Help! Yamaha RX-V1400 has "muted" fronts!! - AVS Forum | Home Theater Discussions And Reviews
Old 06-20-2011, 10:42 AM - Thread Starter
Stippy420's Avatar
Some time ago, it seems that my rx-v1400 stopped outputting to both front speakers. Well, not stopped, but it's very, very quiet/muted, test tone cannot be heard. All the other channels sound just fine; loud and clean.
I've gone through the receiver's manual setup again, connected those speakers to the "B" outputs and reset the unit back to factory settings. No change. (was really hoping my 5-year old accessed some random setting)
Since I'm not working at the moment, I'm really hoping that this is something that I can fix myself (I'm a little above average with soldering/desoldering, replacing components on boards, using a meter, etc.) or at least won't cost me a lot to get fixed.
Does anyone have any ideas as to what the problem might be? Is it worth fixing or do I just live with it like this for a while? I can't see myself spending the money on a new receiver anytime soon, no matter how much I'd love to.
Thanks in advance for any and all help!!
Stippy420 is offline
Old 06-20-2011, 12:49 PM
JOHNnDENVER's Avatar
Do you ever use headphones on it?
Similar but not the exact same complaints on some of these Yammy's have ended up being something with the headphone circuit and/or settings.
JOHNnDENVER is offline
Old 06-20-2011, 01:20 PM
MarkSmith's Avatar
If there is a speaker A/B button try it.
Mark
MarkSmith is offline
Old 06-20-2011, 01:56 PM - Thread Starter
Stippy420's Avatar
I tried it with just A (normal) and AB "on". Also moved one speaker to B for the hell of it, tried AB and just B with that setup, same problem.
As for headphones, I never use them... maybe once or twice years ago.
Old 06-20-2011, 02:05 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 7350 Post(s)
Liked: 3388
Sounds like amp failure. Have you tried connecting a 2CH amp to the FL/FR preouts? You can probably pick up a used amp for fairly cheap on Craigslist.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Sony, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
Old 06-20-2011, 06:14 PM
M Code's Avatar
Quoted: 440 Post(s)
Liked: 261
Have you tried a Processor Reset..
Just my $0.02...
M Code is online now
Old 06-21-2011, 08:53 AM
Yes he has... "and reset the unit back to factory settings. "
In the intial post from the OP.
Old 06-25-2011, 04:13 PM - Thread Starter
Stippy420's Avatar
So it looks like I'm going to have to take the unit in to get an estimate... $50- $100 just to look at it at the "authorized" service centers, non-refundable. (what ever happened to free estimates?)
Ugh. Oh well, I hope it won't be too much to fix.
Thanks for the replies/suggestions!
Yamaha Rx V1400 Av Receiver 6 1 Channel
