First AV Reciever!! Onkyo TX-NR609 or TX-NR708? - AVS Forum | Home Theater Discussions And Reviews
Old 06-20-2011, 06:33 AM - Thread Starter
ogremilk's Avatar
Hey guys,
I am looking to buy my first home theatre set up and am torn between the Onkyo TX-NR609 and TX-NR708....
Being a complete novice when it comes to all this, and after reading all other threads/posts on others asking the same question, I'm still at a loss as to which will suit me better.
I work for an electronics store and am able to purchase the TX-NR609 at cost and the TX-NR708 at 10% below cost, which will still be $150NZD more expensive. Is what the TX-NR708 offers worth the extra cost? I'm not too sure if the Audyssey 2EQ vs. Audyssey MultiEQ debate will apply or not as I have never used this.
I will be using either the Kef KHT2005.3 speaker package...
www .kef.com/gb/SurroundSound/kht/2000
Or the Jensen XR series...
www .jensenspeakers.com.au/page/shop/browse/a/category/e/products_xrseries
(sorry about the broken links, I'm only new to this site and it automatically won't let me post URL's in case I'm a spammer ha)
Please help!
ogremilk is offline
Old 06-20-2011, 08:32 AM
skally's Avatar
Both are a good choice I believe so eighter will work out just fine for the set up you have listed. Its up to you and your pocket book thou,Just me... I would choose the 708 as it has the Muliti EQ.
skally is offline
Old 06-20-2011, 06:25 PM
eliteconcept's Avatar
you may consider the rc370 as well.. it has just a couple less features than the 708 at about $100 US less
eliteconcept is offline
Old 06-20-2011, 09:44 PM - Thread Starter
ogremilk's Avatar
Am I likely to use the Audyssey technology though? I have never had an amp before so do not know how easy/hard it is to use or to get right. And apart from the MultiEQ, is there anything else which seperates the 609 or 708 apart from the upscaling?
ogremilk is offline
Old 06-20-2011, 09:48 PM - Thread Starter
ogremilk's Avatar
Had a quick look at it online and it seems like an impressive amp for the cost, but it isn't an amp I can get a hold of through where I work, which means I'd be paying quite a bit extra to buy from another retailer. The only other amp that we have that I have been tempted by is the Yamaha RXV667, being around the same price bracket for what I can afford.
ogremilk is offline
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Onkyo Tx Nr708
