"official" Denon AVR-3312CI owners thread - Page 5 - AVS Forum
 1Likes
post #121 of 147 Old 04-16-2013, 09:47 PM
iAusio80's Avatar
Does the 3312 out 5.1 from optical out? I was checking to see if I could connect the Sonos Playbar to Denon's optical out vs. TV
Thx
iAusio80 is offline
post #122 of 147 Old 04-17-2013, 05:06 AM
Mfusick's Avatar
Quoted: 140 Post(s)
Liked: 761
This thread needs break down into cliff notes
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is offline
post #123 of 147 Old 04-17-2013, 05:16 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 602 Post(s)
Liked: 1369
Or simply review posts #3-6 in the Denon AVR-XX12 Owner's thread linked below. smile.gif
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#post_20422026
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #124 of 147 Old 05-18-2013, 07:46 PM
chichom27's Avatar
How do I know if my 3312CI can use Airplay?
chichom27 is offline
post #125 of 147 Old 05-18-2013, 07:53 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 602 Post(s)
Liked: 1369
It comes already installed on all the XX12 networking models to include the 3312CI. See p. 76 in your Owner's manual. smile.gif
post #126 of 147 Old 08-26-2013, 09:59 PM
iAusio80's Avatar
Thx
Just realized that it doesn't have an optical out ;( I guess no playbar for me ;-
iAusio80 is offline
post #127 of 147 Old 11-05-2013, 10:36 AM
palavering's Avatar
Originally Posted by pdepres View Post
......So I've figured out how to set the amp assign to normal in order to utilize my 6th and 7th speaker. Still haven't figured out why my 2nd sub is getting no signal.
Rather than remain frustrated, an easy solution might be to buy a "Y" connector. Run your subwoofer cable to the "Y" and then run a cable to each subwoofer. It should work fine.
If I am wrong, somebody please correct me.
Bill
palavering is offline
post #128 of 147 Old 11-05-2013, 04:50 PM
SanchoPanza's Avatar
Quoted: 76 Post(s)
Liked: 446
Rearranged the furniture today, so re-ran Audyssey, used SAVE Feature.
A few minutes ago, 3312 locked up, so did soft re-set, unit went back to Audyssey settings from June.
Pretty sure others have reported this before.
Will use LOAD Feature later, LoL.
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is online now
post #129 of 147 Old 11-23-2013, 02:57 PM
shogun94's Avatar
I have read the manual on the AVR-3312CI but I have yet to find in the menu where I can adjust the bass or treble. Can someone point out how to navigate to the bass and treble settings in the AVR-3312CI? Thanks.
DB
shogun94 is offline
post #130 of 147 Old 11-23-2013, 03:58 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 602 Post(s)
Liked: 1369
As noted on p. 100 of the Owner's manual, in order to adjust the Bass/Treble for Zone 1 you must first disable Audyssey Dyn EQ.
Audio/Video Adjust - Audio Adjust - Tone - Tone Control - ON
post #131 of 147 Old 11-26-2013, 08:16 AM
shogun94's Avatar
That was it as far as the dynamic EQ and tone setting, thanks.
I do have some more questions.
I am using an external amp for everything (all 5 channels) and I have a powered sub. When I run the calibration setup all the channel levels come up in the negative db range. The least amount of attenuation is the center channel minus a couple db and the other channels are -6 db etc. Does this mean the system calibrates so zero on the volume is a absolute reference level? Also, how would I know if I know where I can run the system before clipping starts? If 0db on the volume was where clipping starts at the preamp it would be easier to tell how loud I can safely turn the system up. My amp and sub do not indicate the power output so it's hard to tell where I am running the system as far as power level etc.
