over though, so gotta be somewhere in the 1-8 inputs it might go in order of lowest numbered input?
ruger311 is offline
post #634 of 6544 Old 08-11-2011, 12:14 PM
shempgulp's Avatar
Originally Posted by winston9332 View Post
The 809 might be overkill for htib speakers, but the price difference has often been slim. the 709 is a great receiver.
did you all see the recent review of the 609 on hometheatermag? put out numbers similar to a 100
Onkyo TX NR609:
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 81.0 watts
1% distortion at 95.1 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 77.7 watts
1% distortion at 88.9 watts
http://www.hometheater.com/content/o...-labs-measures
For reference - here's what the Onkyo TX NR5008 puts out:
0.1% distortion at 79.1 watts
1% distortion at 95.5 watts
0.1% distortion at 78.7 watts
1% distortion at 94.6 watts
Sorry I should have clarified. I upgraded my HTIB speakers a few months ago to Acoustech PL-89 5.1.
shempgulp is offline
post #635 of 6544 Old 08-11-2011, 12:42 PM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
Cha ching, thanks!! Just ordered mine.
Originally Posted by castaño View Post
Onkyo TX-NR809 at 6ave.com for $676 + free shipping (discount code AFL4COUPON)
I ordered mine 10 min ago...
Sepen is offline
post #636 of 6544 Old 08-11-2011, 02:15 PM
slowly learning's Avatar
Originally Posted by Mikes2cents View Post
You might want to post in the HTPC section as my GTX460 does audio via HDMI no problem. Why are you using DVI? Is it because of the cable you have? Certainly you are not running HDMI to your PC display and audio to the 809 as a sound solution for PC viewing. Or maybe you are? Just curious.
Unfortunately my GPU doesn't have a HDMI out, so I need to use dvi from my pc. Apparently you can run audio through the dvi, but I haven't been able to get it to work.
Regardless, I don't think this is a solution I can have without buying a new gpu
I would prefer to have my pc video going to a monitor and the avr (then projector and tv). and my pc audio (optical/coaxial) going to the receiver too.
I don't know if the receiver can use both these signals at the same time? any experience?
Thanks again
slowly learning is offline
post #637 of 6544 Old 08-11-2011, 02:44 PM
bartkess's Avatar
been reading this thread.as i needed to update my old receiver.
Yamaha HTR 5890.
I was able to get my local fry's to match the amazon price of $741.19.The sales rep was a real pain as he did not know how to use the internet or amazon.com and thought prime member was the only one's that could get the price.anyway lets not get to far in to that.My setup:
Of course Onkyo TX-NR809
JBL Northridge E-100 front
JBL Northridge C-35 Center
JBL Northridge E-30 surrounds
JBL Northridge E-20 surround back
JBL Northridge E-250p Sub
Directv HR20-100
PS3 40 gb
sony KDL-40xbr4
Harmony 880 remote.
i do have the front speakers bi-amped
as with the yamaha i had them bi-wired using both speakers A-B
that also allowed for the surround backs to be active at the same time.
i did run the full Audyssey MultEQ® XT and pretty happy with the sound from both directv and the ps3 playing mp3's or blu-ray's.even standard dvd's sound great.
for the price this is a great receiver.lots of Power and Features.
very very happy with it.as for the video setting i set to direct.the sony does a good job on its own.
bartkess is offline
post #638 of 6544 Old 08-11-2011, 02:45 PM
bartkess's Avatar
dvi does not accept audio only video.
bartkess is offline
post #639 of 6544 Old 08-11-2011, 03:06 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Thanks again
Hi slowly learning, this receiver you can assign optical or coaxial audio to a HDMI video (or Component, Composite).
JChin is offline
post #640 of 6544 Old 08-11-2011, 04:02 PM
Stavs's Avatar
Hmm...came up at $959 after discount.
Stavs is offline
post #641 of 6544 Old 08-11-2011, 04:44 PM
Quoted: 73 Post(s)
Liked: 44
I think it was for a limited time only. I was going to get one myself but changed my mind.
jsil is offline
post #642 of 6544 Old 08-11-2011, 07:48 PM
Gordon Parr's Avatar
I ordered my 809 yesterday from B&H - $721.49. Will arrive Monday!!!
Murphy's New Law --
"If it doesn't fit, force it.
If it breaks it was meant to"
Gordon Parr is offline
post #643 of 6544 Old 08-11-2011, 09:28 PM
tompatrick's Avatar
Amazon has it for $704, 6th Ave-$702, and Vanns-$704. I thought when I jumped on the Amazon $699 deal a few weeks back, it would take longer to get back to that price range!
tompatrick is offline
post #644 of 6544 Old 08-11-2011, 09:54 PM
neworder71's Avatar
Originally Posted by neworder71 View Post
I've been researching some of the information on UPSs and the issue may be with the version we are using. A UPS either reproduces a normal wall socket sine wave or it doesn't. Most of the ones you get from a normal consumer electronics store are not sine wave, they are stepped...including my J10. Some of the research I found suggests a power strip is better option to a stepped UPS.
Apparently some strips (like some Panamax) actually turn the power off completely with any voltage fluctuation and then come back on when the voltage stabilizes. This might be the best option if you don't have full sine UPS and want better protection.
I'm leaving mine on the UPS until the next audio drop then switching to a strip to test it out.
