The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
Old 08-27-2011, 09:35 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6566 Post(s)
Liked: 3634
I have a recurring problem that I wanted to share to see if anyone is experiencing the same, and to see if there is a solution. It's not a big problem, but annoying nevertheless.
I have a Denon 4311, so the connection between the AVR and Pro is a serial-to-USB cable. My laptop is running Windows 7 Ultimate 32-bit, and I and using the Prolific USB-to-Serial drivers.
The issue is this: if the laptop perceives that there has been inactivity on the USB port for a specific time, the port times out. I haven't been able to measure the timeout value, but it is probably 3-5 minutes. So, if I take too long to move the mic into a new measurement position, or I get distracted, the next time I click on "measure", Pro issues a communications I/O error because the USB port has timed out. The immediate fix is simple--unplug the USB cable, re-connect it, and click on "measure" again, and Pro is happy once again.
I really would like a permanent resolution if anyone has a suggestion.
AustinJerry is offline
Old 08-27-2011, 09:39 AM
ronaldjoe's Avatar
Added on:
Pardon me, I am new to this thread and Pro kit.
Where is the best place to get a set pro kit online?
ONKYO | EAD | SILNOTE | WIREWORLD | KIMBER | TARALABS | RPGC | PARADIGM | PBK Sub Calibration
ronaldjoe is offline
Old 08-27-2011, 10:03 AM
calentz's Avatar
Quoted: 57 Post(s)
Liked: 42
I presume that you don't have the power supply connected & the port shuts down to conserve the batt; you might try using the L/T with the power connected.
--Carl
calentz is offline
Old 08-27-2011, 10:06 AM
Liked: 3634
Originally Posted by ronaldjoe View Post
Added on:
If you go to http://www.audyssey.com/installers/installer-program, you will be asked to contact a professional installer in your area, from whom you can purchase the product. If your local installer can't help, call Audyssey tech support and ask for Luke. He will be able to advise you.
The Pro Kit costs $550. The required AVR-specific license file costs an additional $150. The latest software version is 3.4, which can be downloaded from the Audyssey installer web site, http://installer.audyssey.com/Home.aspx.
Old 08-27-2011, 10:44 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Both 4311 and 5508 are paired with EAD PowerMaster 5ch amp.
The EAD PM amps are one of the best amps ever made. My PM2000 smoked the Theta Dreadnaught in my system, wasn't even close.
mjaudio is offline
Old 08-27-2011, 11:01 AM
Liked: 3634
That would not be a correct assumption--the laptop is connected to power. I'm thinking there might be a setting to enable/disable power conservation (regardless of whether the laptop is connected or not). However, looking at the driver detailed options (see attached), none of the options seem to apply.
Old 08-27-2011, 06:19 PM
ronaldjoe's Avatar
Thanks for tips and guide . I was initially under the impression that the Pro Kit costs $550 comes with license as well.
I am residing in overseas and will drop audyssey a note for next step.
Yeah, I love the amp more these days.
Old 08-29-2011, 11:47 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Pro Kit is sold separately. Someone might be selling a kit and thinking they can include a license, but that is generally not possible.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 08-29-2011, 02:37 PM
fitzcaraldo215's Avatar
Quoted: 38 Post(s)
Liked: 42
Right, the license and the kit were always separate. The license stays with the processor. It is only transferrable by the installer or kit owner who registered it to another processor by the same manufacturer.
fitzcaraldo215 is offline
Old 08-29-2011, 02:49 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Maybe I am reading this wrong but from my understanding the license stays with the pre-pro or receiver and cannot be transferred. From what I understand the license I bought with my 5508 will stay with that pre-pro, if I then bought a 5509 I would have to purchase another Pro license for the 5509 even though I own a kit. Am I wrong?
mjaudio is offline
Old 08-29-2011, 03:01 PM
mjf_uk's Avatar
This is also the way I understand it, after contacting Audyssey a few months ago to confirm. I was told that the only way a license can be transferred is if your Processor is faulty and is replaced with a new/different one.
mjf_uk is offline
Old 08-29-2011, 07:27 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I'd stick with the 5508.
pepar is offline
Old 08-29-2011, 07:39 PM
Liked: 3634
Originally Posted by uydguy View Post
Looks good! I recommend here! http://351100.tk/33
WTF? Spam?
Old 08-29-2011, 08:13 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
WTF? Spam?
report that post
pepar is offline
Old 08-29-2011, 09:15 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Your right, no real reason to go with the 5509 from the specs I have seen so far.
mjaudio is offline
Old 08-30-2011, 07:57 AM
Quoted: 38 Post(s)
Liked: 42
I have done it as part of a normal upgrade process. There was never a question of whether the unit was faulty or not. Just contact Luke at Audyssey Support. But, it must be to the same manufacturer. I do not even think you could transfer an Onkyo license to an Integra, though they are the same company.
