Receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-07-2011, 03:00 PM - Thread Starter
Thinroyy's Avatar
Right now i have a 250W surround sound stereo system w/DVD player by RCA and I'm looking to boost my decibel level. I have 2 (two) Pioneer CS-911A's along with another 100W surround sound system. I was curious what kind of receiver, if any, I could use to connect all 3 systems, how much it would cost, and where i could get it. Also, i was wondering that, if there isn't a receiver that I could use, if there was a way to wire 2 (two) or more separate receivers to get the desired result.
Thinroyy is offline
post #2 of 6 Old 07-07-2011, 04:04 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Don't bother...
I could try to explain why, but it will take to long I think.
If you really want a better system, get a mid range receiver (like the Yamaha RX-V6xx models) and some quality speakers.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 6 Old 07-07-2011, 04:08 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
What's the purpose of wiring the systems together? Are they in the same room?
I would scrap the whole RCA system setup and start off with a good receiver and some new speakers.
What's your budget?
Afro GT
afrogt is offline
post #4 of 6 Old 07-07-2011, 04:39 PM - Thread Starter
Thinroyy's Avatar
Yeah, they're all in the same room. And i just want them wired together for maximum sound, the RCA speakers are decent, along with the CS-911A's which are 30+ years old, so sound quality isn't one of my concerns, the only thing that worries me about it is that the RCA receiver can't handle the wattages. If I can't get the original plan to work out, what would you recommend i do? I've had the two systems hooked up in separate rooms on different receivers (the CS-911A's are hooked up to a Panasonic SA-H30 so they're not that impressive right now) and the RCA system is, basically, crap, since it turns off if i turn the volume up too much. Any suggestions?
Thinroyy is offline
post #5 of 6 Old 07-07-2011, 05:29 PM
mjpearce023's Avatar
Quoted: 34 Post(s)
Liked: 38
I would go with MichaelJ's recommendation. 14 low quality speakers will not sound as good as 2 good quality speakers.
mjpearce023 is offline
post #6 of 6 Old 07-07-2011, 08:17 PM - Thread Starter
Thinroyy's Avatar
Like i said though, I'm not looking for quality I'm looking for loudness...but i do appreciate the reply, if all else fails I'll sell it all and try to buy some good speaker's
Thinroyy is offline