Ok so I left it on UPS for couple days and the sound dropped out of the standby pass-through again. Then I switched to a standard power strip, same thing, no sound after a couple days. Sound will only come back with an on-off cycle of the power strip. Looks like it is time to call onkyo, out of town for a few days so it will have to be next wk.
For the others experiencing the same issue, what type of cable box/source have you seen it with. I have a year old DTV HD box (no dvr).
neworder71 is offline
post #645 of 6544 Old 08-11-2011, 10:03 PM
ruger311's Avatar
Have a morphine hd dvr. No problem "crosses fingers" since fw update
ruger311 is offline
post #646 of 6544 Old 08-11-2011, 11:20 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Hy, I just got my Onkyo 809 and I cant get Audyssey to work, it does all the noise tests with all the speakers including the subwoofer but then the screen sais it is calculating and it stays like that forever.
My last receiver was an Denon 2808 also with Audyssey XT and works great, ¿does any one know what could be the problem? ¿is my unit falty?, I can still return it and have it changed for another receiver.
Thanks for your help, and excuse my english I am from Spain.
NeogeoG is offline
post #647 of 6544 Old 08-11-2011, 11:37 PM
alluu's Avatar
Just picked up the 809 from 6ave for $661.05. Time to retire my 875 that I bought from 6ave in 2007 for $998. At this price, I couldn't help myself.
alluu is offline
post #648 of 6544 Old 08-11-2011, 11:40 PM
suicyco's Avatar
Have you updated the firmware? Otherwise I'd suggest its faulty in some way. Mine only took a few seconds to calculate and save. Try calling Onkyo or exchanging for another one if its not the firmware. I updated the firmware first thing out of the box, so I dunno if the factory firmware has any Audyssey issues.
suicyco is offline
post #649 of 6544 Old 08-11-2011, 11:42 PM
suicyco's Avatar
Wow, I wonder why the constant low prices? Its either the true price point of this receiver (great sales technique!) or they are trying to flood the market with newer receivers to wash away the bad taste from the last few models flaky hardware.
suicyco is offline
post #650 of 6544 Old 08-11-2011, 11:43 PM
Quoted: 73 Post(s)
Liked: 44
alluu,
How did you get it for that price. The price on this receiver is moving fast.
jsil is offline
post #651 of 6544 Old 08-11-2011, 11:52 PM
alluu's Avatar
Used the coupon code mentioned in this thread. $688.59 before the discount
ONKTXNR809ONKYO Onkyo TX-NR809 THX Certified 7.2-Channel Network A/V Receiver (Black)1$688.59
ZCOUPON6ave.com – Your Special Savings1($27.54)
alluu is offline
post #652 of 6544 Old 08-12-2011, 12:05 AM
NeogeoG's Avatar
Quoted: 29 Post(s)
Thanks for the help, yes ive also tried with the latest filmware but it does the same thing, beginning to think that its a falty unit.
I have my front speakers conected to a amplifier Vincent SAV 150 through the preout outputs, this afternoon I will try to conect all the speakers directly through de Onkyo, see if that makes any diference, if not I will have to return it.
NeogeoG is offline
post #653 of 6544 Old 08-12-2011, 06:29 AM
Stavs's Avatar
Well, I finally pulled the trigger on this unit. Big River had it for $702 this morning, so I jumped since I can have it tomorrow for an additional $4.
I'm upgrading from a Denon 3808ci that got hit by lightning. I wasd never really pleased with the interface of the denon, so I am hoping this is better.
Stavs is offline
post #654 of 6544 Old 08-12-2011, 07:51 AM
joeyvaz's Avatar
Quoted: 68 Post(s)
Liked: 29
does anyone know what bit rate Pandora streams at into this receiver? Just wondering because it sounds pretty good in my opinion.
joeyvaz is online now
post #655 of 6544 Old 08-12-2011, 10:11 AM
Baked's Avatar
Try updating the firmware, even if it is the same version. If that does not work it is probaby defective.
Your English is much better than my Spanish!
Baked is offline
post #656 of 6544 Old 08-12-2011, 11:54 AM
bartkess's Avatar
So no one commented on my setup.
bartkess is offline
post #657 of 6544 Old 08-12-2011, 12:41 PM
Baked's Avatar
You did not ask for comment or have any question or problem that I could see.
Baked is offline
post #658 of 6544 Old 08-12-2011, 12:41 PM
henbone11's Avatar
you did not indicate that you were looking for comments. not sure what you want to hear, except that someone is impressed with it?
henbone11 is offline
post #659 of 6544 Old 08-12-2011, 01:15 PM
bartkess's Avatar
thanks and you both are right i did not have a question or ask a comment.
but i do have a question now maybe you guys can help with.
on the old yamaha i had the crossover set to 80hz.this was suggested by another site a long while back dont remember the site.but was suggested for the speakers and the brightness of the yamaha.
after running the Audyssey MultEQ® XT setup it set it to 40hz.
also it set the LPF of LFE to 120hz (not sure what this does)
should i leave it or set it to 40hz? and if so what should the LPF of LFE be set to?
Thanks..
bartkess is offline
post #660 of 6544 Old 08-12-2011, 02:26 PM
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
leave it
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/2200 Sub
hdtv00 is offline
Onkyo Tx Nr809 , Component Amplifiers , Receivers Amplifiers , Onkyo Tx Nr808
