Budget AV Receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-18-2011, 07:34 PM - Thread Starter
Shari13's Avatar
I'm nowhere near an audiophile, but I do love and want good sound in my 22X12 living NYC living room. I'm looking for a receiver to replace old and now dead Denon DRA stereo receiver with easy connectivity to 3 y/o Samsung 40" LCD tv, IPod readiness and a bit of future-proofing.
I've been looking at Onkyo SR-TX309, Yamaha RX-V471, and Denon AVR 1612. I think the Onkyo 509 is more in the league with my Yamaha and Denon choices, but what's nice about the 309 is Ipod readiness at a ~$100 lower price point. thanks for any tips and input.
Shari13 is offline
post #2 of 13 Old 06-18-2011, 07:44 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Denon avr-591 the model previous to the avr1612 can be had for $250 on amazon and you will not be able to get a better receiver than that at that price.
crazyrob425 is offline
post #3 of 13 Old 06-18-2011, 08:58 PM - Thread Starter
Shari13's Avatar
Thanks crazyrob. I have no problem with last year's models, but it looks like the 591 requires purchase of dock for mp3 connectivity, which i'm so trying to avoid.
Shari13 is offline
post #4 of 13 Old 06-18-2011, 09:21 PM
skally's Avatar
I am an Onkyo fan without a doubt but for the option that you listed maybe you might want to look into this as well...
http://www.amazon.com/Pioneer-VSX-10...453369&sr=1-14
Otherwise the 509 would work mas well
Good luck
skally is offline
post #5 of 13 Old 06-18-2011, 09:54 PM
Quoted: 443 Post(s)
Liked: 337
Denon AVR-1911 is a possibility with a USB hook up for iPod
http://www.crutchfield.com/p_033AV19...11.html?tp=179
It won CNET's test to be the best sounding midrange receiver...
http://news.cnet.com/8301-17938_105-20017189-1.html
post #6 of 13 Old 06-25-2011, 01:31 PM - Thread Starter
Shari13's Avatar
Can I use the old speakers with the new AVRs till I'm ready to upgrade?
So its a Samsung 40" LCD HD TV, Panasonic Hard Drive DVR about 5 y/o, and Macbook Pro about a year old.
I would have loved to get a real cheap receiver for now, but I'm starting to covet new features like Ipod connection and internet radio. Does that probably put me in the $3-400 range at least?
Thanks again.
Shari13 is offline
post #7 of 13 Old 06-25-2011, 02:14 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
It depends on the speakers. If they are 6 or 8 ohms, then yes. If they're less than that, probably not.
BIslander is offline
post #8 of 13 Old 06-25-2011, 02:25 PM - Thread Starter
Shari13's Avatar
Here http://stereonomono.blogspot.com/2010/08/b-dm-310.html it says impedence 8 ohms. Good? Thanks so much.
Shari13 is offline
post #9 of 13 Old 06-25-2011, 02:30 PM
skally's Avatar
Yes, you can use those speakers with the new AVR no problem. In fact you may like them... who knows.
http://www.vanns.com/shop/servlet/it...oneer-vsx1020k
skally is offline
post #10 of 13 Old 06-25-2011, 02:42 PM - Thread Starter
Shari13's Avatar
I was just leaning toward Pioneer 820. Great price on Amazon and even Best Buy. Do you happen to know what I lose from the 1020 on the 820. (head spinning . . . )
Shari13 is offline
post #11 of 13 Old 06-25-2011, 04:25 PM
skally's Avatar
With the 1020 you will get a few more features is all such as: Internet Radio, iPhone Remote App, 6 HDMi (.. as aposed to only 4HDMI's on the 820), 7.1 as to the 820 has 5.1, a better on-Screen Display or GUI as the 820 only has Text. If those features arnt a concern to you then the 820 will work just fine as it will save you a few dollars as well.
skally is offline
post #12 of 13 Old 06-25-2011, 05:55 PM - Thread Starter
Shari13's Avatar
I'm a huge fan of local radio, but even here in NY choices are limited, so internet radio has started to sound like a feature I'd use much. Though could you do access it by connnecting computer, and letting computer pull sound from web?
I'm a bit acronym shy - GUI - ___ ___ Interface? I'm guessing it's the kind of thing I may not miss without it, until i have it . .
Shari13 is offline
post #13 of 13 Old 06-25-2011, 07:14 PM
BurtReynolds's Avatar
Graphical User Interface - "GUI"
IMO, you are correct, you don't "need' an a receiver that can pull internet radio on its own if you plan to hook a computer up to it anyway.
Of course by that same line of thought, you wouldn't need the iPod integration since you theoretically have the music on your computer.
BurtReynolds is offline