DB
shogun94 is offline
post #132 of 147 Old 11-27-2013, 11:41 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 602 Post(s)
Liked: 1369
Yes, after running Audyssey, 0db (or 80 on absolute scale) corresponds to "reference" movie volume, a level you generally do not want to exceed when using the AVR's on board amps.
post #133 of 147 Old 11-28-2013, 06:52 AM
shogun94's Avatar
Lets say that using the built in amp the system is calibrated to reference level using a give set of speakers. If the speakers are efficient, 0db may be no problem to reach for the built in amp and the amp could be only putting out 50W RMS / Ch to reach 0DB. If the speakers aren't efficient, the amp my be straining or unable to reach 0db without overheating or over current etc. I do not think in either case I can know where the upper end of the safe operational range is with the built in amp or an external amp. Is there any way to know where the upper end is for operating the system other than something starts to distort? I do have a powerful clean sounding amp and I have know idea haw hard I can push the system an still be in the safe range.
DB.
shogun94 is offline
post #134 of 147 Old 02-13-2014, 05:44 PM
joeycannoli's Avatar
Just had one of my HDMI ports blow on my 3312. Not very happy
joeycannoli is offline
post #135 of 147 Old 06-03-2014, 03:14 PM
shogun94's Avatar
I juts got a new firmware update a couple of days ago but can't find any info on what changed with the new firmware. Does anyone know what changed?
DB
shogun94 is offline
post #136 of 147 Old 06-03-2014, 03:44 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 602 Post(s)
Liked: 1369
Resolves the Netflix DD+ center channel distortion issue.
post #137 of 147 Old 06-03-2014, 05:01 PM
shogun94's Avatar
Is that all the firmware update does? I use Netflix all the time and never had a problem.
shogun94 is offline
post #138 of 147 Old 06-03-2014, 05:31 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 602 Post(s)
Liked: 1369
I have listed the change log in post #6 of the main 2011 Denon XX12 Owner's thread ...
post #139 of 147 Old 06-19-2014, 09:03 PM
blackscorpio's Avatar
Yesterday, my Denon 3312 started acting up.
I haven't switched on the AVR for a week, when I played a BD yesterday, the center channel was very low, I had to increase the channel level to almost +10 for the dialogue to be any audible. Nothing was changed, everything is same as was before. I tried to rerun the auddessy setup, when checked the channel levels, front LR were -2 and -2.5 whereas center was setup at +10, surrounds -2 and -2.5. To rule out the speaker problem, I swapped the Right with center and reran the setup, still the same channel levels, center at +10.
I did a microprocessor reset, again the same results.
any ideas? suggestions?
blackscorpio is offline
post #140 of 147 Old 06-19-2014, 09:29 PM
Quoted: 76 Post(s)
Liked: 446
Sounds like an Amp blown; call Denon.
Mfusick likes this.
post #141 of 147 Old 06-21-2014, 10:00 PM
Shouldn't be the case that there should be NO SOUND, if it were a blown amp.
Is there any test to make sure its really blown amp?
Anyone has any idea what could be cost of replacing the amp, just to get an idea of it? I am not in the US, I am trying to find out if there is a Denon service center here.
post #142 of 147 Old 06-22-2014, 03:18 AM
Quoted: 76 Post(s)
Liked: 446
That's what happened when the Right Front Amp was Blown on my 3312.
Swap speakers & speaker wires; if it follows, it is the wire &/or speaker. If not, it is the amp.
Which is what you have already done; therefore I think it is the Center Amp, sorry.
post #143 of 147 Old 06-24-2014, 06:28 AM
Lucky me! the problem got resolved itself. I wanted to see if I could see anything blown in the AVR, so removed all cables and observed nothing. So, hooked up everything back, ran the setup again. new parameters are:
L:-2
R:-3
C:-3.5
SL: -2
SR:-1.5
Now, I will have to setup again, with multi point audessey and other settings, as was my previous setup.
post #144 of 147 Old 06-24-2014, 11:25 AM
Quoted: 76 Post(s)
Liked: 446
That's good news.
post #145 of 147 Old 06-24-2014, 09:42 PM
That's good news.
Yes, that is indeed.
Thanks for chiming in.
post #146 of 147 Old 06-25-2014, 04:52 AM
Quoted: 76 Post(s)
Liked: 446
My Center & Surrounds sometimes go out;
If I press down on the top back of the AVR, near the HDMI out, I hear a click & the channels start working.
post #147 of 147 Old 06-25-2014, 08:37 AM
Lucky you; you know the trick, you don't need to keep searching for a solution every time it happens.
User Tag List