Old 08-30-2011, 08:05 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
That's great to know.
Thanks for the info.
mjaudio is offline
Old 08-30-2011, 08:31 AM
mjf_uk's Avatar
But when was this? Maybe Audyssey have since decided to no longer allow such things.
mjf_uk is offline
Old 08-30-2011, 09:50 AM
ronaldjoe's Avatar
Thanks for the info. I have dropped Audyssey a mail for further guidance and instruction to purchase a Pro Kit.
Say my friend and I are having the same model of processor, how many license is required?
Old 08-30-2011, 09:56 AM - Thread Starter
SoundofMind's Avatar
Liked: 166
^1 license per unit.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 08-30-2011, 10:00 AM
ronaldjoe's Avatar
EDIT: Found my answer, each license is tagged to a specific serial number of an installer ready device. Thanks
Old 08-30-2011, 10:10 AM - Thread Starter
Liked: 166
I have done it as part of a normal upgrade process...
Interesting. When I asked Luke if I could buy a license for my 4310 to my planned-in-the-near-future 4311/A100 he said no. When I asked Luke if I could transfer the registered-to-a-4311 license that was offered with my used Pro kit to my 4310 he said no. But he was nice about it.
So though I had the kit in hand, I waited till I got the A100. That was tough but I did it to save $150.
Old 08-30-2011, 11:24 AM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
I had to pay again when I replaced 4810 w/4311.
Noah
noah katz is offline
Old 08-30-2011, 04:29 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Interesting. When I asked Luke if I could buy a license for my 4310 and then transfer it to my planned-in-the-near-future 4311/A100 he said no. When I asked Luke if I could transfer the registered-to-a-4311 license that was offered with my used Pro kit to my 4310 he said no. But he was nice about it.
An unregistered license can be transferred within a manufacturer's family. I purchased two for the Onk 885 and never used the second. When I bought my 5508, I transferred it myself on the Installer's website.
A registered license can be transferred at Audyssey's discretion from a defective unit to a different unit. But generally, a license that is registered stays with that unit.
Jeff
pepar is offline
Old 08-30-2011, 08:39 PM - Thread Starter
Liked: 166
^Excellent clarification, Jeff. I'll edit my post to be more precise.
Old 09-11-2011, 09:13 AM
BigCoolJesus's Avatar
Quoted: 685 Post(s)
Liked: 380
Hey guys,
I am going to be picking up an Integra DTR-70.2 in the next week or two (as long as my dealer can get one ordered in since the 70.3 was announced). My current receiver is a DTR-40.2 with basic MultEQ.
I have been told that jumping from MultEQ to XT 32 will be a very noticeable difference, so I have to ask: Is dishing out another $500-700 for Audyssey Pro going to make the same noticeable difference from XT 32 to Audyssey Pro?
Upgrading to the DTR-70.2 was a little stretch of my budget, but tacking on Audyssey Pro would definitely put a lot more strain on my wallet. If the consensus is that Pro makes a difference but nothing remarkable over XT 32 than I will bypass getting it. But if it truly does make a night and day difference than I will find a way.
BigCoolJesus is offline
Old 09-11-2011, 09:18 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
In my personal experience Audyssey Pro makes the biggest difference with music, with movies the difference is not as big and IMO not needed.
If you don't already have room treatments I would use the $500 for Pro and invest it in room treatment instead, would make more of a difference.
mjaudio is offline
Old 09-11-2011, 09:57 AM
Quoted: 685 Post(s)
Liked: 380
Guess I should have added that information in my post: My room is strictly Movie/Game/DirecTV.....no music. So I'm assuming that just reaffirms the notion to not get Pro?
Thanks for input so far!
Old 09-11-2011, 11:15 AM - Thread Starter
Liked: 166
^Unless you're lucky enough to find a used kit, it's $550, plus $150 for license=$700. And IME it is NOT "night and day". I don't get the same "bump up" from Pro as I did upgrading from XT to XT32.
Pro's big value-added for me is the distinct and significant SQ improvements for MC music. It does improve film, but probably not noticably to the same degree as music, as mj mentioned. The customization and measuring capabilities are nice plusses too.
Old 09-11-2011, 11:49 AM
Quoted: 685 Post(s)
Liked: 380
Awesome, thanks for the input guys!
Denon Avr4310ci Receiver , Audyssey
